Browse Forums Building A New House Re: Building with Wisdom Homes 6781Jul 24, 2017 3:40 pm ozmonkeyoy - What is the color of your cabinets? I believe you are going for spotted gum floors, right on trend there! We are thinking of grey porcelain floors, which is making it hard for us to decide / go for dark cabinetries. Building with Wisdom Homes 6782Jul 24, 2017 5:11 pm aaron2008 @ozmonkeyoy - What is the color of your cabinets? I believe you are going for spotted gum floors, right on trend there! We are thinking of grey porcelain floors, which is making it hard for us to decide / go for dark cabinetries. Hi Aaron, We have grey tiles (standard range) with the darker upper cabinets (called domain I think?) Hope that helps! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Majestic 40 - wisdom homes Re: Building with Wisdom Homes 6783Jul 24, 2017 5:55 pm MandM+4 ozmonkeyoy MandM+4 Pool went in the ground on Tuesday and then all the plumbing, set up for the concrete bond beam so not quite finished yet. To NP's credit they would have done the bond beam at the end of this week but we are still waiting for our bank to pay them so fair dos. We kept some of the fill to use in our backyard, do you know if W will let us keep it there if it's outside of the slab peg out? I've said to hubby I don't think they will, hoping if he gets in there with a machine and spreads it around that will be ok... Building Monte Carlo 40- Wisdom homes Fair enough re pool. Hopefully looks good (although I'm sure still rough at the moment), but at least you get to see the size of it on your lot. You won't get the exact picture though til its all done with the house also there. If the spoil is outside of the your scrape and cut zone that W will do, then I see no reason why they will touch it. I would ensure that its as far away as possible to the pegged area and also tell W that you want the fill left there. Will there be leftover fill from the cut/scrape that W will do? I know on ours (and land is very flat), that they took away quite a lot of the leftover spoil. If you want any left onsite, just tell them (they'll be happy to leave it as long as its out of the way, saves them $$$. We will try and get the fill spread around a bit before we hand the site over so we can see if we need any extra. My husband is being his usual not in a hurry self, while I'm fretting that it'll somehow cause us problems lol. They have a storm water drain going in that goes diagonally across the yard so that's the only thing it may cause an issue with and I'm not sure if they'll scrape the land all the way because of that drain? I'll attach the storm water plan and a pic of our pool without concrete. I am happy with the colour. There'll be a waterfall on the fence side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By the way, does anyone else have messed up notifications? I've been getting notifications for heaps of threads I'm not following and nothing on the ones I am. Building Monte Carlo 40- Wisdom homes I would doubt that they would scrape all of your yard (where you have the diagonal pipe going - too much work for them.... Best to just ask your CSR to advise construction that you want the pool fill left onsite. Pool looks good, and will be a great complement to your backyard. We are in the midst of looking for someone to landscape the pool surrounds (ie concrete and tiling mainly), as I think NP are a little bit $$$ with what they want. I'm not sure though whether NP can work around this or not? Will NP have to come back out to your place once W finish? Re: Building with Wisdom Homes 6784Jul 24, 2017 5:57 pm MandM+4 ozmonkeyoy MandM+4 Pool went in the ground on Tuesday and then all the plumbing, set up for the concrete bond beam so not quite finished yet. To NP's credit they would have done the bond beam at the end of this week but we are still waiting for our bank to pay them so fair dos. We kept some of the fill to use in our backyard, do you know if W will let us keep it there if it's outside of the slab peg out? I've said to hubby I don't think they will, hoping if he gets in there with a machine and spreads it around that will be ok... Building Monte Carlo 40- Wisdom homes Fair enough re pool. Hopefully looks good (although I'm sure still rough at the moment), but at least you get to see the size of it on your lot. You won't get the exact picture though til its all done with the house also there. If the spoil is outside of the your scrape and cut zone that W will do, then I see no reason why they will touch it. I would ensure that its as far away as possible to the pegged area and also tell W that you want the fill left there. Will there be leftover fill from the cut/scrape that W will do? I know on ours (and land is very flat), that they took away quite a lot of the leftover spoil. If you want any left onsite, just tell them (they'll be happy to leave it as long as its out of the way, saves them $$$. We will try and get the fill spread around a bit before we hand the site over so we can see if we need any extra. My husband is being his usual not in a hurry self, while I'm fretting that it'll somehow cause us problems lol. They have a storm water drain going in that goes diagonally across the yard so that's the only thing it may cause an issue with and I'm not sure if they'll scrape the land all the way because of that drain? I'll attach the storm water plan and a pic of our pool without concrete. I am happy with the colour. There'll be a waterfall on the fence side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By the way, does anyone else have messed up notifications? I've been getting notifications for heaps of threads I'm not following and nothing on the ones I am. Building Monte Carlo 40- Wisdom homes oh, no messed up notifications at my end (just saw the last part of your post) Re: Building with Wisdom Homes 6785Jul 24, 2017 6:01 pm aaron2008 @ozmonkeyoy - What is the color of your cabinets? I believe you are going for spotted gum floors, right on trend there! We are thinking of grey porcelain floors, which is making it hard for us to decide / go for dark cabinetries. Hi aaron2008, Per Kitchen schedule; BASE DOORS MATERIAL POLYURETHANE (FLAT FACE) FINISH SATIN COLOUR DULUX – WHITE CLOAK QUARTER STRENGTH EDGE NA HANDLES REVERSE SHARK EDGE PLACEMENT NA UPPER DOORS MATERIAL POLYTEC FINISH MATT COLOUR CHAR OAK (VERTICAL GRAIN) EDGE MATCHING 1mm HANDLES 20mm DOOR DROP DOWN PLACEMENT NA Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Char-Oak (Vertical Grain) (Sorry pic came out big) I think the grey tiles will work fine with above choices..... Oz Re: Building with Wisdom Homes 6786Jul 24, 2017 10:37 pm ozmonkeyoy MandM+4 ozmonkeyoy [quote="MandM+4"] Pool went in the ground on Tuesday and then all the plumbing, set up for the concrete bond beam so not quite finished yet. To NP's credit they would have done the bond beam at the end of this week but we are still waiting for our bank to pay them so fair dos. We kept some of the fill to use in our backyard, do you know if W will let us keep it there if it's outside of the slab peg out? I've said to hubby I don't think they will, hoping if he gets in there with a machine and spreads it around that will be ok... Building Monte Carlo 40- Wisdom homes Fair enough re pool. Hopefully looks good (although I'm sure still rough at the moment), but at least you get to see the size of it on your lot. You won't get the exact picture though til its all done with the house also there. If the spoil is outside of the your scrape and cut zone that W will do, then I see no reason why they will touch it. I would ensure that its as far away as possible to the pegged area and also tell W that you want the fill left there. Will there be leftover fill from the cut/scrape that W will do? I know on ours (and land is very flat), that they took away quite a lot of the leftover spoil. If you want any left onsite, just tell them (they'll be happy to leave it as long as its out of the way, saves them $$$. We will try and get the fill spread around a bit before we hand the site over so we can see if we need any extra. My husband is being his usual not in a hurry self, while I'm fretting that it'll somehow cause us problems lol. They have a storm water drain going in that goes diagonally across the yard so that's the only thing it may cause an issue with and I'm not sure if they'll scrape the land all the way because of that drain? I'll attach the storm water plan and a pic of our pool without concrete. I am happy with the colour. There'll be a waterfall on the fence side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By the way, does anyone else have messed up notifications? I've been getting notifications for heaps of threads I'm not following and nothing on the ones I am. Building Monte Carlo 40- Wisdom homes I would doubt that they would scrape all of your yard (where you have the diagonal pipe going - too much work for them.... Best to just ask your CSR to advise construction that you want the pool fill left onsite. Pool looks good, and will be a great complement to your backyard. We are in the midst of looking for someone to landscape the pool surrounds (ie concrete and tiling mainly), as I think NP are a little bit $$$ with what they want. I'm not sure though whether NP can work around this or not? Will NP have to come back out to your place once W finish?[/quote] Yes they come back, clean the pool and get all the equipment up and running after W finish. We will probably get the remainder of the pool concrete done at the same time as driveway, a side path and shed slab...not going to get W to do the driveway, we have decided just to get them to prep the yard and maybe the back fence/retaining. We are now planning a deck next to alfresco and I think we will tile the whole pool area, not sure if we will DIY that or not. We've also decided not to pay NP's markup...their price for concrete is the same as W's. How are you heating your pool? We are thinking of getting a solar PV system on the house so I'm not sure whether to go a separate solar system for the pool or do a heat pump. Building Monte Carlo 40- Wisdom homes Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 6787Jul 25, 2017 10:37 am MandM+4 ozmonkeyoy I would doubt that they would scrape all of your yard (where you have the diagonal pipe going - too much work for them.... Best to just ask your CSR to advise construction that you want the pool fill left onsite. Pool looks good, and will be a great complement to your backyard. We are in the midst of looking for someone to landscape the pool surrounds (ie concrete and tiling mainly), as I think NP are a little bit $$$ with what they want. I'm not sure though whether NP can work around this or not? Will NP have to come back out to your place once W finish? Yes they come back, clean the pool and get all the equipment up and running after W finish. We will probably get the remainder of the pool concrete done at the same time as driveway, a side path and shed slab...not going to get W to do the driveway, we have decided just to get them to prep the yard and maybe the back fence/retaining. We are now planning a deck next to alfresco and I think we will tile the whole pool area, not sure if we will DIY that or not. We've also decided not to pay NP's markup...their price for concrete is the same as W's. How are you heating your pool? We are thinking of getting a solar PV system on the house so I'm not sure whether to go a separate solar system for the pool or do a heat pump. Building Monte Carlo 40- Wisdom homes We are heating the pool via a gas heater. Because we also have a spa going in, it requires the gas heater. We may look at getting solar for the pool on at some point as well, just so the gas heater isn't running a lot (with gas pricing rising). We have a pool at current home, and the solar is enough for November to March (October also if its warm), but if you want to use the pool outside of this period, definitely will need a boost from a heater. We had the caeserstone benches delivered this morning, rear balcony rail installed, and tilers are still also hanging around. Good to see action still happening onsite. Re: Building with Wisdom Homes 6788Jul 25, 2017 10:48 am Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Re: Building with Wisdom Homes 6789Jul 25, 2017 11:55 am ozmonkeyoy Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Building with Wisdom Homes 6790Jul 25, 2017 1:47 pm ozmonkeyoy Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Hi Oz, Demo finished. We are still waiting for some sort of update from W... no draft end panel as yet... So we are using this time to replace some palings in the rear fence and had a macadamia tree removed (with council permission) cause our middle daughter has a severe nut allergy. That was another battle with council. It would have been within 2 metres of our alfresco area and they said it must remain. A Dr certificate to verify our claims was all that was needed to change their minds. Your place is looking fabulous. I'm loving your tile selections and can't wait for the next lot of photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Manhattan 52 Scrape 8/11/17 Slab 16/11/17 Handover 7/12/18 Re: Building with Wisdom Homes 6791Jul 25, 2017 1:58 pm lombieagle ozmonkeyoy Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Hi, we are now 6months in admin and WH have only this week submitted for developers approval. All colours, flooring, kitchen, Air Con etc signed off. Just a waiting game now. Good luck with the final stages of admin. Apart from slow, how have you found the admin process to date? Re: Building with Wisdom Homes 6792Jul 25, 2017 2:07 pm ozmonkeyoy Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Our framing is ongoing and windows delivered. Progress has been pretty good so far and work done everyday. (I have probably jinx it now) Some snaps from last night, not the best of photos but... More on my blog link below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 6793Jul 25, 2017 2:09 pm ozmonkeyoy lombieagle ozmonkeyoy Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Hi, we are now 6months in admin and WH have only this week submitted for developers approval. All colours, flooring, kitchen, Air Con etc signed off. Just a waiting game now. Good luck with the final stages of admin. Apart from slow, how have you found the admin process to date? Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 6794Jul 25, 2017 2:15 pm amf139 ozmonkeyoy Its all gone pretty quiet around here lately. What is everyone up to??? Maybe its all the main contributors are finished or just getting started? Hi Oz, Demo finished. We are still waiting for some sort of update from W... no draft end panel as yet... So we are using this time to replace some palings in the rear fence and had a macadamia tree removed (with council permission) cause our middle daughter has a severe nut allergy. That was another battle with council. It would have been within 2 metres of our alfresco area and they said it must remain. A Dr certificate to verify our claims was all that was needed to change their minds. Your place is looking fabulous. I'm loving your tile selections and can't wait for the next lot of photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Awesome...progress, good to finally see the demo done!!! So you are getting much closer to a construction start if selections are done and you're close to draft end panel. After all of the dramas, any expectations on construction start date, or you don't want to jinx yourself? We have an appointment with WL on Thursday, so am hoping to talk them into allowing us to have a sneek peek inside the house as well. Really hard to get any pics of anything once lockup happens. Re: Building with Wisdom Homes 6795Jul 25, 2017 3:09 pm Thank You ozmonkeyoy & mrsllamas2016 Just ordered all possible samples from ceaserstone,laminex & polytec. We got our revised tender with floor plan last week. Been waiting for W to find a suitable alternative for the Rain Water Garden & RWT. Its been a month since registration of our land. Things that I found out all by myself 1. There is no overhead cabinets on Bulters as std 2. Aircon upgrade, we need a PA for that (at least in my budget) 3. We need to build a retaining wall as a part of landscaping 4. Portico is smaller than what we thought and we have to live with it now as change it would mean another 1.5 month of work I am hoping that W get back to us sooner with a plan & tender with no mistakes so we go for contract & appointments.The construction to start by Nov at least but it seems like a dream with the delays.We will definitely going for DA rather than CDC so fingers cross. Re: Building with Wisdom Homes 6796Jul 25, 2017 6:18 pm We have upper roof on and first floor bricks cleaned. Eaves and upper downpipes are in and painted. Expansion joints siliconed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ majestic35.weebly.com Re: Building with Wisdom Homes 6797Jul 25, 2017 6:27 pm Hi everyone! It has been ages since I posted - partly because our epic journey that has been our build started to get me down, and also when I did jump on here to check what was going on I became totally overwhelmed by the hundreds of posts I had to catch up on! I am happy to say that I am now up to date on posts and really happy to see everyone's progress! And also a big welcome to the new members - wishing you all a stress free and speedy build! So a quick update of where we're at: we finally have a PCI date! Woohoo! 7th August, making it a a whopping 48 weeks since the start of construction!! Somehow, Wisdom has claimed 59 days (3 months!) of contract extension which means they won't back pay us. Has anyone asked for a breakdown of what is included in the days over? We really don't care at this point, we just want to get in. And I doubt they'd write 'incompetence' as a reason! Lol! Anyway, apart from the original issues we had with the incorrect facade plan being built, we also had tiles run out that took forever to source, incorrect placement of AC vents that needed to be moved and patched up, balcony rendered in the incorrect colour, stairs stained incorrectly, just to name a few. There is still work to be completed ie. carpet, caulking, etc. but we're getting there. Here are some recent pics: Entry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Staircase Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Butlers pantry/walk in pantry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Leisure room (fireplace wall to be tiled after handover). Big windows overlook the pool already installed by Narellan Pools Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dining/alfresco Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Void Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master WIR Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master ensuite with glass panel installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 - Wisdom Homes Re: Building with Wisdom Homes 6798Jul 25, 2017 6:42 pm msjovi Hi everyone! It has been ages since I posted - partly because our epic journey that has been our build started to get me down, and also when I did jump on here to check what was going on I became totally overwhelmed by the hundreds of posts I had to catch up on! I am happy to say that I am now up to date on posts and really happy to see everyone's progress! And also a big welcome to the new members - wishing you all a stress free and speedy build! So a quick update of where we're at: we finally have a PCI date! Woohoo! 7th August, making it a a whopping 48 weeks since the start of construction!! Somehow, Wisdom has claimed 59 days (3 months!) of contract extension which means they won't back pay us. Has anyone asked for a breakdown of what is included in the days over? We really don't care at this point, we just want to get in. And I doubt they'd write 'incompetence' as a reason! Lol! Anyway, apart from the original issues we had with the incorrect facade plan being built, we also had tiles run out that took forever to source, incorrect placement of AC vents that needed to be moved and patched up, balcony rendered in the incorrect colour, stairs stained incorrectly, just to name a few. There is still work to be completed ie. carpet, caulking, etc. but we're getting there. Here are some recent pics: Entry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Staircase Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Butlers pantry/walk in pantry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Leisure room (fireplace wall to be tiled after handover). Big windows overlook the pool already installed by Narellan Pools Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dining/alfresco Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Void Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master WIR Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master ensuite with glass panel installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 - Wisdom Homes She's beautiful!!!!! congrats. Almost time to make it your home. Xxx Building Majestic 40 - wisdom homes Re: Building with Wisdom Homes 6799Jul 25, 2017 8:02 pm msjovi Hi everyone! It has been ages since I posted - partly because our epic journey that has been our build started to get me down, and also when I did jump on here to check what was going on I became totally overwhelmed by the hundreds of posts I had to catch up on! I am happy to say that I am now up to date on posts and really happy to see everyone's progress! And also a big welcome to the new members - wishing you all a stress free and speedy build! So a quick update of where we're at: we finally have a PCI date! Woohoo! 7th August, making it a a whopping 48 weeks since the start of construction!! Somehow, Wisdom has claimed 59 days (3 months!) of contract extension which means they won't back pay us. Has anyone asked for a breakdown of what is included in the days over? We really don't care at this point, we just want to get in. And I doubt they'd write 'incompetence' as a reason! Lol! Anyway, apart from the original issues we had with the incorrect facade plan being built, we also had tiles run out that took forever to source, incorrect placement of AC vents that needed to be moved and patched up, balcony rendered in the incorrect colour, stairs stained incorrectly, just to name a few. There is still work to be completed ie. carpet, caulking, etc. but we're getting there. Here are some recent pics: Entry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Staircase Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Butlers pantry/walk in pantry Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Leisure room (fireplace wall to be tiled after handover). Big windows overlook the pool already installed by Narellan Pools Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Dining/alfresco Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Void Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master WIR Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master ensuite with glass panel installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 41 - Wisdom Homes Absolutely stunning!! It is better than a display home. So happy to hear you have a PCI date but honestly, it's taken them a year, they can not claim 59 days in rain and Xmas shutdown, surely?! I think that's mega cheeky. I hope your beautiful home is worth all the anguish it's caused. Can not wait to see it finished, and your pool! Building Monte Carlo 40- Wisdom homes Building Monte Carlo 40- Wisdom homes Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18777 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73833 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8947 |
