Browse Forums Building A New House 1 Jul 28, 2014 4:19 pm Hi Just a quick question about cold water tap for fridge. Where is the actual tap you turn on and off put, is it like a toilet tap and just sits behind the fridge? Thanks Re: Cold water tap for fridge 4Jul 28, 2014 4:51 pm I've also heard a good suggestion to put the tap in a cupboard next to or above the fridge recess if you can. That way you don't have to pull the fridge out to turn the tap off or change the water filter if it's an inline water filter. Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1664 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12647 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2588 |
