Browse Forums Building A New House Re: Building with Wisdom Homes 13202Oct 24, 2018 8:01 pm Manhattan52 Stukip Anyone have any experience with AtoZ Demolitions based on Ryde NSW. Quote seems okay and just need to decide whether to lock it in. They are OK but not great. Would use someone else if you can. Wisdom recommends site demolition What would have made them great? Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Re: Building with Wisdom Homes 13203Oct 24, 2018 8:11 pm Stukip Manhattan52 Stukip Anyone have any experience with AtoZ Demolitions based on Ryde NSW. Quote seems okay and just need to decide whether to lock it in. They are OK but not great. Would use someone else if you can. Wisdom recommends site demolition What would have made them great?[/q Took 4 weeks when the said would take 2 Had to contact several times after job finished to come and pick up the rubbish they left behind Tree stumps that were in the quote to be removed weren’t touched. Had to get someone else to come and do it. Re: Building with Wisdom Homes 13204Oct 24, 2018 9:24 pm niles I have been going through the thread for some time and trying to finalise things, I got quotes from 2 different builders and for a similar square home , My land is slightly sloping but NOT more than 1 m and need a 'H1' class slab. i got my siting back from both and one of them said i would need deepened edge beams for about half the length of my home that is to hold the dirt that is being filled from cut portion. While other said i would not need any beams just the cut and fill can take care of it even more the expected ground level of is almost same the difference is few centimeters Now i am confused which is the better build in terms of design and durability, cut and fill with or without deepened edge beams i am in similar situation what do you guys reckon? Re: Building with Wisdom Homes 13205Oct 25, 2018 4:14 am becks81 Bathroom mirrors: can anyone comment on how these are fixed to the walls? We want to change them to mirrored shaving cabinets at a later stage, like in a few years, would this be doable? From what I’ve seen they’re glued to the tiles. We have a couple of them being replaced and it’s likely they will be done after handover so if I’m around to see them replace them I’m will have a look at how they get the old one off the wall for you. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 13207Oct 25, 2018 3:26 pm MIM11 Hi, does have anything to do with 1.5mm grout for the main area large tiles and probably grout for the other rooms? If so we’ve also been slugged for it? Hi, we have 1.5mm grout to our wet areas. These incur additional labour costs. Depending on your grout colour, it may have additional costs also. Re: Building with Wisdom Homes 13208Oct 25, 2018 6:16 pm Does this look like gas had been disconnected ready for demolition? Meter is gone but not sure what to expect.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Re: Building with Wisdom Homes 13210Oct 25, 2018 8:57 pm Jenifermarie becks81 Bathroom mirrors: can anyone comment on how these are fixed to the walls? We want to change them to mirrored shaving cabinets at a later stage, like in a few years, would this be doable? From what I’ve seen they’re glued to the tiles. We have a couple of them being replaced and it’s likely they will be done after handover so if I’m around to see them replace them I’m will have a look at how they get the old one off the wall for you. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thanks for that!! Re: Building with Wisdom Homes 13212Oct 26, 2018 7:53 pm congratulations on reaching this milestone Manhattan52. Really hope there is no stopping now and you get your dream house in one shot! Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 13214Oct 27, 2018 7:45 am Congratulations Manhattan52, it’s gonna go quick from here. Are you joining the pool with the slab or are they separated? Re: Building with Wisdom Homes 13215Oct 27, 2018 2:04 pm Magnus Congratulations Manhattan52, it’s gonna go quick from here. Are you joining the pool with the slab or are they separated? It’s all joined, bottom floor tiles, alfresco tiles, outside tiling past that and pool are all the same tiles just different texture Re: Building with Wisdom Homes 13216Oct 27, 2018 6:42 pm becks81 Bathroom mirrors: can anyone comment on how these are fixed to the walls? We want to change them to mirrored shaving cabinets at a later stage, like in a few years, would this be doable? Building Ambassador 41 Wisdom Homes DA 17 Jan 2018, Slab 19 Mar 2018, Frame 20 Apr 2018, Bricks 04-31 May 2018, Gyprock 13-19 Jul 2018, Stairs 23-27 Jul 2018, kitchen, bathroom tiles, downlights, Aircon 24 Aug 2018 [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 13217Oct 27, 2018 9:41 pm Kazi becks81 Bathroom mirrors: can anyone comment on how these are fixed to the walls? We want to change them to mirrored shaving cabinets at a later stage, like in a few years, would this be doable? Building Ambassador 41 Wisdom Homes DA 17 Jan 2018, Slab 19 Mar 2018, Frame 20 Apr 2018, Bricks 04-31 May 2018, Gyprock 13-19 Jul 2018, Stairs 23-27 Jul 2018, kitchen, bathroom tiles, downlights, Aircon 24 Aug 2018 Thank you, Kazi. Re: Building with Wisdom Homes 13218Oct 29, 2018 2:45 pm niles - I am 99% sure W quoted for drop edge. Its the right thing to do. Not an expert on the subject but did a bit of a research because we had cut and fill more than 1.5m. 1. One of the very strict council - Hills Shire allows cut and fill upto 1.5m, so I am guessing you will be alright without drop edge. 2. If you discuss this with your Sales person she will ask the back office expert to look at your plan from cut and fill point of view and offer you similar solution. I have read that this has happened before. 3. Every one building in NSW require an H1 slab because of the soil condition. 4. I would go for drop edge beams however in your case the cut n fill is less than 1m contact Sales and make an informed decision. Re: Building with Wisdom Homes 13219Oct 29, 2018 3:11 pm aaron2008 @niles - I am 99% sure W quoted for drop edge. Its the right thing to do. Not an expert on the subject but did a bit of a research because we had cut and fill more than 1.5m. 1. One of the very strict council - Hills Shire allows cut and fill upto 1.5m, so I am guessing you will be alright without drop edge. 2. If you discuss this with your Sales person she will ask the back office expert to look at your plan from cut and fill point of view and offer you similar solution. I have read that this has happened before. 3. Every one building in NSW require an H1 slab because of the soil condition. 4. I would go for drop edge beams however in your case the cut n fill is less than 1m contact Sales and make an informed decision. Thanks aaron2008 , did bit of homework once i posted the question and did find Drop edge beam is the right thing, my concerns was the cost and why the difference between 2 builders. Will try to have a informed decision as you have suggested. Re: Building with Wisdom Homes 13220Oct 29, 2018 4:32 pm aaron2008 @niles - I am 99% sure W quoted for drop edge. Its the right thing to do. Not an expert on the subject but did a bit of a research because we had cut and fill more than 1.5m. 1. One of the very strict council - Hills Shire allows cut and fill upto 1.5m, so I am guessing you will be alright without drop edge. 2. If you discuss this with your Sales person she will ask the back office expert to look at your plan from cut and fill point of view and offer you similar solution. I have read that this has happened before. 3. Every one building in NSW require an H1 slab because of the soil condition. 4. I would go for drop edge beams however in your case the cut n fill is less than 1m contact Sales and make an informed decision. aaron2008 We're getting an M class slab. May I ask how you know that everyone building in NSW requires H class? Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18885 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73934 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9200 |
