Browse Forums Building A New House 1 Sep 29, 2014 1:22 pm So we are lucky enough to have this lovely PIT on our land, we're not too worried, but I was expecting it to be more of a drain? Does the green plastic cover come off? Can we build an elevated deck over this? (which is our main plan) Which will just be stumped (no slab) and allow water to run under it? Maybe even have an access panel to lift up if it ever needed to be accessed? Hellllp, we always knew it was going to be there but now I've seen it and I'm not sure what I'm even looking at haha Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Anyone else had one of these things on their land? (Drai 2Sep 29, 2014 6:00 pm Looks like a drain/sewer access point. If it is, it should be part of an easement therefore permitting you from building over it. Do you have any easements running through your property? Dale - Building Newbie Proserpine, QLD Re: Anyone else had one of these things on their land? (Drai 3Sep 29, 2014 7:11 pm Yes, we have one of those (access to the local stormwater drainage scheme) and as dalemengel says it is indeed protected by an easement (no-go zone) so no, we can't anything build over it. If you look at your site detail drawing you should see a zone marked in as a easement to protect it. Easements are for all kinds of underground services. They are areas that authorities need to access if/when something goes wrong with the line/service and they can then easily gain access to fix it. I hope you have somewhere else you can build your deck Re: Anyone else had one of these things on their land? (Drai 4Sep 29, 2014 7:44 pm Bugger. Its ugly, haha Re: Anyone else had one of these things on their land? (Drai 5Oct 23, 2014 7:09 am From your other post that I read, it sounded like your builder is doing your deck is this right? As I thought they would have told you about not being able to build over an easement. Easements are such a pain we have one too but lucky enough it's closer to the back of our yard so enough room for a pool ours won't be like yours I don't think though atm it's just a pipe sticking up which I'm assuming they will cut down and cap. That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81896 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4546 Agreed. I just found out today the certifier has not given the final sign off. 2 4094 |
