FHOG - what banks will let you use as a deposit?
I used the FHOG as deposit for the house costs.
Loan through BankWest (Organised by my broker)
I managed to get a loan a few years back. Newly self employed ~ 15 months, single with minimal savings. Most banks i spoke to more or less laughed me out the door. Met with a few different brokers - some couldn't help without using parents house as collateral, however finally found one that was able to come up with an option that worked.
Thanks
http://www.aussie.com.au/mortgage-broke ... -grant.htm
There are good and bad brokers though even in the larger companies - ask around and see if you can get one on referral (an actual person not a company) and when you do let them know who referred you. When the broker knows they are getting work via a referral it can actually make a difference because if they are unable to help you it may prevent that person from referring work to them again, so it encourages them to go the extra mile or at the very least maybe give you some pointers of how you might be able to make it work in 3 or 6 months etc. EG even getting rid of a credit card with a $2k limit rather than saving for a bigger deposit can make a significant difference in how your application is viewed and your borrowing capacity.
Also are you looking at buying a block that is not yet registered? The reason I ask is that if you have enough to secure a block now and its say 12 months away from being registered, in that 12 months you could go through the preliminary admin stuff with a builder as well as save for the other 5% required for the build. Not an ideal scenario, obviously exhaust every option to have in using the FHOG as a deposit so everything is more black and white but if the land is a while away from being registered anyway you may find that some things have changed or you might have a larger deposit at that time that could reduce your LMI.
Best of luck with it.
Credit where its due though, if the broker thinks it'll be refused its best they don't lodge the application, so if you do find one that is prepared to submit it question them closely as to why they think it'll work when others think it won't. It'd be better to save for an extra 12 months and get it through first time than have numerous enquiries on your credit file that are likely to raise some questions.
I found builders loan australia who claim to be able to use fhog as upfront deposit but I think they are based in QLD, waiting to hear from them.
Maybe rules changed since you went through bankwest ST13.
1
Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be…
29/05/2023
16
That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor.
14/06/2023
3
If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with…
