Browse Forums Building A New House 1 Jun 01, 2008 9:47 pm Hi Guys
Went to have a look at the have completed frame today. It had been raining in the morning and I noticed some water pooling on the slab. It was about 4 metres from the entrance and included part of the kitchen and hall. An area about 4 metres square. I estimate it was about 5mm in deepth in the middle. It was deep enough for the kids to jump up and down in the puddle to get wet. My concern is would this effect the level of laying timber flooring? Am I being to fussy?, and is this acceptable tolerence in concrete slabs? Your advice once again is much appreciated. Thanks Will we ever get there? Re: Water pooling on slab 2Jun 01, 2008 10:16 pm On the second page of post below there's a bit on pondng on slabs and tolerances an issue which Forumite Belgrave bought up...hope it helps.
https://forum.homeone.com.au/viewtopic.p ... e&start=15 mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Water pooling on slab 3Jun 02, 2008 9:22 pm Thanks Mike. The links have been very helpful. Seems to be within normal tolerence.
Too late now anyway. Frames up and the builders a steaming along. Will we ever get there? This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28319 Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 6948 If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12109 |
