Browse Forums Building A New House Re: Cost of retaining wall in Full split level 3Jul 07, 2014 3:01 pm Beetaloo If the ground is stable, i.e. shale or rock, then the least cost solution is not to use a retaining wall, but batter the slope back at the change of level. If you have done a soil test, your civil engineer should be able to advise what the maximum angle of the cut can be. Another option may be to have say a 1 meter high retaining wall and then batter back from this point. Thanks for the suggestion. The cut and fill was used to make a flat area. the geotech report says the land is P classified but they did bore hole on the flat surface. The split level I am looking is like, double storey from the front and single from first level. Move your linen into laundry and access laundry from your present linen space 1 7985 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5108 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9887 |
