Browse Forums Building A New House 1 Sep 01, 2014 11:08 pm A couple of questions for anyone who may know or any experts around here: 1. We recently got back our Geotech report from the borehole testing. It mentioned that "UTP DW ROCK" was found at 1000mm and the same at 800mm at "test site 2". I am wondering whether I will need any rock excavation. I know this will depend on many factors, but what would those factors be? The land is relatively flat with minimal cut/fill. For electrical and water services, how deep do they need to go? If they need to go further than where the rock is found, does that mean rock excavation may be required? 2. The site classification says "S Class". However, I know for a fact that the whole area (Oran Park, NSW) is salinity affected, so does this mean I still need a H Class slab? Or are they saying I might just need a S Class slab as that's what the report came back with? I ask these questions because basically, prior to our final contract signing before our site costs are firmed up, I want to make sure the builder doesn't try and rip me off with site costs. If anyone is able to decipher this information, that'll be great! I've got some pictures below of my report too. $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Geotech Report - Rock removal? 2Sep 02, 2014 6:08 am Also worth mentioning that the site is relatively flat, with a slight gentle slope towards the back right hand corner. Not sure if that will have anything to do with it. $395 Fixed Priced Landscape Plans for DA M: 0435 127 244 | W: bluegumdesign.com.au | E: info@bluegumdesign.com.au Residential | Commercial | Industrial Re: Geotech Report - Rock removal? 3Jun 13, 2015 6:11 am Rock is as in your case often found not too far below the surface. If one did 100 test holes, an absurd notion, of course, one would have a better picture. But the fact is that you have rock and no-one can tell you in advance what the costs will be. We can all be surprised. It will be worse if you cut the site because you get closer to that rock. Naturally it depends on the type of home, strip footings, slab, stumps etc. Given that the site is relatively flat, you may not have a huge problem. Good luck. Re: Geotech Report - Rock removal? 4Jun 13, 2015 9:19 am I'm always amazed that the geotechs for new homes only test a few m in from the boundaries which in some cases on larger blocks of land can be a long way from where the house will actually be built. Any engineers we've engaged to do soil testing we usually ask them to put down four bores on the corners of any house or addition we have been involved in. Stewie Re: Geotech Report - Rock removal? 5Jun 13, 2015 9:38 am Brahma Bull 2. The site classification says "S Class". However, I know for a fact that the whole area (Oran Park, NSW) is salinity affected, so does this mean I still need a H Class slab? Or are they saying I might just need a S Class slab as that's what the report came back with? Slab should still be S, but if salinity is considered to be an issue some of the typical precautions can be: Use a higher strength concrete mix Sulphate resistant cement More important that water is not added on site More cover to reinforcement. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Geotech Report - Rock removal? 6Jun 13, 2015 9:52 am Is it a single storey or double storey home, Large or small home, contour survey? Do you want to raise the slab slightly with fill and retaining or cut and fill? There are many impacting variables to consider, IMO rock breaker isnt one You will need to weigh up the cost implications with the builder...and try to negotiate...but somehow I feel your builder has the upper hand here. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi all, I have been looking at land in South Australia, that is on a slope however most of the core excavation is complete, with a flat area to place a house. The agent… 0 1411 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6710 |
