Browse Forums Building A New House 1 Aug 20, 2014 1:25 pm Re: Ugly or not? 3Aug 20, 2014 2:21 pm No I don't think it is ugly... I think it does really well to mimic its surroundings... the colour of the walls emulate the tree bark and the shape of the roof copies that of the surrounding trees. My build: viewtopic.php?f=31&t=68002 Re: Ugly or not? 5Aug 20, 2014 7:39 pm Roof angle is to drop snow off it. Its obviously a design from North America/ Europe. If youre more than happy to give a passing nod to the architecture of a colder clime..................go for it. I'd be changing the pitch of the roof it would be a PAIN to heat it with ceilings of that height. Saving money on quality stuff done right firstime Our Build Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=66810&p=1094349#p1094349 Re: Ugly or not? 7Aug 20, 2014 9:41 pm MyH1Login "Assuming house is built in a similar forested location"... I think in the same context, the house is beautiful. +1 Also, as Burnsfirsttime says "the colour of the walls emulate the tree bark". I really like the grey colour, & think the choice of timber would be critical. If you plan a rectangular build like this, make sure you orientate it correctly. Following passive solar principles, with the longer walls facing north & south (& minimising western windows), will result in a more comfortable house. I wouldn't recommend a lot of skylights. North facing skylights will be hot in summer, while all skylights will leak heat in winter. Hard to see, but I assume this build has 2nd storey loft spaces. If you want loft spaces I'd recommend having narrow slit windows on the gable ends, along the roof lines (Hillcott barn, on Grand Designs, used these & is shown below). I would expect that these would be more thermally efficient than skylights, are inconspicuous, & look great when the interior is lit at night. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ edit: I've discovered your other thread. As there's no loft space, you'll have sufficient natural lighting & won't be needing skylights or slit windows. Re: Ugly or not? 8Aug 20, 2014 9:45 pm Absolutely gorgeous actually. From the inside, you'll probably want more windows though. For something not dissimilar to this, check out this blog: http://selfbuildhouse.wordpress.com http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Ugly or not? 9Aug 21, 2014 7:38 am Thanks for all the replies. Beauty is in the eye of the beholder as it is said, but I find the design in question quite pleasing, plus simple rectangles with a gable is a cost effective way to build apparently. I also have to consider resale and so more for than against is preferrable. That said this design isn’t suited to the suburbs, it needs a green space on acreage, preferably forested. Thanks for highlighting that MyH1Login and Burnsfirsttime. @Bayview, Forg, Wandin: Yes, as soon as the roof line is changed, or eaves and awnings are added, you lose the look I’d like to capture. @ddarroch: Good points about energy efficiency, I’m thinking along the same line. Thanks for the comment and link housebythewater. Fantastic view that house has. Re: Ugly or not? 10Aug 21, 2014 9:08 am the Hillcot barn ddarroch.....very nice, actually one of my favourite grand designs Re: Ugly or not? 11Aug 21, 2014 12:28 pm it looks very barn-like. In Qld you'd want a verandah or two - but I assume Huon Valley is in Tas? In which case you probably won't be spending much time sitting outside. at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61387 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6182 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 |
