Browse Forums Building A New House 1 Oct 01, 2014 4:14 pm Hi all, I thought I would create a new thread documenting our Brisbane build with a custom builder. Back in January 2013 we found a vacant block in Norman Park - an established suburb of Brisbane. The block is 502m2 with a 10m frontage and 50m depth. It has a down slope/fall of 1 in 5.8 or approximately 10 degrees and also backs onto the railway line. Being first home buyers, we decided to buy the block as the location was great. If we were to buy in a new estate we would be a lot further out from the city, and we'd be looking at a similar price for the land as well. We knew there would be some challenges building on the block, but we managed to it at what we though what was a reasonable price. Below are some pictures of the land when we first purchased it. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - Plans 2Oct 02, 2014 9:48 am As our block is located in an older established suburb of Brisbane, our design was required to comply with the Brisbane City Council Character Code. This meant the use of lightweight materials and metal sheet roofing, to preserve the 'Queenslander, timber and tin' aesthetic of the local neighbourhood. The houses on our street are all built prior to 1949 so we thought it was very important build a house that complemented the character of the neighbourhood. Having a narrow frontage also meant the design was also required to comply with the Small Lot Code - this meant the width of our house was to be a maximum of 7 metres. Given the difficulties of our moderately sloping block and narrow frontage we soon found out that no volume builders would even talk to us. So we had to go about finding a custom builder. We also discovered that there were no 'off the shelf' plans suited to our block. We required a double story split level home, elevated off the ground on steel poles. I ended up designing a house suitable to our block. Below is a copy of our floor plan. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - Site Works 3Oct 02, 2014 3:13 pm Site works & poles going in. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Build in Brisbane - Suspended slab & flooring 4Oct 02, 2014 3:20 pm Suspended slab and first floor particleboard flooring. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Build in Brisbane 5Oct 04, 2014 1:42 pm Wow,good job on designing something to suit your block. How much will it cost to build considering its a character home? Re: Custom Build in Brisbane 6Oct 05, 2014 10:55 am Looking forward to following this build as we're just about to start something with many similarities. Re: Custom Build in Brisbane 7Oct 07, 2014 9:41 am thebrolga Looking forward to following this build as we're just about to start something with many similarities. I'll be following your build with interest, your design looks great! Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - Selections 8Oct 07, 2014 10:07 am Some of our selections - Kitchen: Cabinetry - Laminex 'Charcoal' narual finish Benchtop - 20mm Caesarstone Clamshell Splashback - Matte white 300x100 brick bond tiling Mixer - Abey SK5 pull out mixer Sink - Abey Lucia LUA200 double bowl undermount Oven - Siemens HB75GU550A 60cm pyrolytic oven Microwave - Siemens HF35M562BP built in microwave Dishwasher - Siemens SN46M582AU stainless steel built-under Cooktop - Siemens ER926SB70A 90cm gas cooktop Laundry: Cabinetry - Formica 'Snow Drift' gloss Benchtop - 20mm Caesarstone Clamshell Splashback - Matte white 300x100 brick bond tiling Flooring: Boral 19mm Solid Strip Flooring - 'Australian Beech' to main floor area Wet area tiling - National Tiles - Belgium Stone 'Cenere' Bedrooms - Godfrey Hirst Calais Shades - Furnace Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - Frame completed 9Oct 07, 2014 3:19 pm Framing complete & scaffold up Upper storey wall frames up Roof frame complete and scaffold up The back deck Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - ROOF! 10Oct 10, 2014 9:37 am The roof! As well as windows, external doors & the start of cladding. Front entry Living & dining windows Sliding doors to deck Start of weatherboard cladding Back of the house Mandatory dunny pic Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - ROOF! 11Oct 10, 2014 9:57 am Oh, you've spared us all the drama! A build on fast forward. Those Norman Park hills sure are a challenge, but completely worth it. What a great part of Brisbane. The "character home" has me interested. Added to that your choice of floors, tiles and bench tops and I'm definitely following. Beech floors are going to be divine. I have picked the Clamshell caesarstone for our powder room, so I'm looking forward to seeing yours go in. http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Custom Brisbane Build - Character Area - ROOF! 12Oct 10, 2014 10:54 am housebythewater Oh, you've spared us all the drama! A build on fast forward. Those Norman Park hills sure are a challenge, but completely worth it. What a great part of Brisbane. The "character home" has me interested. Added to that your choice of floors, tiles and bench tops and I'm definitely following. Beech floors are going to be divine. I have picked the Clamshell caesarstone for our powder room, so I'm looking forward to seeing yours go in. We started our build mid-year and are now nearing completion - about 3-4 weeks away from moving in. I was always meaning to create a thread - especially because there aren't too many Brisbane Character Zone builds on Homeone, but I was slack and didn't get around to it until now. Caesarstone Clamshell wasn't our first choice. We originally selected Organic White, however it was out of stock until the end of October. Not wanting to delay the build/move in date, we switched to Clamshell and are really happy with it! Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - ROOF! 13Oct 10, 2014 11:51 am That's a very quick build. http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Custom Brisbane Build - Character Area - ROOF! 14Oct 10, 2014 4:36 pm Yeah, the builders haven't messed around at all. The most difficult part to manage has maintaining access to the site. When neighbours park their cars in front it makes it very frustrating. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - ROOF! 15Oct 12, 2014 3:49 pm Hi, just found your build and looking forward to following. We are custom building on a sloping block and love following these builds, thanks for sharing Love your colour choices, Cheers! Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Custom Brisbane Build - Character Area - ROOF! 16Oct 14, 2014 2:50 pm I love your pretty and cool house and I fetch a tremendous idea, going to apply Re: Custom Brisbane Build - Character Area - ROOF! 17Oct 14, 2014 3:20 pm That is looking really good. Well done. We are hoping to start build at the beginning of Jan with Valeco. We'll be using steel poles as well. Re: Custom Brisbane Build - Character Area - Lock up 18Oct 20, 2014 10:28 am Garage looking towards the street Front entry, looking at the stairwell and through to the living/dining area Study Kitchen/Laundry/Dining/Back Deck Out to the back deck Main bedroom french doors to balcony Front facade Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Custom Brisbane Build - Character Area - Lock up 19Oct 20, 2014 7:37 pm Your build is on fast forward!!! Love those big gums down the back...really looking forward to seeing the interior fit out. Re: Custom Brisbane Build - Character Area - Lock up 20Oct 22, 2014 10:04 am Lovely outlook from the deck. http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Any advice on a builder in NSW who is demanding an extra 22000k after the house is completed and contract paid in full .Standard HIA contract. Never received a variation.… 0 20525 It is in lake macquarie area and dimensions are width 14 m and depth 8 m and the slope is 1/5 going down from the road. 1 7090 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 |
