Browse Forums Building A New House 1 Aug 08, 2014 5:16 pm Hi, I just started looking for a vacant land and need some of your help. I just visited 3 land and got contour plan for the these. would you please help me to understand which one would be great to go with as I believe if it's more than 1 m change in ur slope it would cost you high a lot. Re: Contour plan Advice neede 3Aug 09, 2014 4:15 am You need to use image hosting service such as http://www.photobucket.com Then once you upload the image there, get the direct link to it, and post it here with the embed code such as [*img] http://www.theimagewebsite.com/image.jpg [*/img] NOTE: remove the * when you actually post it My first build journey here https://forum.homeone.com.au/viewtopic.php?f=31&t=71028 Re: Contour plan Advice neede 4Aug 09, 2014 10:10 am HI All, I have added few image here . http://s48.photobucket.com/user/tobhagirath/slideshow/ if you could help me to undestand that does this contour plan is ok or may be any extra cost will be involved in that to level the surface Re: Contour plan Advice neede 5Aug 09, 2014 11:53 am It's hard to say without knowing what you want to build but as a rough guide: In each block you look to have about 1/2m of cross fall and minimal fall along the length of the block. These blocks will require some cut and fill to give a level construction pad but shouldn't be that expensive. (perhaps $2-3,000) If you want to build right up to the edge or have a driveway on the edge a low retaining wall may also be needed The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Contour plan Advice neede 6Aug 11, 2014 11:02 am ok thanks for the info i believe it would be 4m to 4.5m space needs to leave for the drive way in front and for backyard as well. Re: Contour plan Advice neede 7Aug 11, 2014 12:53 pm ![]() i believe it would be 4m to 4.5m space needs to leave for the drive way in front and for backyard as well. There are certain setbacks that will apply. You will find more information at this link http://www.anewhouse.com.au/2013/02/setbacks/. Another thing to check is if there are any sewerage or drainage easements which typically affect the back 3m of a block. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Old Home Restoration / Renovation Your lintel will need to rest on something and it is usually at least 250 mm of brick, it doesn't seem there is enough space on the right side for it, as the opening is… 3 2509 Hi, I am new to the grp. I am building new house on land size of 326 sqm with frontage of 10.7. Attached is the draft plan, looking for feedback and inputs from the… 0 2985 The neighboring lot has a 0.9m maintenance easement. So hopefully a 3-4m distance is enough to bring in some NE sunlight? Would be a bonus if they decide to build just a… 2 1660 |
