10 days between PCI date and Handover date. No, not all issues were fixed, in fact barely half were done but we were ok to get them fixed in the following weeks.
Browse Forums Building A New House Re: Building with Wisdom Homes 16036Nov 24, 2020 10:18 am MANHATTAN1 See below the image of the alfresco concrete slab and brickwork. The gap between the brick and the slab is 45mm and the top of the brick sits approx. 35mm higher than the slab. Just wondering if this is consistent with other builds? I am planning to tile the alfresco so to me this seems problematic. Keen for your thoughts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ That’s consistent to the build. We put tiles in the alfresco and it works out. What type of flooring will you use? Re: Building with Wisdom Homes 16037Nov 24, 2020 11:04 am Ok thanks we have confirmed the same today with SS who has been very helpful with a solution- we are planning to screed and use travertine. Re: Building with Wisdom Homes 16038Nov 25, 2020 12:07 pm Hi Everyone, Does anyone know, if we have to do a pest control before we move in?. The contract includes a clause that indicate we have to make pest control each year to avoid warranty issues. If so when do you do it before hand over (when house is empty) or after move in? Cheers Re: Building with Wisdom Homes 16039Nov 25, 2020 1:06 pm malypetu Hi Everyone, Does anyone know, if we have to do a pest control before we move in?. The contract includes a clause that indicate we have to make pest control each year to avoid warranty issues. If so when do you do it before hand over (when house is empty) or after move in? Cheers I would be interested to know too, however every time I have moved house I have always had pest control in before I have even moved furniture in, I hate bugs Re: Building with Wisdom Homes 16040Nov 25, 2020 1:46 pm JasmanC malypetu Hi Everyone, Does anyone know, if we have to do a pest control before we move in?. The contract includes a clause that indicate we have to make pest control each year to avoid warranty issues. If so when do you do it before hand over (when house is empty) or after move in? Cheers I would be interested to know too, however every time I have moved house I have always had pest control in before I have even moved furniture in, I hate bugs Yeah I thought so too. I'm also under the assumption the pest control should be done inside and outside, right? Any recommendations on this? Just a side note. We are approaching the PCI (Practical Completion Inspection), I've found this site https://anewhouse.com.au/ where it provide a good document ($4) with recommendations to carry out the PCI and thoroughly check the construction. In my case I have Houspect to do the inspection but for anybody doing it on their own, this will give you lots of good advice. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8206 |
