Browse Forums Building A New House Re: Brick or Hebel on P class soil 2Jun 28, 2014 3:07 pm My understanding is that the type of material used for walls is not impacted by the soil type. The foundations are the most critical for the soil type and the engineer will recommend specifications. Hebel is cheaper than bricks and is better for insulation. It is also quick to install. Good if you are planning to render your facade. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13063 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5347 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5181 |
