Yes, we have flyscreens on ours.
We requested flyscreens on our tender for all openable windows as well.
So do the windows open inwards as well as out or are the screens inside the windows?
Browse Forums Building A New House Re: Building with Wisdom Homes 9121Feb 01, 2018 1:15 pm ozmonkeyoy Yes, we have flyscreens on ours. We requested flyscreens on our tender for all openable windows as well. So do the windows open inwards as well as out or are the screens inside the windows? Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 9122Feb 01, 2018 1:21 pm MandM+4 doosra ASJ1981 I just checked my Contract Tender and it says "10-11 Outlets with 2 x Zones" For our Washington, do you think this setup is fine: Zone 1 - Master & Bedroom 4 (2 outlets) Zone 2 - Upper Lounge, Bedroom 2 & Bedroom 3 (3 outlets) Zone 3 - Dining, Kitchen & Leisure (4 outlets) Zone 4 - Office and Lounge-turned-Theatre room (2 outlets) Means we need an additional 2 zones, (but it sounds like 4 zones is overkill for only 29sq) OR should Zone 1 be upstairs and Zone 2 downstairs (Is 1 zone per floor enough?) Ahhh decisions decisions! You guys can see how much i struggle with these things! LOL! I can't even decide what coffee i want and i really need one right about now! Zones really come down to how u use the house so you're the best person to decide. If you're on the esp classic then I think 2 zones is enough and the reason I say this is because with this unit, it's either on or off which means the air con runs at same power all the time. Whereas the esp plus can slow itself down depending on zones. For example, if I were to just zone the office and use the aircon, it'll run a lot less electricity whereas urs draws full power. That's what I've been told so others can correct me if wrong. This is true, but it is going to switch off when the room reaches the desired temp and it will take a lot less time to do that in a smaller space. Also, I don’t believe these units can do the entire house at the same time? So if extra zones you can cool part of each floor at the same time rather than just choosing up or down. Can anyone finished their build confirm this? Yes with extra zones that's the whole purpose to allow to cool parts of the house and each floor at same time. Good point with the desired temp piece but also in saying that, I'd imagine that if the outlets are adequately spaced and placed then I would assume that getting the other rooms to same temp shouldn't take that much extra time . Asj- speak to ur consultant around the scenario that MandM and I have raised and if it uses close to same power whether u have 1 room zoned vs upstairs/downstairs then u could just save money and not get extra zones. Re: Building with Wisdom Homes 9123Feb 01, 2018 1:24 pm MandM+4 ozmonkeyoy Yes, we have flyscreens on ours. We requested flyscreens on our tender for all openable windows as well. So do the windows open inwards as well as out or are the screens inside the windows? Screens are inside the windows. The windows only open outwards. Re: Building with Wisdom Homes 9124Feb 01, 2018 1:26 pm MandM+4 doosra ASJ1981 I just checked my Contract Tender and it says "10-11 Outlets with 2 x Zones" For our Washington, do you think this setup is fine: Zone 1 - Master & Bedroom 4 (2 outlets) Zone 2 - Upper Lounge, Bedroom 2 & Bedroom 3 (3 outlets) Zone 3 - Dining, Kitchen & Leisure (4 outlets) Zone 4 - Office and Lounge-turned-Theatre room (2 outlets) Means we need an additional 2 zones, (but it sounds like 4 zones is overkill for only 29sq) OR should Zone 1 be upstairs and Zone 2 downstairs (Is 1 zone per floor enough?) Ahhh decisions decisions! You guys can see how much i struggle with these things! LOL! I can't even decide what coffee i want and i really need one right about now! Zones really come down to how u use the house so you're the best person to decide. If you're on the esp classic then I think 2 zones is enough and the reason I say this is because with this unit, it's either on or off which means the air con runs at same power all the time. Whereas the esp plus can slow itself down depending on zones. For example, if I were to just zone the office and use the aircon, it'll run a lot less electricity whereas urs draws full power. That's what I've been told so others can correct me if wrong. This is true, but it is going to switch off when the room reaches the desired temp and it will take a lot less time to do that in a smaller space. Also, I don’t believe these units can do the entire house at the same time? So if extra zones you can cool part of each floor at the same time rather than just choosing up or down. Can anyone finished their build confirm this? You guys are awesome! Appreciate the feedback and responses. I work from home 1-2 days a week and if i don't have any client meetings, it can sometimes be 3 days a week. My home office is right at the front of the house - as soon as you walk in and so i will spend a lot of my work hours in there. Hubby will be at work and kids at school, so i probably won't need the Leisure/Kitchen/Dining air-con to be on at the same time (it's at the back of the house). I like your point MandM+4 about cooling a part of each floor rather than up or down. For an extra 2 zones and $700, i might add them anyway because it will be the forever home. Re: Building with Wisdom Homes 9125Feb 01, 2018 3:18 pm spk_homebuild Jenifermarie We opted to upgrade our powerpoints in our kitchen so they would blend in more - we went with the charcoal Saturn Horizon range as they were the best match for our smoked mirror backsplash. It was $137 for the cooler switch and $139 per double power point when we did our appt last May. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ We too did this . On the splashbacks , we decided to go with default white tiles for the butlers pantry. Was a bit of a compromise but we decided to spend it else where. What stage are you in JeniferMarie. We signed off our DEP and are waiting on Construction plans We’re officially in production estimating as of today Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9127Feb 01, 2018 3:55 pm Jenifermarie spk_homebuild Jenifermarie We opted to upgrade our powerpoints in our kitchen so they would blend in more - we went with the charcoal Saturn Horizon range as they were the best match for our smoked mirror backsplash. It was $137 for the cooler switch and $139 per double power point when we did our appt last May. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ We too did this . On the splashbacks , we decided to go with default white tiles for the butlers pantry. Was a bit of a compromise but we decided to spend it else where. What stage are you in JeniferMarie. We signed off our DEP and are waiting on Construction plans We’re officially in production estimating as of today Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 9129Feb 01, 2018 4:09 pm ozmonkeyoy MandM+4 Yes, we have flyscreens on ours. We requested flyscreens on our tender for all openable windows as well. So do the windows open inwards as well as out or are the screens inside the windows? Screens are inside the windows. The windows only open outwards.[/quote] Seems obvious i know but the thought only just occurred to me about the awning windows opening outwards when I was thinking about what screen to put on the balcony door today. That confirms my decision to put plantation shutters on those windows then, pretty them up on the inside. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 9130Feb 01, 2018 4:59 pm MandM+4 ozmonkeyoy Yes, we have flyscreens on ours. We requested flyscreens on our tender for all openable windows as well. So do the windows open inwards as well as out or are the screens inside the windows? Screens are inside the windows. The windows only open outwards.[/quote] Seems obvious i know but the thought only just occurred to me about the awning windows opening outwards when I was thinking about what screen to put on the balcony door today. That confirms my decision to put plantation shutters on those windows then, pretty them up on the inside. [/quote]All good. See pics of one of ours from an ensuite; We have plantations on ours. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 9131Feb 01, 2018 5:02 pm ozmonkeyoy MandM+4 Yes, we have flyscreens on ours. We requested flyscreens on our tender for all openable windows as well. So do the windows open inwards as well as out or are the screens inside the windows? Screens are inside the windows. The windows only open outwards.[/quote] Seems obvious i know but the thought only just occurred to me about the awning windows opening outwards when I was thinking about what screen to put on the balcony door today. That confirms my decision to put plantation shutters on those windows then, pretty them up on the inside. [/quote]All good. See pics of one of ours from an ensuite; We have plantations on ours. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] Thanks! They look neater than I was picturing. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 9132Feb 01, 2018 5:05 pm ozmonkeyoy MandM+4 Yes, we have flyscreens on ours. We requested flyscreens on our tender for all openable windows as well. So do the windows open inwards as well as out or are the screens inside the windows? Screens are inside the windows. The windows only open outwards.[/quote] Seems obvious i know but the thought only just occurred to me about the awning windows opening outwards when I was thinking about what screen to put on the balcony door today. That confirms my decision to put plantation shutters on those windows then, pretty them up on the inside. [/quote]All good. See pics of one of ours from an ensuite; We have plantations on ours. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote]Thanks for sharing! Looks very neat and something I'll likely do after handover. Who did u go through for these and were they expensive? Re: Building with Wisdom Homes 9136Feb 01, 2018 5:18 pm eagle1 Hi MandM+4, Do you know how many milimeters thickness your gyprock is for the walls and ceilings? No I don’t sorry, I didn’t realise it came in different thicknesses. I’ll have a look on site on the weekend. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 9137Feb 01, 2018 5:25 pm They have the sizes available of 10mm and 13mm for the walls and ceilings! I don't know what they are planning for my house but I didn't get to the gyprock stage yet. Please let me know when you find out the size of yours. Thank you Re: Building with Wisdom Homes 9138Feb 01, 2018 5:25 pm They have the sizes available of 10mm and 13mm for the walls and ceilings! I don't know what they are planning for my house but I didn't get to the gyprock stage yet. Please let me know when you find out the size of yours. Thank you Re: Building with Wisdom Homes 9139Feb 01, 2018 6:59 pm ASJ1981 doosra ASJ1981 Hi All, Our selections appointments are booked in for March! Was hoping to sneak in the air-con appointment somewhere in those two days but Ultra Air don't have any available appointments. I have asked her to send me brochures so we can have a look through them and a phone consultation may suffice instead of an on site meeting. Anyway, i just had a quick look on the brochures she sent and a lot of info but i was wanting something a bit more streamlined - ie the differences between the packages and the prices. My question is, did anyone upgrade? We only have 29 squares and i remember reading a post that 2 zones should suffice, taking into consideration that we are also getting ceiling fans in all the bedrooms and the leisure room. I do want to upgrade the downstairs outlet to a Linear one and will be placed in the kitchen's dropped ceiling. We upgraded to esp plus which also includes Wi-Fi which is a big bonus. We are building a 39sq and have no ceiling fans so we also went 4 zones. Esp plus is mor e energy efficient and It's our forever home so the saving in electricity should pay off. With 29sq and ceiling fans, u may not need to Thank you doosra. I was thinking the same, that we may not need to upgrade to the ESP. I am ok forking out for the Linear outlet upgrade. I am thinking whether to add the Wifi as well for convenience (on a really hot day, being able to turn on the air-con from your phone while driving home would be bliss and having your house already cold - haha!) The WiFi upgrade is worth every cent!!!!!! My favourite thing in our house. It’s been a god send this summer in the middle of the night to grab your phone, and turn it on a 30 minute timer!!!! Highly recommend! We didn’t upgrade, they told me it would take 7 years to “break even” on the additional cost for the air con system vs money saved on bills. Building Majestic 40 - wisdom homes Re: Building with Wisdom Homes 9140Feb 01, 2018 7:02 pm ASJ1981 I just checked my Contract Tender and it says "10-11 Outlets with 2 x Zones" For our Washington, do you think this setup is fine: Zone 1 - Master & Bedroom 4 (2 outlets) Zone 2 - Upper Lounge, Bedroom 2 & Bedroom 3 (3 outlets) Zone 3 - Dining, Kitchen & Leisure (4 outlets) Zone 4 - Office and Lounge-turned-Theatre room (2 outlets) Means we need an additional 2 zones, (but it sounds like 4 zones is overkill for only 29sq) OR should Zone 1 be upstairs and Zone 2 downstairs (Is 1 zone per floor enough?) Ahhh decisions decisions! You guys can see how much i struggle with these things! LOL! I can't even decide what coffee i want and i really need one right about now! That’s nearly what we have (40 squares though) Except upstairs we did master and upper rumpus together, and bedrooms 2,3,4 together but yes 4 zones all up Building Majestic 40 - wisdom homes Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18249 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73086 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8032 |
