Browse Forums Building A New House 1 Jun 23, 2014 3:45 pm Hi, Got the results from the 2nd soil test which says my land is now Class P where it was previously classified as H2. The builder will now need to provide a PH2 slab. Ive got no issues with that, but what i find strange is that on the initial engineering drawings there was 25 concrete piers to the rear half of the house, but on the revised and final drawings there is only 6 concrete piers to the rear of the house. Is it possible to have a stronger slab with less piers??? Re: 2nd soil test, Worst Soil but less piers? 2Jun 23, 2014 4:53 pm It entirely depends on the slab design. Beams may have been strengthened to require support less often. I presume you haven't changed your building materials (ie brick to some light weight cladding, conc tile to sheet steel)??? It's impossible to say without seeing it all. Without anything obvious I'd ring the engineer and ask. Re: 2nd soil test, Worst Soil but less piers? 3Jun 23, 2014 7:01 pm Hi we had H1 class and are building single story. Is yours single or double? at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61460 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37613 Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 13042 |
