Yes, we had the fan and wiring installed post handover.
Much easier process to have W do a provision for it, but it can be done post.
Browse Forums Building A New House Re: Building with Wisdom Homes 13060Oct 16, 2018 9:30 am becks81 ozmonkeyoy Unless W have changed the way they do it, it was pot luck for us as to where the plumbers put the taps - we had absolutely no choice about it. We have 3 taps in total (as standard), and per you pic, they put them in the same locations on our house apart from the tap near your outdoor leisure area (so we have just the one tap at rear of house. I guess if you pay for a hot/cold water point they will put it where you want. The front tap near the home office we have inside our side-gate, just so we have it as access for the side yard. It is also used as our central point for our Rainbird irrigation system. Bit disappointing to hear. Our CSR told me that we just negotiate with SS during construction, hope this is the case as my feeling is that we will need to look at the house in situ to make a decision. Quote "Outdoor taps 2 as standard and location will be nominated or chosen in construction with your site supervisor." Ensure that you bring it up early with your SS. We talked to ours, but was told that they place them in same positions on all builds, unless you pay W extra to nominate a particular position. I'm pretty sure the plumbers generally pick the corners of the houses and allocate the positions there. My experience is once in construction, the SS won't budge on very much at all, and will always relate back to the tender/plans and if you push harder they will send you back to HO to negotiate/pay more. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73525 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8242 |
