Browse Forums Building A New House 1 Sep 23, 2014 9:15 pm Hi, Just chasing opinions from people regarding infill above sliding doors. Our builder does do a brick infill above doors/windows, however 3 out of 4 of our sliding doors have ended up with a very large gap above them, which they have covered with aluminium infill, i don't believe this is acceptable, but builder is not keen on repairing. What we were expecting Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What other 3 doors are like Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As you can see almost a full brick course gap above the door. Anyone else had similar issues? Sheridan 38 @ Gainsborough Greens, Pimpama QLD Re: Infill above sliding doors. 2Oct 08, 2014 11:03 pm Hi uzz31, There is a steel lintel holding the brickwork up you know, so it seems that they set it one course too high... so it would be very costly to repair. It would be difficult to win in VCAT by the way but a slim chance, particularly if the elevations show no infill and no gap. Continual pressure might also work... but the mortar colour match might not be good. Building, who would do such a thing? Good luck, Leonardo_23 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5243 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10934 we have a standard size and often we have a lot of variety to choose 0 3579 |
