Browse Forums Building A New House Re: Building with Wisdom Homes 14976Sep 08, 2019 5:19 pm sv_reddy Hi, Have any of you gone with slimline rain water tank? if yes, what are the costs and what is the size? Our council requirement is to have 3000 ltr tank. Thanks for us 3000L slimline tank was part of base price, we had to upgrade to 5000L for ~1.8K Re: Building with Wisdom Homes 14977Sep 08, 2019 10:17 pm Ambassador36 Manhattan52 Ambassador36 Hi guys! How did you organise your landscaping around the build? Did you need to excavate the site after slab went down? Did anyone go with wisdom for landscaping or did you go privately and if private how was wisdom with giving you access? I am using Wisdom Landscapes. If you go privately you will need to do work either before Wisdom takes control of your site or after handover. You won’t have access during Yes you are correct, Wisdom confirmed no site access before or during build. We have decided to still do after handover as I have a few local landscaper prelim quotes for much more wallet friendly costs. We are only after very standard levelling and turf at this point due to budget constraints Before wisdom fences the site. Do any earth work or excavation even if minimal leveling, as it’s easier before if you don’t have a lot off access up the sides. Re: Building with Wisdom Homes 14978Sep 09, 2019 7:53 am We noticed that our outdoor leisure stacking door is shorter than all our ground floor doors. We got to know the height difference only in construction plan door schedule. If we increase it now, will it be a variation and need DA approval? Is that a structural change? Re: Building with Wisdom Homes 14979Sep 09, 2019 8:28 am champs2018 We noticed that our outdoor leisure stacking door is shorter than all our ground floor doors. We got to know the height difference only in construction plan door schedule. If we increase it now, will it be a variation and need DA approval? Is that a structural change? Hi Champs, Yes, we had to increase all our door and window heights before tender, but there is no harm in checking though! Reach out to CSR and check what the requirements are. They don't let you know these things though, we only thought of it when our friend had overlooked this when increasing the ceiling height, we had to learn from their mistake unfortunately. Good luck! Re: Building with Wisdom Homes 14980Sep 09, 2019 9:39 am champs2018 We noticed that our outdoor leisure stacking door is shorter than all our ground floor doors. We got to know the height difference only in construction plan door schedule. If we increase it now, will it be a variation and need DA approval? Is that a structural change? For the leisure door, apart from checking the height, we also checked how that height compares with the window in that area (dinning, rumpus, etc). we wanted the top of that door to be at a similar level with the top of the other windows in the same space so it looks more uniform. just more points for you to consider Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73525 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8242 |
