Browse Forums Building A New House Re: Building boundary 2Aug 21, 2014 8:14 pm http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Building boundary 3Aug 22, 2014 8:56 am khp3294 Can someone please tell me how close I can build to my side boundary? It varies, from council to council. I believe it's 900mm where I am. Check your local council's planning (zoning) documentation, which is likely to be online. Look for "side setback" requirements. Also, if you are building a 2 storey house, be careful. The top storey may have a larger side setback than the bottom storey (ie. the top storey may have a larger minimum distance from the boundary than the bottom storey), to stop overshadowing. You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 Hello, We are about to build and the plans show a part of the exterior wall is being built on top of a limestone retaining wall. Does this mean the retaining wall will… 0 6965 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16305 |
