Browse Forums Building A New House 1 Sep 16, 2014 12:58 pm Running around with the different builders. I am thinking, is there any advantages of building a 12.5m House on a 14m wide land. or put it like, what are the disadvantages of building one? Hope some of you guys have had the same scenario and could share your experience. Cheers ! Re: Building a 12.5m House on a 14m Lot 2Sep 16, 2014 1:21 pm Hi macky1012, I am a designer, so the first thing I look for is adequate sunshine opportunities - meaning north light to outdoor areas and living rooms. That is probably the most important thing. A little more detail might also help hone in on the constraints of your site including fence heights north point, etc Leonardo_23 Re: Building a 12.5m House on a 14m Lot 3Sep 16, 2014 1:29 pm Check out your required building setbacks. You may find a 12.5m may be too wide for the 14m frontage. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Building a 12.5m House on a 14m Lot 4Sep 16, 2014 7:41 pm Leonardo_23 Hi macky1012, I am a designer, so the first thing I look for is adequate sunshine opportunities - meaning north light to outdoor areas and living rooms. That is probably the most important thing. A little more detail might also help hone in on the constraints of your site including fence heights north point, etc Leonardo_23 Yeah, we have this restriction of "north Facing"backyard, which i think means we cannot construc anything that would obstruct the view of the family area. Because of this, i am really getting limited selection on floor plans. thanks! Re: Building a 12.5m House on a 14m Lot 5Sep 16, 2014 7:42 pm mitchitygrub Check out your required building setbacks. You may find a 12.5m may be too wide for the 14m frontage. This is another thing, as narrower house tends to be longer.. so we are really being pushed up to the end of the backyard.. Re: Building a 12.5m House on a 14m Lot 6Sep 17, 2014 8:16 am Hi macky 1012, Our lot was 14 metres wide and we wanted sunlight to living areas. As our north side neighbours built a massive double story which overshadowed us we ended up with an L-shaped house with the back area only 5 metres wide. It did push the house deep into the lot. What you need to watch out for in that case is whether you have any easements at the back which could affect how far back you go. Also what is your mandatory front setback? If you are on highly reactive clay soil I would also be watching that you have adequate space on both sides of the house to bury service pipes a reasonable distance from the house and that you have adequate room for a concrete apron 1 metre wide around the house. We are in Melbourne so having the sunshine has made a big difference to the comfort of the house in winter. And the overall effect is a bit as if you had a courtyard house because you can see the garden from just about everywhere (apart from bathrooms and study). Are the house plans you are looking at 12.5 metres wide just at the garage or for the whole house? What sort of climate are you in? How deep is your lot? What is being built on your north side? What sort of soil do you have? How many people do you need to accommodate in the house? There are a lot of things to consider really. Ausdesign is a designer on here with a really helpful website and he may be able to give you some better advice if you send him a message. http://www.ausdesign.com.au/ Re: Building a 12.5m House on a 14m Lot 8Sep 18, 2014 7:50 am Ours was 14m by 34m with a 2 metre easement at the back and a 4 metre front setback so we had a bit more room to play with than you. One option may be to build up; this would give you a greater selection of narrower floor plans. You need to decide what is important to you and what is possible. Most houses these days seem to be built to "fill up" the front but I prefer to see a bit of garden separating houses and you need to think about whether you really want your service pipes running under your foundations or very close to them. Re: Building a 12.5m House on a 14m Lot 9Sep 23, 2014 12:32 pm Liliana Ours was 14m by 34m with a 2 metre easement at the back and a 4 metre front setback so we had a bit more room to play with than you. One option may be to build up; this would give you a greater selection of narrower floor plans. You need to decide what is important to you and what is possible. Most houses these days seem to be built to "fill up" the front but I prefer to see a bit of garden separating houses and you need to think about whether you really want your service pipes running under your foundations or very close to them. thanks liliana. i wanted a really low maintenance garde. so maybe a reasonable backyard for barbies will do. we are doing our best to get a plan that is suitable for a 14m wide hose. so right now i have 3 shorlisted. 2 for 14m and 1 for a 12.5 Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4744 You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4854 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10035 |
