Browse Forums Building A New House 1 Aug 04, 2014 11:47 am Hi guys, First post I'm looking at buying a property in a Brisbane suburb that is in a character zone. I'm not too worried about getting the DA to demolish the house but I am getting concerned about the difficulty of building a new house there. It would be classified as a small lot at 10 x 40m. Could I use a project builder or would I be looking at a designer/architect? Budget is a concern so I would love any experience you guys can pass on. Thanks Re: Brisbane Character zone 405m block new build 2Aug 04, 2014 12:58 pm If there is a pre 1946 house on your block you may strike some trouble getting a DA to demolish it. I'm currently building on a 10x50m block in Norman Park with a custom builder. Couldn't be happier with the whole process. I'd suggest talking to custom builders. They will be able to tailor the design and inclusions to suit your budget. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Brisbane Character zone 405m block new build 3Aug 04, 2014 1:05 pm Thanks, i will look into that. I have gotten some expert (expensive) advice that suggests the DA will be no problem based n the house itself. Build budget would be up to 400k. Re: Brisbane Character zone 405m block new build 4Aug 04, 2014 1:10 pm 400k is a good budget to work from. Should get you a decent home. Where are you looking at building? Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Brisbane Character zone 405m block new build 5Aug 04, 2014 1:16 pm We are looking at a house in Grange Re: Brisbane Character zone 405m block new build 6Aug 04, 2014 2:22 pm Great area. I'll send you a couple of suggestions - builders I dealt with when going through the process. Check your PM's. Building in Brisbane with Vernal-Corner & Buchanan https://forum.homeone.com.au/viewtopic.php?f=31&t=73636 Re: Brisbane Character zone 405m block new build 8Nov 22, 2014 4:25 am Just on a side note, have you checked the relevant BCC codes that apply? The council website is great (not just for paying parking fines) - it has the actual codes for demolition precinct, character, small lot, as well as an interactive map that shows what codes and other overlays your house falls under. I'm sure your expert is on top of it all - I wanted the peace-of-mind myself, and was empowered when I did my eon research and got educated. So when an expert talked some of the lingo, I didn't feel like a complete idiot. Best of luck with it - The Grange is a beautiful part of Brisbane! Home is where the lot is Construction commenced 3rd November 2014 Re: Brisbane Character zone 405m block new build 9Nov 26, 2014 10:11 am Thanks for that willpower. Just as an update, we have bought an old house in Alderley to knock down & build new. It is a much bigger block and has none of the restrictions. Demolition is due for earl December & build in the new year. Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 33655 Hi , I'm currently going through this now within the Whitehorse council which has a similar set of restrictions. We're having to make compromises with our floor plan due… 3 30668 Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 356756 |
