Welcome Man52
Extra Concrete Pump coming your way... Good Luck with it all.
Ask away we are a friendly bunch
Browse Forums Building A New House Re: Building with Wisdom Homes 8641Dec 13, 2017 8:15 am Manhattan52 haha yeah will cost a bit. Our tender/contract was $1.56m. I guess we are at early stages, waiting for the rest of quotes like Kitchen and Lansdcaping to come back. All that have come back so far have been ballpark what I expected so can't complain. Welcome Man52 Extra Concrete Pump coming your way... Good Luck with it all. Ask away we are a friendly bunch Re: Building with Wisdom Homes 8642Dec 13, 2017 8:18 am Manhattan52 Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Welcome! The house sounds like it will be a palace, looking forward to seeing it take shape. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 8643Dec 13, 2017 8:43 am MandM+4 Manhattan52 Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Welcome! The house sounds like it will be a palace, looking forward to seeing it take shape. Welcome Manhattan52! That is going to be one amazing house! Welcome to the forum. The best thing i did was find this thread! So much info and these guys are a wealth of knowledge and a very friendly bunch indeed! I had and STILL have a million and one questions and there's always someone that's available to answer and give great advice! Re: Building with Wisdom Homes 8644Dec 13, 2017 9:26 am doosra The fridge is not too close to a water fitting, but i think there may be a possible solution here. I could use the cold water fitting under the butler pantry sink. Then run the pipe from there through to Microwave then through to the Fridge area. I can hide the pipes under the butler pantry bottom shelf so it won't be visible. What do you guys think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Best to speak to a plumber to get their perspective and cost Re: Building with Wisdom Homes 8645Dec 13, 2017 9:30 am Manhattan52 Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Hi Manhattan52, We built the same house earlier this year, but definitely not to the grand scale that you are doing it to. Its a great design, and many ways to customise it to your own tastes and needs. Will be great to see it coming together, be sure to post updates. Even though we are finished building with Wisdom, I still hang around to see how the newer builds are progressing. Any questions, happy to help where I can. Oz. Re: Building with Wisdom Homes 8646Dec 13, 2017 11:26 am ozmonkeyoy doosra The fridge is not too close to a water fitting, but i think there may be a possible solution here. I could use the cold water fitting under the butler pantry sink. Then run the pipe from there through to Microwave then through to the Fridge area. I can hide the pipes under the butler pantry bottom shelf so it won't be visible. What do you guys think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Best to speak to a plumber to get their perspective and cost If you already have a plumbed fridge then finding an alternative way is best. If you dont already have the plumbed fridge then a non plumbed fridge is an option if it gets too hard and costly to run the pipes after handover Re: Building with Wisdom Homes 8647Dec 13, 2017 11:30 am calais ozmonkeyoy doosra The fridge is not too close to a water fitting, but i think there may be a possible solution here. I could use the cold water fitting under the butler pantry sink. Then run the pipe from there through to Microwave then through to the Fridge area. I can hide the pipes under the butler pantry bottom shelf so it won't be visible. What do you guys think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Best to speak to a plumber to get their perspective and cost If you already have a plumbed fridge then finding an alternative way is best. If you dont already have the plumbed fridge then a non plumbed fridge is an option if it gets too hard and costly to run the pipes after handover I need new appliances but have always had a plumbed fridge for ice and water. Can't bear myself to fill up ice cube trays all the time. It's okay though, the solution i proposed is easily achieved after handover and would cost me close to nothing to do. Just need to buy the hose and tap fittings and feed the hose so will probably pass on getting Wisdom to add it as it'll cost me a bomb. On the contract, it says 1k fee for non structural changes after contract signing. Re: Building with Wisdom Homes 8648Dec 13, 2017 11:40 am just got a call from Wisdom and they're allowing the variation of the fridge fitting and not charging me a building variation because it really is minor and we caught it early. Thank God...I need to sign a building variation and plans just need to be updated so slight delay but nothing major. I have to say i've been very impressed with the CSR Team Manager. My CSR initially said "too late" but then i forwarded it to her manager and now it's all sorted. Although i've had challenges and been very frustrated through this process, they've taken my complaints seriously and Team Manager specifically and also the GM have really gone above and beyond for me. Re: Building with Wisdom Homes 8649Dec 13, 2017 1:03 pm doosra just got a call from Wisdom and they're allowing the variation of the fridge fitting and not charging me a building variation because it really is minor and we caught it early. Thank God...I need to sign a building variation and plans just need to be updated so slight delay but nothing major. I have to say i've been very impressed with the CSR Team Manager. My CSR initially said "too late" but then i forwarded it to her manager and now it's all sorted. Although i've had challenges and been very frustrated through this process, they've taken my complaints seriously and Team Manager specifically and also the GM have really gone above and beyond for me. Great news! With the hydraulic blowout it’s the least they could do. Re: Building with Wisdom Homes 8650Dec 13, 2017 8:14 pm Manhattan52 Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Welcome aboard! There's a few of us building a Manhattan. It's a fantastic floorplan isn't it? We are also building a 52 (with significant changes) in Strathfield. We are up to the frame. Hoping to get that started before Christmas shutdown. Manhattan 52 Scrape 8/11/17 Slab 16/11/17 Handover 7/12/18 Re: Building with Wisdom Homes 8651Dec 14, 2017 8:18 am amf139 Manhattan52 Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Welcome aboard! There's a few of us building a Manhattan. It's a fantastic floorplan isn't it? We are also building a 52 (with significant changes) in Strathfield. We are up to the frame. Hoping to get that started before Christmas shutdown. Hi amf139, how long now since your slab was poured? Ours was done yesterday (yippee!) but I’m guessing that will be it for us till next year. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 8652Dec 14, 2017 9:55 am ChizCake amf139 Manhattan52 Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Welcome aboard! There's a few of us building a Manhattan. It's a fantastic floorplan isn't it? We are also building a 52 (with significant changes) in Strathfield. We are up to the frame. Hoping to get that started before Christmas shutdown. Hi amf139, how long now since your slab was poured? Ours was done yesterday (yippee!) but I’m guessing that will be it for us till next year. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Congrats! I was about to ask the same question. Our slab was completed on the 30 Nov and there has been no action since then. I didn't expect anything would happen until the new year. Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 8653Dec 14, 2017 12:46 pm lombieagle ChizCake amf139 [quote="Manhattan52"]Hi All, I just wanted to say Hi and to thank you you all for your invaluable information. We are building a Manhattan 52 with the Diplomat facade the same as Oran parks Display home with a few changes and a third garage as a KDRB in Turramurra on 2200m2. We have also extended the outdoor area by another 60m2 wrapping it around the dining room and getting pool and landscapes done by WH. I had my appointments a few weeks ago and just waiting for the remainder of the quotes to come in. i don't hold much hope as everything is upgraded or specified differently to what WH offer. Luckily we are going through CDC as Kuringai Council is notorious for delays. anyway just wanted to say how helpful you have all been and hope to share with you my build both good and bad Welcome aboard! There's a few of us building a Manhattan. It's a fantastic floorplan isn't it? We are also building a 52 (with significant changes) in Strathfield. We are up to the frame. Hoping to get that started before Christmas shutdown. Hi amf139, how long now since your slab was poured? Ours was done yesterday (yippee!) but I’m guessing that will be it for us till next year. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Congrats! I was about to ask the same question. Our slab was completed on the 30 Nov and there has been no action since then. I didn't expect anything would happen until the new year.[/quote] Our slab was poured a month ago. We were supposed to be getting a small amount of landscaping at the rear done before frames, but the plumbing people (external plumbing) accidentally knocked a electricity power wire that belongs to our neighbour but crosses over our driveway.... so 9 days later we are still waiting for any action. An email this morning informs us we are responsible for arranging tiger tails, which I have now done. So I doubt we will get our frame up by Christmas shutdown as was first promised. The frustration level is still high! Manhattan 52 Scrape 8/11/17 Slab 16/11/17 Handover 7/12/18 Re: Building with Wisdom Homes 8655Dec 15, 2017 11:22 am MandM+4 For those ahead of me, when does the temporary fencing come down? TIA Mine didn't come down until a few days before handover. Re: Building with Wisdom Homes 8656Dec 15, 2017 11:31 am It's glad to receive the call from WS to be noticed our DA has been logged into Council already. It's lucky to log in before Christmas. We might be getting the feedback on Feb 2018. But anyway, it means our house project is keeping to move forward Re: Building with Wisdom Homes 8657Dec 15, 2017 11:42 am MandM+4 For those ahead of me, when does the temporary fencing come down? TIA How did your bricks turn out after being cleaned? Are you happy with it? Any close up pics? Cheers!!! Re: Building with Wisdom Homes 8658Dec 15, 2017 11:48 am Chinoandbebe MandM+4 For those ahead of me, when does the temporary fencing come down? TIA How did your bricks turn out after being cleaned? Are you happy with it? Any close up pics? Cheers!!! Yes they look great! I haven’t taken pics as yet but will post when I do Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 8659Dec 15, 2017 12:59 pm MandM+4 Chinoandbebe MandM+4 For those ahead of me, when does the temporary fencing come down? TIA How did your bricks turn out after being cleaned? Are you happy with it? Any close up pics? Cheers!!! Yes they look great! I haven’t taken pics as yet but will post when I do Ours went down just b4 handover Re: Building with Wisdom Homes 8660Dec 15, 2017 4:39 pm MandM+4 For those ahead of me, when does the temporary fencing come down? TIA Yeah ours was about a week before handover too! How come? Building Majestic 40 - wisdom homes Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73522 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8241 |
