Browse Forums Building A New House 1 Aug 15, 2014 11:59 pm I'm stuck on the options on timber flooring and could definitely do with some solid advice from those that know! I would like the darker grey tinge/tone colouring so understand that I cannot get solid timber. Trees apparently don't grow in grey colour (said with sarcasm by a salesman) I really don't want to go with laminate flooring as it seems the cheaper way to go and hasnt been in the running.. yet.. So, in researching, I came across engineered floating timber flooring - link provided on my colour choice (but still open to suggestions). http://www.lionkingflooring.com.au/prod ... ntagegrey/ Would appreciate advice on the pros and cons on engineered timber floating flooring - (to include durability, colour choice range, Sydney suppliers at a good price) Re: Timber Flooring options - so confused 2Aug 26, 2014 10:31 am Picking up your yellow pages would be the most practical way to go about this. A flooring specialist would answer all of your questions. But to summarise the difference between engineered and solid timber. Engineered is much cheaper, just install and nothing else, comes in a myriad of finishes. Biggest downside, doesn't feel solid and flexes and creeks when you walk on it. Can only be sanded 2-3 times in it's life. Solid timber, expensive, once laid needs to be sanded and stained/coated. Solid as solid can be. Can be resanded many many times. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15919 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6468 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8317 |
