Browse Forums Building A New House Re: Ugly or not? 5Aug 20, 2014 7:39 pm Saving money on quality stuff done right firstime Our Build Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=66810&p=1094349#p1094349 Re: Ugly or not? 8Aug 20, 2014 9:45 pm http://www.housebythewater.wordpress.com From blank block to new home in Mandurah, Western Australia. viewtopic.php?f=31&t=65564 Re: Ugly or not? 11Aug 21, 2014 12:28 pm it looks very barn-like. In Qld you'd want a verandah or two - but I assume Huon Valley is in Tas? In which case you probably won't be spending much time sitting outside. at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61375 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6177 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 |
