I believe they are plastic.
Browse Forums Building A New House Re: Building with Wisdom Homes 10541Apr 23, 2018 9:10 pm Chompy What are the downpipes made of? I believe they are plastic. Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 10542Apr 23, 2018 9:25 pm ajayshekar singalg @Jordann, did you only get provisions for downlights through W, and installed them yourself. If yourself, do you need an electrician to install them? I have got only provisions from W too. I plan to install myself. The provisions come as 3 pin socket. We just need to plug in the down light and push it in the cut out. So dont need an electrician. Building Ambassador 36 - Wisdom Homes Yep got provisioned with W, they will cut the hole and run the cables to it and terminate with a 3 pin socket. Just buy down lights which has the transformer and plug like below and plug it in yourself. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 10543Apr 23, 2018 11:13 pm Jordann ajayshekar singalg @Jordann, did you only get provisions for downlights through W, and installed them yourself. If yourself, do you need an electrician to install them? I have got only provisions from W too. I plan to install myself. The provisions come as 3 pin socket. We just need to plug in the down light and push it in the cut out. So dont need an electrician. Building Ambassador 36 - Wisdom Homes Yep got provisioned with W, they will cut the hole and run the cables to it and terminate with a 3 pin socket. Just buy down lights which has the transformer and plug like below and plug it in yourself. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is so helpful..could you please let me know How much does these cost?? And how much does W charge for only provision for downlights with 3 socket pin?? Re: Building with Wisdom Homes 10544Apr 23, 2018 11:36 pm champs2018 This is so helpful..could you please let me know How much does these cost?? And how much does W charge for only provision for downlights with 3 socket pin?? Think it was $70 or $75 for down lights provisioned. There's a few place you can get down lights, just have to shop around. These are my lights. https://www.lights2you.com.au/3a-13w-dl ... 050lm.html Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 10545Apr 24, 2018 7:08 am Jordann champs2018 This is so helpful..could you please let me know How much does these cost?? And how much does W charge for only provision for downlights with 3 socket pin?? Think it was $70 or $75 for down lights provisioned. There's a few place you can get down lights, just have to shop around. These are my lights. https://www.lights2you.com.au/3a-13w-dl ... 050lm.html Thanks Jordann Re: Building with Wisdom Homes 10546Apr 24, 2018 7:45 am Manhattan52 GLO Manhattan52 [quote="Funk52"]Has anyone selected the solar panels and Tesla battery storage instead of taking the $15k voucher? Looks like a good deal but I would hope that you receive a consultation to review your energy needs before having to decide on this. Agreed - We are doing ours after handover as the largest panels they could do was 6kw which would not generate enough power to use the battery at all. We are getting 15kw on the roof. A lot of people think if they have a battery it will solve all their bills but you need to have enough panels to make this work properly It’s really unfortunate as we would have preferred W to do it so it could be roughed in prior to completion for a much nicer look but not to worry. 15kw is pretty big. How did you determine what you can fit on your roof? Which panels are you getting? The guys doing my solar got a plan of my roof and have placed them on it to see what fits where and also any issue re shading etc My roof space is 360m2 so have plenty of room and I’m getting 325w LG panels. I will also be having 3 phase power hence the 15kw[/quote] Do you have the diagram of your roof with panel alignment? I'm building a Manhattan 44ens and think I can only fit 6-7kw along the garage side length (north facing) it's above the laundry/home theater and main living space. Re: Building with Wisdom Homes 10547Apr 24, 2018 1:35 pm ajayshekar - tiles to alfresco is an optional extra. we were quoted 2500. we opted out at the last minute because we were leaning towards extension of alfresco with decking. Now that the council said No to decking we will be looking at concrete alfresco until things sort out with council on what we can do and what not! Plan is to go for concrete extension with tiles and pergola after handover. Re: Building with Wisdom Homes 10548Apr 24, 2018 1:41 pm we have wisdom to do tiling to the alfresco as extra and then ask wisdom to do extra 20 m2 of concrete extension with matching tile. I have the alfresco area tiling with matching tile with the ground floor main floor tile. Re: Building with Wisdom Homes 10549Apr 24, 2018 1:44 pm aaron2008 @ajayshekar - tiles to alfresco is an optional extra. we were quoted 2500. we opted out at the last minute because we were leaning towards extension of alfresco with decking. Now that the council said No to decking we will be looking at concrete alfresco until things sort out with council on what we can do and what not! Plan is to go for concrete extension with tiles and pergola after handover. I was actually thinking of decking and extending the alfresco area now that W aren't tiling. Hope Blacktown council allow it. Building Ambassador 36 - Wisdom Homes Re: Building with Wisdom Homes 10550Apr 24, 2018 3:45 pm psur2357 - how much is extension costing you? ajayshekar - We are with Hills shire & the restriction is due to bushfire, so you will be alright. After handover and certificate etc, I don't think you need to approach council for decking as long as you compliance with the rules of step down. Re: Building with Wisdom Homes 10554Apr 24, 2018 3:52 pm psur2357 Chompy aaron2008 @chompy downpipes are made of PVC How are they coloured? spray paint on site Thanks psur Just checking - any risk of paint quality and deterioration. Perhaps I’m being overly cautious. Re: Building with Wisdom Homes 10555Apr 24, 2018 4:07 pm Chompy psur2357 Chompy [quote="aaron2008"]@chompy downpipes are made of PVC How are they coloured? spray paint on site Thanks psur Just checking - any risk of paint quality and deterioration. Perhaps I’m being overly cautious. [/quote] The downpipes have to be PVC because of the rainwater tank. Water sits in the pipes. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10556Apr 24, 2018 5:01 pm psur2357 we have wisdom to do tiling to the alfresco as extra and then ask wisdom to do extra 20 m2 of concrete extension with matching tile. I have the alfresco area tiling with matching tile with the ground floor main floor tile. How much does Wisdom charge for alfresco extension?? Our alfresco seems to be very small..planning to get extended as well...But we are also thinking of decking but may have to do it after handover Re: Building with Wisdom Homes 10557Apr 24, 2018 5:03 pm I got an extension of 9m x 3.5 and the extra cost was $38,450 Re: Building with Wisdom Homes 10558Apr 24, 2018 5:13 pm [quote="Manhattan52"]I got an extension of 9m x 3.5 and the extra cost was Decking works cheaper maybe.. gotta check that now..thanks Re: Building with Wisdom Homes 10559Apr 24, 2018 5:28 pm champs2018 psur2357 we have wisdom to do tiling to the alfresco as extra and then ask wisdom to do extra 20 m2 of concrete extension with matching tile. I have the alfresco area tiling with matching tile with the ground floor main floor tile. How much does Wisdom charge for alfresco extension?? Our alfresco seems to be very small..planning to get extended as well...But we are also thinking of decking but may have to do it after handover Extension with roof was about $1000 sqm when we did ours (same as internal extensions) Without roof would be much less majestic35.weebly.com Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8206 |
