Browse Forums Building A New House 1 Jul 21, 2014 10:10 pm Hello All
This is my first post. i have been re-reading very informative posts from knowledgeable people, and I wanted to ask a question here in hopes that I can learn even more. I'm looking to build a 225sqmt home on a 448sqmt piece of land in Ipswich (QLD). I received a "tender" from a builder and I was wondering if it was possible for someone to review the tender and provide any feedback. "You're paying too much" "Good deal! Go for it " "you forgot to add this* this* and this*" https://www.dropbox.com/s/9u2fqcwry0xnr ... te1.pdf?m= [PDF 77.5KB] Alternate Link If Above doesn't work for you: https://drive.google.com/file/d/0B-u5_M ... sp=sharing Re: Quote from a builder - suggestions 2Jul 23, 2014 12:46 pm Hi there. Just wondering if anyone had 5 minutes to have a peek at the above PDF and give any feedback? Re: Quote from a builder - suggestions 6Jul 23, 2014 1:42 pm I read it and it seems really light on the details. Ours went to tender and it was a huge document detailing heaps of things - even now - 1 yr later I'm having trouble with our builder and out docs as they are trying to tell me our arched window - among all the other windows is actually a tin/ aluminium window and if we want it to be glass that will be another $800 thanks. Do everything in writing BEFORE you sign anything is my advice. Ultimate Homes PERTH '13 Dec Council App '14 Jun Slab '15 Jun Lockup Dec PCI '16 Jan Feb PCI 9 wks ago - still NOT in viewtopic.php?f=31&t=80759 Re: Quote from a builder - suggestions 7Jul 23, 2014 1:50 pm are you supplying your own rainwater tank , i just had a quick look and will have another look again after lunch Re: Quote from a builder - suggestions 8Jul 23, 2014 2:14 pm Dropbox: try a different web browser Rainwater tank: this isn't a requirement in QLD (anymore) Re: Quote from a builder - suggestions 9Jul 24, 2014 6:41 am i also suggest get everything in detail i had several pages and still there were things needed to be added and amended . i would not sign anything until every detail is explained and you are satisfied. i see gaps where they could add more costs to the price. some things seem reasonable as the cermanic and flooring. but site costs i would want them to be really spot on as it could cost you thousands more. are there anything you would like that you have not added to tender as you may as well get them to cost and before you sign if too much delete. this is only my opinion after a quick look through i may have missed reread things etc. but go over your tender with a fine tooth comb before signing anything read and read again to be satisfied. Re: Quote from a builder - suggestions 10Jul 24, 2014 6:48 am That's a terrible way of presenting the included specifications. But at roughly $10k a sq I wouldn't expect much more than std display home inclusions. Are you paying too much? Well if that's going to include all site costs I'd probably say no. Just go through the detail Re: Quote from a builder - suggestions 12Jul 24, 2014 8:48 am Thanks for the advice Stewie. I've just tried that and there is no scroll bar. There is a blue download button at the top which goes nowhere when you click on it. I'm using Mozilla on a PC so I might try Internet Explorer. Re: Quote from a builder - suggestions 13Jul 24, 2014 10:00 am Sorry about the link guys. I've posted a new link here, and in the first post too. https://drive.google.com/file/d/0B-u5_M ... sp=sharing Re: Quote from a builder - suggestions 14Jul 24, 2014 7:06 pm Be wary of Stylemaster "free" tenders. I originally was going to be building with them - my free tender was quite a bit off in terms of cost compared to the contract cost. Then my tender was $10k less than my contract yet again. I pulled the plug at this time and went elsewhere (which i am very happy that i did). Some of the items are priced alright. The zero lot slab upgrade seems too cheap - mine was close to $3k for zero lot boundary on a 224sqm house (not the GTL225). Consider doing your own turf or getting someone in after. $1500 seems like a lot. Go with the cheapest electrical option they offer and get an electrician in after build - it will be significantly cheaper than one of their packages. The rest is pretty standard stuff for stylemaster. You should get a better quote once you pay the $1500~, but yes your free tender is pretty bad. My free tender looked a lot better. Personally i would be worried if my tender looked like this, but i am going to guess it was not originally a PDF thus looks odd. Are you dead set on this house? Do you -love- it? Make sure you shop around and do plenty of searching to make sure you are happy with your choice. There are other builders, whom i would rate higher than Stylemaster, at similar costs. If you love this design, then by all means continue with Stylemaster. Make sure everything you ask for is documented in the contract or on the plans. Do talk with the sales agent if you think something is too expensive. They are willing to 'deal' with regards to price. If budget is an issue, look for a house that is no wider than 12m. You won't need to build zero lot then, and will save the few thousand (and you now have two ways to get around the side of your house). My Noosa 23 Build - viewtopic.php?f=31&t=72782 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20890 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14304 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12358 |
