Browse Forums Building A New House Re: Building with Wisdom Homes 11721Aug 02, 2018 9:39 am We are with NAB and they are pretty good. We had some issue with W making a hugh mistake in $$ figure from draft end panel & end panel.Following which NAB had to do the entire process of accessing us for loan. They did it in record time resulting no delay in construction. Their payments to W is on time within 7 days. Re: Building with Wisdom Homes 11722Aug 02, 2018 10:49 am aaron2008 We are with NAB and they are pretty good. We had some issue with W making a hugh mistake in $$ figure from draft end panel & end panel.Following which NAB had to do the entire process of accessing us for loan. They did it in record time resulting no delay in construction. Their payments to W is on time within 7 days. That is great to know. I agree, have been dealing with NAB and i can not fault them. Even with the Progress Payment issue, they were great to deal with and extremely professional. The Progress Payment issue i had yesterday was resolved on the same day. I did panic in the morning when my CSR wouldn't agree to NAB's proposal. NAB's proposed schedule seemed fair and reasonable to me so i didn't think it would be a huge issue. Especially after doing some online research, it seems most if not all the banks have a maximum of 20% for the Slab Completion. From what i read on this thread, a few have had issues too and WH wouldn't budge so i immediately panicked thinking this is going to be a long drawn out process which i really did not want to deal with. I am glad my Home Lending Manager agreed to it. But more so, i am glad my CSR amended it to satisfy NAB's Lending Criteria. Re: Building with Wisdom Homes 11723Aug 02, 2018 12:28 pm Hi guys, Our land is about to register any time now. I am assuming my CSR would have requested a Survey/Contour Plan (well hopefully she has!). I am just going through some things to get my head around any potential issues we may face in regards to Additional Site Costs or what not and i just noticed the following (refer to my pic) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - site plan from Wisdom Homes has E1 "Easement to Drain Water 1.0m wide" BUT - estate master plan shows E4 "Easement for access and maintenance 0.9m wide" I am not familiar with all of these things - i can only google so much Is this something i need to look out for / be aware of? I am sure all this would be picked up in Survey. Can anyone tell me or advise me of any potential issues i need to know? Lastly, as you can see from the estate master plan, my Lot 2266 has a sewer line at the back fence boundary. Rear setback is 9.8m. Do you guys think this would be an issue in regards to Zone of Influence? Or should i not worry... Sorry if my lingo doesn't make sense. I just pick up from posts here and there TIA!! Re: Building with Wisdom Homes 11724Aug 02, 2018 12:50 pm ASJ1981 Hi guys, Our land is about to register any time now. I am assuming my CSR would have requested a Survey/Contour Plan (well hopefully she has!). I am just going through some things to get my head around any potential issues we may face in regards to Additional Site Costs or what not and i just noticed the following (refer to my pic) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - site plan from Wisdom Homes has E1 "Easement to Drain Water 1.0m wide" BUT - estate master plan shows E4 "Easement for access and maintenance 0.9m wide" I am not familiar with all of these things - i can only google so much Is this something i need to look out for / be aware of? I am sure all this would be picked up in Survey. Can anyone tell me or advise me of any potential issues i need to know? Lastly, as you can see from the estate master plan, my Lot 2266 has a sewer line at the back fence boundary. Rear setback is 9.8m. Do you guys think this would be an issue in regards to Zone of Influence? Or should i not worry... Sorry if my lingo doesn't make sense. I just pick up from posts here and there TIA!! I don't believe you have anything to worry about. You house is 1,180 from the boundary which is more than the 900 requirement. I'm not too fimilar with zone of influence however this is relating to building above or close to sewer line. Your house sits well away from it. Wisdom complete survey/contour plans as part of their tender process. Excitement must be building now that land registration is so close. good luck Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 11725Aug 02, 2018 12:50 pm ASJ1981 Hi guys, Our land is about to register any time now. I am assuming my CSR would have requested a Survey/Contour Plan (well hopefully she has!). I am just going through some things to get my head around any potential issues we may face in regards to Additional Site Costs or what not and i just noticed the following (refer to my pic) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - site plan from Wisdom Homes has E1 "Easement to Drain Water 1.0m wide" BUT - estate master plan shows E4 "Easement for access and maintenance 0.9m wide" I am not familiar with all of these things - i can only google so much Is this something i need to look out for / be aware of? I am sure all this would be picked up in Survey. Can anyone tell me or advise me of any potential issues i need to know? Lastly, as you can see from the estate master plan, my Lot 2266 has a sewer line at the back fence boundary. Rear setback is 9.8m. Do you guys think this would be an issue in regards to Zone of Influence? Or should i not worry... Sorry if my lingo doesn't make sense. I just pick up from posts here and there TIA!! I would send an email to your CSR just to highlight that easement is incorrect. Because it’s a bigger easement than it needs to be it shouldn’t be an issue but if they don’t fix it before you get your building approvals, it might delays those if the plans have to be fixed then. We had to have our plans amended during the approval process which added a couple of weeks on. It was something I had pointed out 2 months before as well where there had been a CDC requirements change and the plans didn’t show a ratio for something (I forget what now) I don’t think the sewer line will be an issue. We have one about 3m from the front of our house and it didn’t fall in the zone of influence. They should add that to your plans once they have requested and completed a sewer/water survey of the lot. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 11726Aug 02, 2018 1:04 pm Thank you for the replies lombieagle and jenifermarie! I really appreciate it. Sometimes i surprise myself with the things i pick up I don't consider myself "in the know" when it comes to these things but i just noticed it this morning when updating my spreadsheet! I was fairly confident about the sewer line not being in the zone of influence (i had to google this, Sydney Water had a diagram) so i sort of knew we were safe and wouldn't need to worry about it. I might wait till next week to bring it up with CSR as we had a LOT of emails going back and forth yesterday with regards to Progress Payments so i might give her a bit of a breather from me - haha! At least now i know, when we do get the Survey back, the first thing i will make sure of is that the plans reflect the correct Easement. lombieagle - yes it is exciting, land registration is ahead of schedule which was a great surprise! jenifermarie - my CSR told me that she would send me my plans to review prior to her submitting to Council, so this would be one of the first things i'll check! Thank God for this thread. Thanks again! Re: Building with Wisdom Homes 11727Aug 02, 2018 11:02 pm GLO becks81 doosra My build was granit guard Granit Guard was in our tender. We actually didn’t think about it. It made sense when we looked into it plus it sounded cheaper than reticulated, given you don’t need to top up the chemical. Do you still need yearly inspections with granit guard? And did you put for it, or simply take the WH recommendation? It was in our tender in lieu of standard and we didn’t ask for it. What is standard termite protection anyway? The cost in our tender is $550 Re: Building with Wisdom Homes 11728Aug 03, 2018 7:35 am I have no idea about termite systems, but can i ask, which one is best and which one cost more? They used Granit Guard for me, but on my end panel, it says "Reticulated termite treatment system to the perimeter of the home" Re: Building with Wisdom Homes 11729Aug 03, 2018 11:18 am thanks, they are different products that i believe are both supplied by Flick Pest control. Not sure of the price difference. Im still keen to know if there is a preference between the options. Re: Building with Wisdom Homes 11730Aug 03, 2018 4:07 pm GLO spk_homebuild GLO What termite protection is everyone selecting? Reticulated System (poison recharge every 3 years) Granit Guard (set and forget) HomeGuard (under slab protection) Termimesh (weep hole physical protection) I’m building in Bardia and apparently the local Flick pest control advised that there are no known termite reports in the area. He was installing a Reticulated System. But keen to get everyone’s thoughts/experiences!!! I'm led to believe that the chemical top up is done under high pressure and done every 3years at a cost of circa $400. I'm 17 Years in my 30yo home with no known Termite protection or developing termite issues. We had asked for Term Guard or Granit Guard which doesn't need this every 3 year process and the added costs, but our colours consultant told us that W only had Reticulated system Am not sure if we were misinformed then or W started supporting others after we had our contract. Whatever is the case I would suggest you are better of with any choices that are advanced and don't have regular maintenance even if it is an upfront cost. http://www.thecomingbackhome.com/Blog/blog/ Re: Building with Wisdom Homes 11731Aug 03, 2018 9:30 pm Does anyone know if having bullnose tread and riser is an upgrade? I don't remember requesting it, but it's in our quote. From the diagram, it looks like the rail starts behind the first step, rather than in front. Is bullnose tread and riser meant to be more aesthetically pleasing? Re: Building with Wisdom Homes 11732Aug 04, 2018 1:22 pm Hi all, Has anyone build a Wisdom home where the bedroom windows that sit high and are long and skinny? Similar to the picture attached. If so how do you find the natural light? I am concerned the room will be dark. Re: Building with Wisdom Homes 11733Aug 04, 2018 5:48 pm MIM11 Hi all, Has anyone build a Wisdom home where the bedroom windows that sit high and are long and skinny? Similar to the picture attached. If so how do you find the natural light? I am concerned the room will be dark. I cant see your picture, but I am having that in our master bedroom as well as the upstairs kids retreat (above the TV) In both instances, there are large sliding doors or large windows that will add natural light. Re: Building with Wisdom Homes 11734Aug 04, 2018 6:00 pm MIM11 Hi all, Has anyone build a Wisdom home where the bedroom windows that sit high and are long and skinny? Similar to the picture attached. If so how do you find the natural light? I am concerned the room will be dark. We have high windows in 3 of the bedrooms and our media room. They are still quite big windows. Don’t need to turn lights on during the day, even with a south facing window. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 11735Aug 04, 2018 6:43 pm GLO thanks, they are different products that i believe are both supplied by Flick Pest control. Not sure of the price difference. Im still keen to know if there is a preference between the options. I took these pics today of my neighbours build. This is what a Reticulated System looks like before it gets buried. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’m still unsure which way to go, but I’m thinking of adding a rock strip like in this photo. (From Manhattan 44 Ens Display home Oran Park) and thinking about adding French drains around the perimeter to reduce water pooling around the slab and causing Slab cancer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ See: https://youtu.be/Dr53xIPE5n0 It looks pretty cost effective and removes water saturation of the solid around the slab. https://www.bunnings.com.au/vinidex-65mm-x-20m-draincoil-with-filter-sock_p4770255 Think that’s worth doing? Re: Building with Wisdom Homes 11737Aug 04, 2018 8:41 pm GLO Has anyone used solid colour bricks? Seem like more and more bricks are painted!?!? Do the brick choices changed or are they always available? We opted for solid bricks. Once I see a little thing that is wrong, I can never unsee it so any small chip on a painted brick would have annoyed me forever. Ours are Austral Freedom which are in the base range. It was tough to pick with so few solid bricks choices unless we wanted to pay a fortune to upgrade but we’re really happy with how the colours have come out. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 11738Aug 05, 2018 10:57 am Hi everyone, Hope you are all having a lovely Sunday so far... I have a question for those who have build blogs. I am thinking of doing one. Have been for awhile now. But time is not always on my side. However, I love the whole idea of it and sharing info etc. I use Insta as my visual diary and I think building blog is just that extra outlet that I need! I guess my question is, how hard is it to build one? I would imagine a lot of time invested as well... any tips would be appreciated. I already follow some of your blogs and find it extremely useful and love reading progress stories! Please DM me for any tips THANK YOU! Re: Building with Wisdom Homes 11739Aug 05, 2018 11:02 am ASJ1981 Hi everyone, Hope you are all having a lovely Sunday so far... I have a question for those who have build blogs. I am thinking of doing one. Have been for awhile now. But time is not always on my side. However, I love the whole idea of it and sharing info etc. I use Insta as my visual diary and I think building blog is just that extra outlet that I need! I guess my question is, how hard is it to build one? I would imagine a lot of time invested as well... any tips would be appreciated. I already follow some of your blogs and find it extremely useful and love reading progress stories! Please DM me for any tips THANK YOU! Use blogger! Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18678 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73723 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8690 |
