Browse Forums Building A New House Re: Building with Wisdom Homes 13641Dec 12, 2018 1:57 pm Handover completed and got the keys 🔑. Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13642Dec 12, 2018 2:03 pm kingofnowhere Manhattan52 ideally should show on your construction plans but tender/contract/end panel will always override any plans. When i was in production estimating and the solar was ordered that's when the supplier came back to me through my colours consultant with placement on my roof manhattan52 can you give bit more info on the solar panel wisdom offer? What capacity did you get and how much was it? It wasn’t an offer as such. I ordered a 6kw system with an 8kw Sonnen battery. I need a lot bigger system than this but this was the biggest they could do. I will add on more panels later on. This cost me $20k Re: Building with Wisdom Homes 13643Dec 12, 2018 2:07 pm Manhattan52 kingofnowhere Manhattan52 ideally should show on your construction plans but tender/contract/end panel will always override any plans. When i was in production estimating and the solar was ordered that's when the supplier came back to me through my colours consultant with placement on my roof manhattan52 can you give bit more info on the solar panel wisdom offer? What capacity did you get and how much was it? It wasn’t an offer as such. I ordered a 6kw system with an 8kw Sonnen battery. I need a lot bigger system than this but this was the biggest they could do. I will add on more panels later on. This cost me $20k Thanks manhattan52 Re: Building with Wisdom Homes 13644Dec 12, 2018 2:07 pm Priyasuresh11 Handover completed and got the keys 🔑. congrats Re: Building with Wisdom Homes 13645Dec 12, 2018 2:21 pm kingofnowhere Priyasuresh11 Handover completed and got the keys 🔑. congrats Thank you Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13647Dec 12, 2018 4:45 pm COOL6789 Priyasuresh11 Handover completed and got the keys 🔑. Congratulations!!! Post some pics for us Sure. Thank you Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13648Dec 12, 2018 4:49 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13649Dec 12, 2018 5:21 pm One Hi everyone, Some of us have solar roof tiles included in the package, should the location of these be reflected in the construction plans or is that something that gets sorted during construction? Hi One Our solar panels were shown in our final construction plans. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They are only approximate locations. When our solar panels were installed, they ended up being installed on the other side of the roof. Re: Building with Wisdom Homes 13651Dec 12, 2018 5:29 pm Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13652Dec 12, 2018 5:39 pm twolittlepeas One Hi everyone, Some of us have solar roof tiles included in the package, should the location of these be reflected in the construction plans or is that something that gets sorted during construction? Hi One Our solar panels were shown in our final construction plans. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They are only approximate locations. When our solar panels were installed, they ended up being installed on the other side of the roof. twolittlepeas Thanks, I didn’t realise there are construction plans and then final construction plans. Learn something everyday! Our construction plans definitely don’t have the solar like yours. Re: Building with Wisdom Homes 13653Dec 12, 2018 6:01 pm One twolittlepeas One Hi everyone, Some of us have solar roof tiles included in the package, should the location of these be reflected in the construction plans or is that something that gets sorted during construction? Hi One Our solar panels were shown in our final construction plans. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They are only approximate locations. When our solar panels were installed, they ended up being installed on the other side of the roof. twolittlepeas Thanks, I didn’t realise there are construction plans and then final construction plans. Learn something everyday! Our construction plans definitely don’t have the solar like yours. Yeah, they don't tell you. I had to ask about them, so you should check with your colour consultant. You get to sign off on construction plans for your DA or CDC approval. And then you'll get your final construction plans after signing your draft end panel. I remember seeing the location of the battery somewhere on a different page of plans too. Re: Building with Wisdom Homes 13654Dec 12, 2018 7:00 pm Another tip for those still in admin. Upgrade your alarm to include key remotes and remote to integrate with garage door. Works out cheaper than doing it afterwards. No one asked us so we didn't think of it at the time Re: Building with Wisdom Homes 13655Dec 12, 2018 7:05 pm Hi all Need some advice. For our kitchen island bench, I have the option to extend the bench length to 3600mm instead of the standard 2800mm The only downside is that the Caesarstone benchtop comes with the max length of 3000mm so they will need to put a joint in to make it 3600mm Will the joint destroy the look of the benchtop? If I do go with the joint what will be a good place to have one to make it less obvious? Re: Building with Wisdom Homes 13656Dec 12, 2018 7:07 pm CS199 Hi all Need some advice. For our kitchen island bench, I have the option to extend the bench length to 3600mm instead of the standard 2800mm The only downside is that the Caesarstone benchtop comes with the max length of 3000mm so they will need to put a joint in to make it 3600mm Will the joint destroy the look of the benchtop? If I do go with the joint what will be a good place to have one to make it less obvious? The join will be straight down the middle. Depends on what benchtop you will have as to if it will look bad or not Re: Building with Wisdom Homes 13657Dec 12, 2018 7:10 pm Manhattan52 CS199 Hi all Need some advice. For our kitchen island bench, I have the option to extend the bench length to 3600mm instead of the standard 2800mm The only downside is that the Caesarstone benchtop comes with the max length of 3000mm so they will need to put a joint in to make it 3600mm Will the joint destroy the look of the benchtop? If I do go with the joint what will be a good place to have one to make it less obvious? The join will be straight down the middle. Depends on what benchtop you will have as to if it will look bad or not They won't be a full length 3000mm and then a joint on a side for 600mm.......dont really want to spoil the look of the kitchen in trying to make island bigger. Going with Nougat as the benchtop Re: Building with Wisdom Homes 13658Dec 12, 2018 7:21 pm CS199 Manhattan52 CS199 Hi all Need some advice. For our kitchen island bench, I have the option to extend the bench length to 3600mm instead of the standard 2800mm The only downside is that the Caesarstone benchtop comes with the max length of 3000mm so they will need to put a joint in to make it 3600mm Will the joint destroy the look of the benchtop? If I do go with the joint what will be a good place to have one to make it less obvious? The join will be straight down the middle. Depends on what benchtop you will have as to if it will look bad or not They won't be a full length 3000mm and then a joint on a side for 600mm.......dont really want to spoil the look of the kitchen in trying to make island bigger. Going with Nougat as the benchtop the join will be in the middle for strength purposes. Close up you will see the join but a few metres away you won’t. Joins especially on a island bench can get a bit grubby also. Would recommend sticking with the one slab Re: Building with Wisdom Homes 13659Dec 12, 2018 7:25 pm doosra Another tip for those still in admin. Upgrade your alarm to include key remotes and remote to integrate with garage door. Works out cheaper than doing it afterwards. No one asked us so we didn't think of it at the time How much are the integrated fobs/remotes? Re: Building with Wisdom Homes 13660Dec 12, 2018 7:43 pm Remote Control Handsets $99.00 each Receiver to Alarm Control Panel for Remotes to Activate Alarm $75.00 Call out fee of technician $120.00 Optional - Receiver to Garage Motor for Remotes to Activate Garage Door off same Handset $99.00 It's the call out fee you have to pay now when doing it after handover.. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18589 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73633 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8496 |
