Browse Forums Building A New House 1 Jun 15, 2014 9:55 am Hi, I am going to build a house in Hurstville, the house is one storey brick veneer construction. The foundation is concrete with reinforced bars. The questions here is how thick the concrete should be. Thank you for your help. Peter Re: how thick a concrete foundation should be 2Jun 15, 2014 10:01 am Have you done soil test on your block of land ? You need to get those soil tests across to an engineer to do up plans for your slab. They will tell you how thick your slab should be. I think Waffle pod slab needs to have the concrete 100mm thick above the pods, at least in the garage area. Probably better to discuss this topic in the Paving and Concreting sub forum, as this thread will get lost in the building a new house sub forum. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: how thick a concrete foundation should be 4Jun 18, 2014 9:01 am as bpratt says it will depend on your soil type i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 15980 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20890 |
