Browse Forums Building A New House 1 Sep 27, 2014 5:52 pm Hello all, After lurking in the background for a couple of weeks, I have decided to join up as my plans to start building gain momentum. I am a single, male, 26 year old, so have to build within my means as I don't have another half to help pay it off I have purchased a 794m2 corner block in a quiet new estate in Proserpine, QLD and looking to build in the next few months. I have already selected the builder and the house plan which I have made several alterations to. Most of you will not have heard of the builder before - Moloko Homes, as they only build in the Whitsundays. They are probably the biggest local builder with a very good reputation. This is the floor plan I have come up with, based on their Gloucester design (http://www.molokohomes.com.au/our-desig ... CZcXvm1bYh). I made quite a few changes - see plan below which I developed by myself online: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dale House 2 by Dale Mengel, on Flickr Room dimensions as follows: Master - 4.92mx4.6m Bed 2 and 3 - 3.06mx3.2m (not including robes - a bit on the small side, but suitable for me) MP/Bed 4 - 3.8mx3.6m Alfresco - 9.73mx4.2m (increased width by 1m from original plan) Garage - approx 5.8mx5.8m (a bit on the small side, but rather put the $$ into extending the alfresco) Bath - 1.92mx3.13m Kitch/Dining/Lounge - 4.65mx10.53m Total floor space - approx 240m2. Total price about $319,000 (includes turfing, fencing, double gates and one single gate), which is about $10,000 under my budget, so I have a bit of leg room if there are any unforeseen extra costs. North is at the top of the screen, which puts the alfresco to the South - good because the S.E. trade winds will cool things down in the summer and that is where my "backyard" will be. I have already moved the laundry into the garage to maximize space, moved the master bed down a few metres, turning the ensuite and WIR 90 degrees, added 200mm onto Bed 2 and 3 and added a secondary entry/exit to the north of the property so it can be accessible from both street frontages. Are there further alterations you would look at making? Bearing in mind I don't have a great deal of leg room to move budget-wise. A soil test was taken for the vacant land by the previous owner - Class S so won't be any extra costs for slab - will probably engineer slab based on Class M regardless given it is included in the price. Many thanks! Inclusions etc in the next post. Dale - Building Newbie Proserpine, QLD Re: Building House in Proserpine, QLD - a newbie! 2Sep 27, 2014 5:54 pm Inclusions/Specs: • We provide you with a 6 year Structural Warranty and a 6 Month Maintenance period. • Connection of services, water, sewer, electricity • Thithor Termite Protection will be installed on your property in accordance with Australia Standard AS3660 Termite Management Part 1: New Building work and the Building Code of Australia. Thithor was designed and tested in Australia to suit or conditions and protect against the voracious ter-mites native to Australia. • You will be given a Home Owners Guide for Ter-mite Management to help in the Prevention of any future issues. • Treated Timber Throughout • 2 x external brass taps • 90mm stormwater to roadside curb. • Continuous Flow Gas Hot water system • Conventional Slab based on a M Classed Site • Based on a flat block • Full Perimeter and penetration termite barriers installed • Solid Filled block work • 10mm cement render on all external walls • Medium Range or Light, Colour Bond Roofing • Colour bond fascia and gutter • 90mm round PVC downpipes • Air Cell insulation • Colours—chosen by you during your Consultation with the Interior Designer • 3 coats internally • Doors and Trim in gloss enamel to match wall colour • 2 coats external—Med Range colour to light colour Timber Trusses • T2 Termite Treated Timber as per Trusses Engineering • 20 degree hip roof design Wall Framing • 2600 ceiling height • Termite Treated Pine framing • Cyclone bolts and rods as per Engineers requirements Architraves 66 x 11 stepped profile Skirtings 66 x 11 stepped profile Internal Lining • 10mm Gyprock to walls throughout • 70mm cove cornice throughout including cupboards • Villa Board to bathrooms and ensuite • Water resistant board to Laundry • Internal doors—standard ready coat • Privacy lock to W.C/Ensuite/Bathroom (will add privacy lock to garage door into house) • Robes—Hat shelf & hanging rail 600mm wide box unit including draws CERAMIC TILING • Quality Builders Range of Ceramic Tiling • Main floor area—Entry / Meals / Family / Kitchen / Hallways / Patio Areas • Wet Areas—Laundry / Bathrooms / Ensuite • 2000mm high tiling to shower recess • 600mm high to kitchen splashback • 200mm above laundry tub • 400mm above bath • 200mm above vanities • Skirting tiles to W.C/Laundry/Ensuite/Bathroom CARPETS • High Quality carpets from our Standard Moloko Homes Range WINDOWS • Powder coated aluminium (Black frames- grey glass) • Grey Tinted glazing throughout • Obscure glass to bathroom/Ensuite/W.C • Insect screens throughout TAPWARE • Nobili Balance Basin Mixer 4* Wels • Nobili Balance Shower Mixer • Nikles Pure Wall Shower BATHROOM ACCESORIES • Genx Bath Outlet • Genx Toilet Roll Holder • Genx Single Towel Rail ( 2 per bathroom ) • Designer Vanity Unit with Stone Bench top • Domain Vanity Basin with overflow or Porcher Cygnet Semi Recessed Vanity Basin with overflow • Porcher Quatre Close Coupled Toilet Suite with Soft Close Seat • Base Acrylic Bath • Toughened shower screens • Silver framed mirrors length of vanity x 900 high • White Vinyl sliders to Built in Robes • Stone Bench tops—Essa Stone Standard Range only • Ceramic Tiles 600mm high to kitchen splashback • Soft Closing Draws and Doors • Laminated cupboards and doors • Chrome or polished nickel handles SINK AND TAPWARE • AFA Flow Undermount Sink • Teknobilli T7 300 Sink Mixer 4* Wels APPLIANCES • Westinghouse 600mm Fan Forced Oven • Westinghouse 600mm Gas Cooktop • Westinghouse 600mm Slideout Recirculating Rangehood • Dishlex Stainless Steel dishwasher • Stainless Steel laundry Drop in Tub. • Base Sink Mixer 4* Wels • Underground power supply ( up to 20 meters) • Generous Power point allowance - 1 x Power Point to each Bedroom - 2 x Point Points in Master Bedroom • LED Down lights throughout - 2 x Down lights to each Bedroom • Generous Double power points throughout other rooms • Ceiling fans to all bedrooms and living areas. • Exhaust fans to showers • 2 x TV outlets • Air conditioning to living area and Master bedroom. • Smoke alarms as per council requirements • Earth leakage circuit breaker • 2200 x 4800 panel lift door with 2 remotes • Statesman DR 270, with grey tinted glass • TV Antenna • Standard Grey concrete driveway • Wall mount clothes line • Full internal and external commercial quality clean upon completion • Removal of all building rubble from site upon completion Dale - Building Newbie Proserpine, QLD Re: Building House in Proserpine, QLD - a newbie! 3Dec 13, 2014 8:44 pm Hiya! I'm also a singleton building- but in Brisbane- hang on for a bumpy ride! Haha. And I am totally in line with the one income budget also. How is it progressing so far?? Modified Killara25 Brisbane, QLD Re: Building House in Proserpine, QLD - a newbie! 4Dec 14, 2014 10:24 am CocoBrisbane Hiya! I'm also a singleton building- but in Brisbane- hang on for a bumpy ride! Haha. And I am totally in line with the one income budget also. How is it progressing so far?? Yeah, it is a bumpy ride, but must be done, haha. It is coming along well, I am up to the framing stage, but that wont happen until after Christmas. They finished all the blockwork though!! I should start my own build thread, will get there one day! Haha. Where are you up to with your build?? Dale - Building Newbie Proserpine, QLD Re: Building House in Proserpine, QLD - a newbie! 5Dec 14, 2014 1:24 pm At the final leg of administration- signing off the final drawings this week then hopefully slab and siteworks starting Jan 5. Has been a real stuggle, though I hope that the build will be cruisy from early next year. It's annoying about the xmas break but hopefully will be a fast build after with everyone being refreshed- and more money to save on ridiculous variation costs :-p Modified Killara25 Brisbane, QLD Re: Building House in Proserpine, QLD - a newbie! 6Dec 14, 2014 5:32 pm CocoBrisbane At the final leg of administration- signing off the final drawings this week then hopefully slab and siteworks starting Jan 5. Has been a real stuggle, though I hope that the build will be cruisy from early next year. It's annoying about the xmas break but hopefully will be a fast build after with everyone being refreshed- and more money to save on ridiculous variation costs :-p Excellent! Congrats! Make sure you post up your plans etc when finalised! Yes, it will be difficult over the Christmas break driving past the block with nothing happening, but they need their holidays! I am very close to budget, so not much wriggle room for variations Luckily I have a builder, electrician and landscaper as friends, so can do lots after handover for very cheap Dale - Building Newbie Proserpine, QLD Re: Building House in Proserpine, QLD - a newbie! 7Dec 14, 2014 5:40 pm I am doing so many things post handover too- although I don't know anyone so will have to line up loads of dates with tradies lol. I have driveway, letterbox, clothesline, decking, crimsafe or alternative competitor, plantation shutters, electrical, render, flooring...sure there is a lot more. Too many to think about! I know that I have gone over my budget by a fair whack so my life will likely consist of noodles after handover lol. Modified Killara25 Brisbane, QLD Re: Building House in Proserpine, QLD - a newbie! 8Dec 14, 2014 6:57 pm CocoBrisbane I am doing so many things post handover too- although I don't know anyone so will have to line up loads of dates with tradies lol. I have driveway, letterbox, clothesline, decking, crimsafe or alternative competitor, plantation shutters, electrical, render, flooring...sure there is a lot more. Too many to think about! I know that I have gone over my budget by a fair whack so my life will likely consist of noodles after handover lol. Good way to save money by doing things after handover, although I know some people who did lots after handover and wished that they spent the extra 10k getting it done as part of build after the stress of organising tradies! If it wasnt for noodles I would have starved at university, haha! My house will consist of a bed and fridge and not much else for the first few months at least!! Dale - Building Newbie Proserpine, QLD Re: Building House in Proserpine, QLD - a newbie! 9Dec 14, 2014 7:09 pm Lol Dale same as me- just literally my bedroom furniture though. I am anticipating some giftcards for xmas for homewares though- luckily! I used to look up shoes online but now I find myself focused on taps etc- very different! Modified Killara25 Brisbane, QLD Re: Building House in Proserpine, QLD - a newbie! 10Dec 14, 2014 7:24 pm CocoBrisbane Lol Dale same as me- just literally my bedroom furniture though. I am anticipating some giftcards for xmas for homewares though- luckily! I used to look up shoes online but now I find myself focused on taps etc- very different! I am hoping for friends and family to chip in some things like kettle, toaster, etc but of course I wont expect them to give me anything (it would be nice though!!). Mum wants to buy my bed and fridge, so I will probably spend my money on getting the alfresco up and running. Being a guy, we love our outdoor areas with bbq, pool table, tv and all that stuff! Some gift cards would be a perfect present - able to buy what suits your tastes! Otherwise you end with some hideous looking stuff that people buy for you :p At 26 I had to make the move to get my own house, I just keep telling myself that the debt will be worth it I am going to go out on a limb and assume you're a female given the shoe shopping? Could be putting my shoe in my mouth by assuming that, haha! Dale - Building Newbie Proserpine, QLD Re: Building House in Proserpine, QLD - a newbie! 11Dec 14, 2014 7:43 pm Really like your plans dalemengel, well done! Nice living and patio area We are about to start as well. The paperwork is getting done right now and we do have the colour selection tomorrow. Good luck with your build! Live Love Lough Building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=74918 Building blog: http://uniquebyeva.com.au/ourhome/ Our food forest blog: http://www.foodforestcookery.com Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5034 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8731 Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4252 |
