I would also make bed 2 window smaller and perhaps eliminate the wc window altogether to help reduce afternoon heat build up.
good luck
Hi Asha,
Thanks for your reply.
Browse Forums Building A New House Re: Selecting home design for a north facing block 61Aug 19, 2014 5:23 pm ![]() Alishine I would definitely flip it so living areas are east facing so they get morning sun rather than arvo sun. I would also make bed 2 window smaller and perhaps eliminate the wc window altogether to help reduce afternoon heat build up. good luck Hi Asha, Thanks for your reply. ![]() Re: Selecting home design for a north facing block 62Aug 20, 2014 10:02 am I disagree that a custom house will cost significantly more than a standard design. Often, customizing a standard design will end up costing significantly more than starting from scratch. ive done a quick hack on how i'd do it... The main thing I'd be looking at (that noone else has mentioned yet) is how to passively cool the house. If you ensure that your design will allow cross ventillation (do you know which way your prevaliling winds are, and can you use them?) or redesign to incorporate stack ventilation. If you're not prepared to go back to the start, and based on the limitations you have in terms of block width and budget, I'd suggest considering a few other tricks to beat the heat - although none of them will help with heating it during winter. Brise Soleil and/or deciduous trees will be the main factor in helping shade the western side of your house. Consider how to put a wet garden on your western side - the passive cooling benefits can be considerable. Tinting and Low-E glass will also make a large difference, as will good wall insulation. Shutters outside the house are another alternative, but obviously they will mean no light at all during the evening. This might not be a problem on bedrooms, more likely to be a problem with living areas. Consider an intelligent roof ventilation system. There are a couple on the market, but its also possible to build your own relatively cheaply. http://www.odyssey.com.au is what we are installing in our new build If you haven't already, go buy yourself a subscription to Sanctuary (http://www.ata.org.au) Which includes access to all the back issues of the mag. You will learn more in a short time from reading that than most other sources (in my experience) Re: Selecting home design for a north facing block 64Aug 20, 2014 6:53 pm ![]() I disagree that a custom house will cost significantly more than a standard design. Often, customizing a standard design will end up costing significantly more than starting from scratch. ive done a quick hack on how i'd do it... http://i1364.photobucket.com/albums/r730/peter_stevenson1/SpamsDesign_zps05ab2bc6.jpg The main thing I'd be looking at (that noone else has mentioned yet) is how to passively cool the house. If you ensure that your design will allow cross ventillation (do you know which way your prevaliling winds are, and can you use them?) or redesign to incorporate stack ventilation. If you're not prepared to go back to the start, and based on the limitations you have in terms of block width and budget, I'd suggest considering a few other tricks to beat the heat - although none of them will help with heating it during winter. Brise Soleil and/or deciduous trees will be the main factor in helping shade the western side of your house. Consider how to put a wet garden on your western side - the passive cooling benefits can be considerable. Tinting and Low-E glass will also make a large difference, as will good wall insulation. Shutters outside the house are another alternative, but obviously they will mean no light at all during the evening. This might not be a problem on bedrooms, more likely to be a problem with living areas. Consider an intelligent roof ventilation system. There are a couple on the market, but its also possible to build your own relatively cheaply. http://www.odyssey.com.au is what we are installing in our new build If you haven't already, go buy yourself a subscription to Sanctuary (http://www.ata.org.au) Which includes access to all the back issues of the mag. You will learn more in a short time from reading that than most other sources (in my experience) Thanks uncyspam! Can you tell me the cost for roof ventilation system (odyssey one) and also when you say a wet garden, what exactly is that ![]() Thanks. Re: Selecting home design for a north facing block 65Aug 21, 2014 4:40 pm I also have a north facing block and went with the 15m Wide Chateau. I think it will work perfect. When I walked into the display home for the first time after looking through hundreds of other displays (most with the same boring layout) I knew this was the home for me. Currently waiting on final contracts and plans. I have made a few changes over the standard plan. I will start a build thread once it gets started in a few months. Re: Selecting home design for a north facing block 66Aug 21, 2014 11:21 pm ![]() I also have a north facing block and went with the 15m Wide Chateau. I think it will work perfect. When I walked into the display home for the first time after looking through hundreds of other displays (most with the same boring layout) I knew this was the home for me. Currently waiting on final contracts and plans. I have made a few changes over the standard plan. I will start a build thread once it gets started in a few months. have you posted your design ? i would love to see it . or else would appreciate if you can post the website link for chateau...thanks Re: Selecting home design for a north facing block 67Aug 22, 2014 1:49 am http://www.synergy.net.au/docs/energy_e ... t_home.pdf BTW nothing beats a 15KW RC dykin Unit with a 5 KW solar unit ![]() The warning is on the sticker on the door too. Second the aluminium powdercoat 6 2452 Be very careful of copyright infringement when posting Floor plans, elevations etc, Flip the internal stairs, get a northern roof light well down into the F/M/K 3D Bim… 4 2960 ![]() Hi, I'm looking for opinions and advice on living room windows. Essentially we have a north facing block, and the house layout we have decided… 0 3249 ![]() |
