Meter box on outside of main bedroom wall -leave it or move?
Page 3 of 3
Will depend on how much you want it i guess.
$155 for sub mains cable is a rip if it is back to back.
You always pay 100 times the cost if doing via builder.
I guess I'll do afterwards if I need it
The sparky was called in to install extra powerpoints for a/c units in a few different rooms.
Upon doing a check of everything, it was discovered the mains cabling coming in was only 4mm cable, so it was impossible to add anything more to the house until the incoming cabling was upgraded to something a lot more substantial.
My sparky asked the home owner what he did to p!ss off the builder's sparky, as he explained why so much had to be done. I think he said the quote would worked out at around $12K, and even then the trenches would have to already dug, as he had two options, 1/. dig up the new pebblecrete driveway, as the power ran underneath it, or 2/. run straight up to house, then through the roof to get to the circuit board.
So it really pays not to p!ss off your builder or his sparky !
Is it not possible to use the existing conduit under the driveway to feed a new cable ?
Not possible, as I think he said it was only 25mm conduit used, so the lot has to be dug up and replaced.
My sparky asked him why he didn't get the builder's sparky to do it, and the response back was along the lines of the prices to be charged were a rip off.
There's no doubt more to this story.
6
The warning is on the sticker on the door too. Second the aluminium powdercoat
