Browse Forums Building A New House Re: Building with Wisdom Homes 15164Oct 22, 2019 9:19 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15165Oct 22, 2019 9:29 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15167Oct 22, 2019 10:11 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15169Oct 22, 2019 4:52 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15173Oct 23, 2019 10:42 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15174Oct 23, 2019 10:45 am ASJ1981 What a shame some people have to ruin this friendly Wisdom Homes thread. It's become annoying to read and follow. It's come to the point where I've had to delete my blog links on here. Here is hoping Homeone Forum administrators approve my request to deactivate my account. Please dont leave the forum. I personally love hearing about your build and looking at your photos. I have followed your build since the early design phases and your colour selections and you have provided some really good insights as well for others to learn from Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15175Oct 23, 2019 12:12 pm ASJ1981 Ditto for me! Please don’t leave the forum. I have also followed your posts with interest, i have appreciated your sharing of aspects of your build to help others, and the good advice you have generously provided. Open, positive, supportive advice and healthy discussion is what this forum is all about! Lets all continue this engagement!😀 Re: Building with Wisdom Homes 15176Oct 23, 2019 12:50 pm Please let us not to stop our productive forum because we encounter a problem. This is exactly the way it should be, we encouter problems and we solve them in order to achieve our collective objective of having our dream home. I personally love to see the progress of each and every one of you and to learn and share experiences. If on top of that we get to see your blogs with pictures of the progress is a big encouragement. Re: Building with Wisdom Homes 15177Oct 23, 2019 1:25 pm Designer Facade (With or without balcony) Anyone done colours that are different from Wisdom brochures and display homes?? How much rendering have you done? Some, all?? What sort of dollars did you spend to render? Is it robust? The pillars are tall and thin, has anyone had cracked rendering? Got to love building on clay in Sydney!! Any opinions, and thoughts, please share. Re: Building with Wisdom Homes 15178Oct 23, 2019 1:32 pm BigD Designer Facade (With or without balcony) Anyone done colours that are different from Wisdom brochures and display homes?? How much rendering have you done? Some, all?? What sort of dollars did you spend to render? Is it robust? The pillars are tall and thin, has anyone had cracked rendering? Got to love building on clay in Sydney!! Any opinions, and thoughts, please share. Quick technical answer: you're correct, if they use a sand and cement render with a paint finish it will end up cracking ( that's around $55/qm) but if they use an acrylic render such as Rockcote or Acrotex for $65-$70/sqm its highly unlikely to crack. So really depends on which method Wisdom uses. Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15179Oct 23, 2019 1:55 pm Hi Does anybody know how much extra will cost to have floorboards on the living/dining room and tiles on the kitchen floor? I understand there will have to be a sort of level adjustment due to different hight between tiles and floorboards and will attract an extra cost. Also if you can tell me how much it cost to have a color schema for the walls. I understand the inclusions allow the house to be painted only in a single color and every extra color will attract charges, but I don't know how much it will be/. Re: Building with Wisdom Homes 15180Oct 23, 2019 2:12 pm malypetu Hi Does anybody know how much extra will cost to have floorboards on the living/dining room and tiles on the kitchen floor? I understand there will have to be a sort of level adjustment due to different hight between tiles and floorboards and will attract an extra cost. Also if you can tell me how much it cost to have a color schema for the walls. I understand the inclusions allow the house to be painted only in a single color and every extra color will attract charges, but I don't know how much it will be/. with careful material selection you should be able to get your tiles and timber to sit flush. Typically engineered timber is 14-15 mm which you can either direct glue or lay on a 5mm rubber underlay A reasonable quality brand will set you back $120/sqm laid. Tiles are generally 10-12mm thick and you can have your tiler lay them on a screed which can be any thickness you like to match up to the height of the timber. You can get a nice large format tile for $50-60/sqm and tiling will cost roughly the same. So if you budget $120/sqm for everything you will be fine Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18460 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73443 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8233 |
