Browse Forums Building A New House 1 Jul 04, 2014 4:21 pm Hi all, Could anyone explain the front setback for me in my situation? I'm building a single story house in South Eastern suburb in a newly developed area. In the developer covenants, it states like this: ' The face of the dwelling must be setback at least 4m from the primary frontage and the garage on each lot must be setback at least 5m from the primary frontage' 'Exception to front setbacks: covered roof elements such as porticos are permitted to encroach with the front setback by up to 1m.' But in the plan of subdivision, it shows that the 5m for the front setback and 3m for the rear setback. So my question is how many metres is for the front setback? Is it 4m or 5m? Also, my builder says that for roof height of more than 3.6m, I can't encroach the portico, is it true? Re: Minimum front setback 3Jul 04, 2014 4:38 pm Is this a South Eastern suburb of Johannesburg? It might help to say which council you're in (and which state) ... there are people 'round here who are eerily knowledgeable on such specifics! Hmm, also land-size might have an effect on regs where you are. Re: Minimum front setback 4Jul 04, 2014 4:45 pm B STAR I dont understand why a plan of subdivision would show set backs. I believe sometimes they may show a building envelope. Can u please post a picture of the subdivision plan. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think it maybe a building envelop as you said. Sorry that I'm quite illiterate in this issue. Re: Minimum front setback 5Jul 04, 2014 4:46 pm Forg Is this a South Eastern suburb of Johannesburg? It might help to say which council you're in (and which state) ... there are people 'round here who are eerily knowledgeable on such specifics! Hmm, also land-size might have an effect on regs where you are. Sorry that I forgot to say it's in Melbourne. The land size is 14m x 33m. Re: Minimum front setback 6Jul 04, 2014 5:01 pm Call your local council, setback will vary on local government area and estate caveats............... Saving money on quality stuff done right firstime Our Build Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=66810&p=1094349#p1094349 Re: Minimum front setback 7Jul 04, 2014 5:14 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Excuse the highlighted areas. Thats just me trying to work out my fencing! It would be very similar to how ours is set out. We have pretty much the same estate guideline. We also have a 3m at the rear of ours which shows our building envelope. Our main house is 4m from the footpath and our garage is 5.6m from footpath. Hope this helps! Second Build, this time with Carlisle 2016, can't wait! Beckham: viewtopic.php?f=31&t=67280 Canterbury: viewtopic.php?f=31&t=81175 Re: Minimum front setback 8Jul 11, 2014 4:26 pm PEARZ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Excuse the highlighted areas. Thats just me trying to work out my fencing! It would be very similar to how ours is set out. We have pretty much the same estate guideline. We also have a 3m at the rear of ours which shows our building envelope. Our main house is 4m from the footpath and our garage is 5.6m from footpath. Hope this helps! So your estate guideline says 4m front setback and 5m setback in the building envelope? Re: Minimum front setback 9Jul 11, 2014 7:20 pm It basically means that the front of the "main" part of the house has to be a minimum of 4 metres back from the boundary. The garage has to be set back 5m so if your house is at the 4m then the garage needs to be staggered back. If you have a front portico or similar, it can be forward of the main part of the house by up to 1m. Apart from the distances this is pretty much the same as the rules in my estate in Western Sydney. You'll probably also find that your house will need to be in line with your neighbours. Re: Minimum front setback 10Jul 16, 2014 2:10 pm Matt1 It basically means that the front of the "main" part of the house has to be a minimum of 4 metres back from the boundary. The garage has to be set back 5m so if your house is at the 4m then the garage needs to be staggered back. If you have a front portico or similar, it can be forward of the main part of the house by up to 1m. Apart from the distances this is pretty much the same as the rules in my estate in Western Sydney. You'll probably also find that your house will need to be in line with your neighbours. Thanks for the advice. But the thing is while the MCP says the setback is 4m, the building envelop shows 5m setback from the front, so I wonder whether it'll be 4m or 5m? Sorry that I am very confused now Re: Minimum front setback 11Jul 16, 2014 2:24 pm It seems to be a conflict in the information your developer has issued you with, you will only get the correct answer by asking them. My build: viewtopic.php?f=31&t=68002 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15767 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3665 |
