Browse Forums Building A New House Re: Building with Wisdom Homes 14922Aug 23, 2019 3:32 pm M4bath sv_reddy Hello all, Whoever is in building phase, when can we expect to have the master plan with "doors/windows schedule"? All we have received so far are the plans with different elevations, none of them have the detailed windows/doors schedule. We have signed the contract, and have the selections soon. Thanks The door and window schedule for us is structural and was the first thing we did before signing the contract as the cost of the upgrades was in the very first tender. You better ask for it quick before they consider it a contract variation. This was the case for us also - the door and ceiling height were discussed prior to our contract. Mind you it was never mentioned to us that the door heights were considered structual, nor did we think about check that they were all the correct height on the plans until i read it on this forum! Lucky ours were all correct prior to plans stage. Building Wisdom Homes Majestic 35 Re: Building with Wisdom Homes 14923Aug 24, 2019 4:19 pm What would you check for......I am looking at getting a private building inspection done Re: Building with Wisdom Homes 14924Aug 25, 2019 10:33 pm Yes. I would recommend getting a private certifier. You almost have to for at least pre linings. At frames there's a whole lot of us there that can go into a lot more detail that what i could here I really you have the plans which include where all the frames are. You then check the location against the slab. All load bearing frames need to sit completely flat against the slab. You then take you leveller to check how flat the frames are by placing them at various locations against the frame. The frames should also be plumb as required. I.e straight vertically down. Along the ones that go down there's another plan which shows where and roughly the height of the ones that go horizontally. This is based against Australian Standards etc. Check all the window and door frames again especially any sliding doors. All the frames need to sit completely flat. You can buy a leveller for about 30 dollars at bunnings. If you can, go out with the inspector to check and see what they do. Also check for blowouts. Ideally the site supervisor will pick up any defects above, as that's what you are paying for. Quality. So really hot are hoping the inspector does not pick anything up unexpected. Your site supervisor should be able to tell you all the defects they picked up before your own inspector does. Else you may have a sketchy one or one that does not have the same experience or skill of the inspector. It should not be the other way round. CS199 What would you check for......I am looking at getting a private building inspection done Re: Building with Wisdom Homes 14925Aug 26, 2019 9:15 am Need some advise and ides In out kitchen we didn't want the microwave to be installed near the sink as that position is too low What is another good position to install the microwave tower/cabinet as per the designs below........if nothing I will get it installed in the pantry only as there is heaps of space there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 14926Aug 26, 2019 9:17 am CS199 Need some advise and ides In out kitchen we didn't want the microwave to be installed near the sink as that position is too low What is another good position to install the microwave tower/cabinet as per the designs below........if nothing I will get it installed in the pantry only as there is heaps of space there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Personally I prefer mine in the pantry Re: Building with Wisdom Homes 14927Aug 26, 2019 9:35 am CS199 Need some advise and ides In out kitchen we didn't want the microwave to be installed near the sink as that position is too low What is another good position to install the microwave tower/cabinet as per the designs below........if nothing I will get it installed in the pantry only as there is heaps of space there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We went with the tower. Re: Building with Wisdom Homes 14928Aug 26, 2019 10:17 am Pantry is not a bad idea. CS199 Need some advise and ides In out kitchen we didn't want the microwave to be installed near the sink as that position is too low What is another good position to install the microwave tower/cabinet as per the designs below........if nothing I will get it installed in the pantry only as there is heaps of space there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 14930Aug 26, 2019 12:19 pm CS199 Need some advise and ides In out kitchen we didn't want the microwave to be installed near the sink as that position is too low What is another good position to install the microwave tower/cabinet as per the designs below........if nothing I will get it installed in the pantry only as there is heaps of space there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I had mine installed next to the fridge similar to the display homes. Re: Building with Wisdom Homes 14931Aug 26, 2019 1:17 pm Hi All, For those planning on doing Driveways after handover does anyone have any driveway concreter recommendations in the Sydney area? I am just getting quotes now and they are varying to the point where I am questioning the quality of some and the validity of others. Any help would be appreciated. Thanks Bob Re: Building with Wisdom Homes 14932Aug 26, 2019 1:43 pm Femstar CS199 Need some advise and ides In out kitchen we didn't want the microwave to be installed near the sink as that position is too low What is another good position to install the microwave tower/cabinet as per the designs below........if nothing I will get it installed in the pantry only as there is heaps of space there Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I had mine installed next to the fridge similar to the display homes. Do you have a photo by any chance that you can share Re: Building with Wisdom Homes 14934Aug 27, 2019 7:08 pm Chompy Rangehoods Q. Are they ducted externally? Yes mine is Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Re: Building with Wisdom Homes 14936Aug 27, 2019 7:45 pm sv_reddy Hi, Any of you guys planned to have motorised blinds? What provisions do I need to request for, during electrical selections? Thanks All my windows have motorised blinds. If you are going through EHI they will do the electrical for you. If you don't provision in the hardwire, the battery operated motorised are also excellent. It charges through a small USB lead once every 6 months. Re: Building with Wisdom Homes 14937Aug 27, 2019 7:54 pm Manhattan52 sv_reddy Hi, Any of you guys planned to have motorised blinds? What provisions do I need to request for, during electrical selections? Thanks All my windows have motorised blinds. If you are going through EHI they will do the electrical for you. If you don't provision in the hardwire, the battery operated motorised are also excellent. It charges through a small USB lead once every 6 months. Thanks Manhattan52. Is Wisdom tied up with EHI? Sorry, I wasnt sure. lol I would like to hard wire it for some selected windows. Any idea how much it cost to provide the hard wire provision per window? Is that a power point? or something else. Thanks Re: Building with Wisdom Homes 14938Aug 27, 2019 8:03 pm sv_reddy Manhattan52 sv_reddy Hi, Any of you guys planned to have motorised blinds? What provisions do I need to request for, during electrical selections? Thanks All my windows have motorised blinds. If you are going through EHI they will do the electrical for you. If you don't provision in the hardwire, the battery operated motorised are also excellent. It charges through a small USB lead once every 6 months. Thanks Manhattan52. Is Wisdom tied up with EHI? Sorry, I wasnt sure. lol I would like to hard wire it for some selected windows. Any idea how much it cost to provide the hard wire provision per window? Is that a power point? or something else. Thanks EHI is Wisdoms supplier of blinds/curtains/screen doors etc. you will have an appointment at Canvas Quarter with them. I didn’t get provisioning as EHI are doing the lot. I think the motorisation of each blind cost about $700 which includes the electrical install and the motor itself as well as remotes etc. it isn’t a power point as such it’s an electrical tail that is hidden when the blinds are installed Re: Building with Wisdom Homes 14939Aug 27, 2019 8:13 pm Manhattan52 sv_reddy Manhattan52 All my windows have motorised blinds. If you are going through EHI they will do the electrical for you. If you don't provision in the hardwire, the battery operated motorised are also excellent. It charges through a small USB lead once every 6 months. Thanks Manhattan52. Is Wisdom tied up with EHI? Sorry, I wasnt sure. lol I would like to hard wire it for some selected windows. Any idea how much it cost to provide the hard wire provision per window? Is that a power point? or something else. Thanks EHI is Wisdoms supplier of blinds/curtains/screen doors etc. you will have an appointment at Canvas Quarter with them. I didn’t get provisioning as EHI are doing the lot. I think the motorisation of each blind cost about $700 which includes the electrical install and the motor itself as well as remotes etc. it isn’t a power point as such it’s an electrical tail that is hidden when the blinds are installed Thank you Manhattan52, much appreciated. What is your suggestion if I want to have them later, as we cant afford now? Re: Building with Wisdom Homes 14940Aug 27, 2019 8:13 pm Manhattan52 sv_reddy Manhattan52 [quote="sv_reddy"]Hi, Any of you guys planned to have motorised blinds? What provisions do I need to request for, during electrical selections? Thanks All my windows have motorised blinds. If you are going through EHI they will do the electrical for you. If you don't provision in the hardwire, the battery operated motorised are also excellent. It charges through a small USB lead once every 6 months. Thanks Manhattan52. Is Wisdom tied up with EHI? Sorry, I wasnt sure. lol I would like to hard wire it for some selected windows. Any idea how much it cost to provide the hard wire provision per window? Is that a power point? or something else. Thanks EHI is Wisdoms supplier of blinds/curtains/screen doors etc. you will have an appointment at Canvas Quarter with them. I didn’t get provisioning as EHI are doing the lot. I think the motorisation of each blind cost about $700 which includes the electrical install and the motor itself as well as remotes etc. it isn’t a power point as such it’s an electrical tail that is hidden when the blinds are installed[/quote] Good insights-does that mean you need to specify up front as part of electrical ? Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18249 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 20 73079 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8029 |
