Once tiling is complete he will have a rough idea.
Browse Forums Building A New House Re: Building with Wisdom Homes 15084Oct 12, 2019 9:33 am Manhattan52 becks81 Can the unpainted/unstained front door and architrave take much rain? Our porch roof is not in place yet and there’s a large puddle of water at the threshold. Looks like our garage door went on today! If anything is damaged they will replace completely Thank you Manhattan52. I was hoping the rain would not make me anxious at this point in the build but we also still have 2 windows missing which also allows the rain in. Re: Building with Wisdom Homes 15085Oct 12, 2019 12:33 pm Ninsta Hi guys, quick question. We have just had our floor tiles laid on our ground floor and were surprised to see that the skirting boards were left on and the tiles have just been butted up against them. Well not completely as we have come across some inconsistent gaps! 1) is this standard? We assumed tiles first then skirting boards. 2) doesn’t this defeat the purpose of the higher skirting boards you get as an upgrade? Hi Ninsta, Great question! So a few things, are the tiles hard up to the skirting or is there a 4mm gap? the reason I ask is because tiles, as weird as this sounds expand and contract. This means if they are hard up to the skirting they will push the wall or pop the tiles up either way not great. Most of the time a small gap is left between the skirting and the tile then filled with a colour matched silicone hiding the gap By Australian standards, you can not go more than 4.5m in any direction without having an expansion joint. Most of the time they will hide it in a grout joint again using silicone. Now the reason they do the skirting first is if you have tiles down the hallway in to an open carpet theatre or rumpus the skirting will be a different height than the carpet area will be hard on the slab and the skirting on the tiles will be higher by 16mm depending on the thickness of the tile and glue Hope this helps www.bespokebuildingconsultants.com.au @bespokebuildingconsultants Re: Building with Wisdom Homes 15087Oct 12, 2019 2:22 pm melindaz how is everyone going?we only have landscaping left, take too long to wait for the landscaping people! Melindaz, You are almost there. Is WH completing your landscaping work? I’m at wet area tiling stage now. WH will be doing most of my landscaping work too. Re: Building with Wisdom Homes 15088Oct 12, 2019 2:25 pm Femstar melindaz how is everyone going?we only have landscaping left, take too long to wait for the landscaping people! Melindaz, You are almost there. Is WH completing your landscaping work? I’m at wet area tiling stage now. WH will be doing most of my landscaping work too. Our landscaping has also started. We had wet fit out last week although not a lot of progress the last fortnight. Re: Building with Wisdom Homes 15089Oct 12, 2019 8:07 pm Femstar melindaz how is everyone going?we only have landscaping left, take too long to wait for the landscaping people! Melindaz, You are almost there. Is WH completing your landscaping work? I’m at wet area tiling stage now. WH will be doing most of my landscaping work too. What size is your build, Femstar? We’re building a 41+ and you seem a few weeks ahead of us. Have you been given a date? The end is in sight!! Re: Building with Wisdom Homes 15090Oct 12, 2019 8:33 pm becks81 Femstar melindaz how is everyone going?we only have landscaping left, take too long to wait for the landscaping people! Melindaz, You are almost there. Is WH completing your landscaping work? I’m at wet area tiling stage now. WH will be doing most of my landscaping work too. What size is your build, Femstar? We’re building a 41+ and you seem a few weeks ahead of us. Have you been given a date? The end is in sight!! Hi Becks81, we are building the Monte Carlo 42 ensuite. WH home still don’t want to commit any dates until when the fixtures are ordered and confirmed all in stock. I think we are both in almost same stage. Re: Building with Wisdom Homes 15091Oct 13, 2019 7:32 pm Bespokebuilding Ninsta Hi guys, quick question. We have just had our floor tiles laid on our ground floor and were surprised to see that the skirting boards were left on and the tiles have just been butted up against them. Well not completely as we have come across some inconsistent gaps! 1) is this standard? We assumed tiles first then skirting boards. 2) doesn’t this defeat the purpose of the higher skirting boards you get as an upgrade? Hi Ninsta, Great question! So a few things, are the tiles hard up to the skirting or is there a 4mm gap? the reason I ask is because tiles, as weird as this sounds expand and contract. This means if they are hard up to the skirting they will push the wall or pop the tiles up either way not great. Most of the time a small gap is left between the skirting and the tile then filled with a colour matched silicone hiding the gap By Australian standards, you can not go more than 4.5m in any direction without having an expansion joint. Most of the time they will hide it in a grout joint again using silicone. Now the reason they do the skirting first is if you have tiles down the hallway in to an open carpet theatre or rumpus the skirting will be a different height than the carpet area will be hard on the slab and the skirting on the tiles will be higher by 16mm depending on the thickness of the tile and glue Hope this helps http://www.bespokebuildingconsultants.com.au @bespokebuildingconsultants Thank you for the reply! We were concerned as some of the gaps were inconsistent - some a couple mm, some definitely over 4mm. We don’t have any open spaces onto carpet as we have doors in the media. It’s just frustrating as spoke to 3 different people about wanting the skirting boards on top. Building Wisdom Homes Majestic 35 Re: Building with Wisdom Homes 15092Oct 13, 2019 8:01 pm My biggest piece of advice would be grab a few photos, draft up an email raising your concerns that way there is a digital footprint everyone can trace. And if you tiles pop or become “drummy” you have a leg to stand on Apologies this advice is a little late By chance do you have a email conversation about the skirting been up by chance? If there is anything else please don’t hesitate to reach out! Regards, Dan Www.bespokebuildingconsultants.com.au @bespokebuildingconsultants Re: Building with Wisdom Homes 15093Oct 14, 2019 9:56 pm Yes,we use wisdom to complete the landscaping, site has been cleaned and fence on , just wait for garden bed ,letter box and turf on ! And drive way should be done this week Femstar melindaz how is everyone going?we only have landscaping left, take too long to wait for the landscaping people! Melindaz, You are almost there. Is WH completing your landscaping work? I’m at wet area tiling stage now. WH will be doing most of my landscaping work too. Re: Building with Wisdom Homes 15094Oct 16, 2019 3:10 pm Hi All I am curious about something which might seem minor but has annoyed me to no end this week. Were any of you asked at any stage where you wanted your garden taps to be located before your job was released to site? Re: Building with Wisdom Homes 15095Oct 16, 2019 3:12 pm Sorry me again. Has anyone had an independent inspector come back with a mile long list of framework defects? How was it handled? How was it rectified? When was it rectified (in comparison to receiving the framework invoice)? Re: Building with Wisdom Homes 15096Oct 16, 2019 3:23 pm The defects should be rectified before the stage invoice is paid, and they are covered up with plaster and brickwork etc. Work must be done to buiding code standards or it is defective and incomplete. Check your contract carefully for the appropriate procedure to dispute the invoice is payable. get them to fix the frame defects before they cover them up. You will need to inspect carefully again after they claim they have fixed things. Don't believe what they say... Re: Building with Wisdom Homes 15097Oct 16, 2019 3:40 pm Teezed Sorry me again. Has anyone had an independent inspector come back with a mile long list of framework defects? How was it handled? How was it rectified? When was it rectified (in comparison to receiving the framework invoice)? Hi Teezed, Try contacting the builder explaining why you are not paying the stage claim until it is rectified. Getting a written response back from them is the best cover you can have. This way you will have something in writing if the worst does happen And if the inspector should offer a return to the site to make sure his list is complete. hopefully, they are cosmetic defects not structural. Please let us know if we could help in any way! Regards, Dan. www.bespokebuildingconsultants.com.au @bespokebuildingconsultants Re: Building with Wisdom Homes 15098Oct 16, 2019 3:44 pm Norfolk The defects should be rectified before the stage invoice is paid, and they are covered up with plaster and brickwork etc. Work must be done to buiding code standards or it is defective and incomplete. Check your contract carefully for the appropriate procedure to dispute the invoice is payable. get them to fix the frame defects before they cover them up. You will need to inspect carefully again after they claim they have fixed things. Don't believe what they say... Thank you for your advice. We are meeting with our SS tomorrow and I will advise him that we will not be paying the framework invoice until the defects are rectified. Re: Building with Wisdom Homes 15099Oct 16, 2019 3:45 pm Bespokebuilding Teezed Sorry me again. Has anyone had an independent inspector come back with a mile long list of framework defects? How was it handled? How was it rectified? When was it rectified (in comparison to receiving the framework invoice)? Hi Teezed, Try contacting the builder explaining why you are not paying the stage claim until it is rectified. Getting a written response back from them is the best cover you can have. This way you will have something in writing if the worst does happen And if the inspector should offer a return to the site to make sure his list is complete. hopefully, they are cosmetic defects not structural. Please let us know if we could help in any way! Regards, Dan. http://www.bespokebuildingconsultants.com.au @bespokebuildingconsultants Thank you for your advice. I will be advising in writing that we require the defects to be rectified before we will be paying the framework invoice. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18466 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73474 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8235 |
