We have 18 panels @ 5kW and the battery capacity is 13.5kWh.
Will send through some photos soon. Still working through the unpacking etc. very happy with the place, few minor issues but nothing which can't wait until maintenance
Browse Forums Building A New House Re: Building with Wisdom Homes 14831Jul 09, 2019 5:30 pm sv_reddy Hi again, We really like the upgraded kitchen bench stones and are looking at statuario maximus, we are building an ambassador if at all able to stretch our already stretch budget! Does anyone have indicative costs of this upgrade or alternatively the white attica in the mid range? We are also doing the waterfall edge on the kitchen island if that helps. Thanks/Reddy Also pricing on the translucent glass door for both toilet and shower in master ensuite if anyone has done this if they could let us know the cost. Re: Building with Wisdom Homes 14832Jul 12, 2019 12:05 pm Hi All, We just had our lower level bricks done, but now been having some second thoughts on some kitchen selections. Thinking about changing the laminate to poly urethane and upgrading to undermount sink in pantry. Looking for some info like how much the admin fee would be for this change, trying to see if its worth the change now. Re: Building with Wisdom Homes 14833Jul 12, 2019 12:08 pm kingofnowhere Hi All, We just had our lower level bricks done, but now been having some second thoughts on some kitchen selections. Thinking about changing the laminate to poly urethane and upgrading to undermount sink in pantry. Looking for some info like how much the admin fee would be for this change, trying to see if its worth the change now. You would be up for a variation from both Wisdom and whoever is doing your kitchen as well as the difference in your product What is your current laminate and what poly do you want to change to? Re: Building with Wisdom Homes 14834Jul 12, 2019 12:20 pm Manhattan52 kingofnowhere Hi All, We just had our lower level bricks done, but now been having some second thoughts on some kitchen selections. Thinking about changing the laminate to poly urethane and upgrading to undermount sink in pantry. Looking for some info like how much the admin fee would be for this change, trying to see if its worth the change now. You would be up for a variation from both Wisdom and whoever is doing your kitchen as well as the difference in your product What is your current laminate and what poly do you want to change to? Thanks manhattan52, we have selected we have polytec laminate with matt finish (highland cherry) for all. Seeing if we can upgrade to 2 tone i.e. below the cook top run to white white gloss with polytec / laminex (the most economical poly urethane look). Any idea on how much the variation for wisdom and timpelle going to be Re: Building with Wisdom Homes 14835Jul 12, 2019 12:25 pm kingofnowhere Manhattan52 kingofnowhere Hi All, We just had our lower level bricks done, but now been having some second thoughts on some kitchen selections. Thinking about changing the laminate to poly urethane and upgrading to undermount sink in pantry. Looking for some info like how much the admin fee would be for this change, trying to see if its worth the change now. You would be up for a variation from both Wisdom and whoever is doing your kitchen as well as the difference in your product What is your current laminate and what poly do you want to change to? Thanks manhattan52, we have selected we have polytec laminate with matt finish (highland cherry) for all. Seeing if we can upgrade to 2 tone i.e. below the cook top run to white white gloss with polytec / laminex (the most economical poly urethane look). Any idea on how much the variation for wisdom and timpelle going to be it might be almost cheaper to do your doors yourself after handover. There is a place at castle hill who will take your doors off and poly them for you and put them back on yo will get absolutely smashed with a variation fee and the 25% builders margin if you change now, when all Wisdom needs to do is send timpelle an email as builders will normally only put your cabinets into production 2-3 weeks before, installation. So unless they are already made, its just the time it takes to write a quick email Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 14836Jul 12, 2019 12:29 pm kingofnowhere Manhattan52 kingofnowhere Hi All, We just had our lower level bricks done, but now been having some second thoughts on some kitchen selections. Thinking about changing the laminate to poly urethane and upgrading to undermount sink in pantry. Looking for some info like how much the admin fee would be for this change, trying to see if its worth the change now. You would be up for a variation from both Wisdom and whoever is doing your kitchen as well as the difference in your product What is your current laminate and what poly do you want to change to? Thanks manhattan52, we have selected we have polytec laminate with matt finish (highland cherry) for all. Seeing if we can upgrade to 2 tone i.e. below the cook top run to white white gloss with polytec / laminex (the most economical poly urethane look). Any idea on how much the variation for wisdom and timpelle going to be I think Wisdom is either $1000 or $1500. Timpelle may not charge you and don’t know how much it would be but they do state that they can. However in my experience with them they are pretty good with changes. Because it’s a colour change may be ok however they may need redraw fee for your undernount sink cut out. Personally I would change now if that’s what you really want as you don’t want to be always thinking you wish you had changed it. However the Highland Cherry in Woodmatt is a lovely colour Re: Building with Wisdom Homes 14837Jul 12, 2019 1:16 pm SejaeD it might be almost cheaper to do your doors yourself after handover. There is a place at castle hill who will take your doors off and poly them for you and put them back on yo will get absolutely smashed with a variation fee and the 25% builders margin if you change now, when all Wisdom needs to do is send timpelle an email as builders will normally only put your cabinets into production 2-3 weeks before, installation. So unless they are already made, its just the time it takes to write a quick email Thanks can they do drawers too ? Can you please PM me the details of the place, would like to check them out before i make a decision. Re: Building with Wisdom Homes 14838Jul 12, 2019 1:28 pm Manhattan52 I think Wisdom is either $1000 or $1500. Timpelle may not charge you and don’t know how much it would be but they do state that they can. However in my experience with them they are pretty good with changes. Because it’s a colour change may be ok however they may need redraw fee for your undernount sink cut out. Personally I would change now if that’s what you really want as you don’t want to be always thinking you wish you had changed it. However the Highland Cherry in Woodmatt is a lovely colour manhattan52 thanks i also prefer changing now and not worry about voiding any warranties, unless doing post handover is going to be way cheaper. Thanks for the confidence boost on Woodland cherry selection Re: Building with Wisdom Homes 14839Jul 12, 2019 6:25 pm Hi Guys, Trying to get my head around the required cabling for double storey (ambassador 36), its all confusing for me, not an expert. How many data points you have? I am thinking to future proof the house. How much is wisdom charging for extra data points than what they offer. Is it Hills Home Hub that wisdom installs? didnt read great reviews about it, and also it is hard to expand in future if you want to. Does wisdom allows to have our own cabling? by a licensed one? Any advise is greatly appreciated. Thanks Re: Building with Wisdom Homes 14840Jul 14, 2019 5:28 pm Athena Hi Guys, Trying to get my head around the required cabling for double storey (ambassador 36), its all confusing for me, not an expert. How many data points you have? I am thinking to future proof the house. How much is wisdom charging for extra data points than what they offer. Is it Hills Home Hub that wisdom installs? didnt read great reviews about it, and also it is hard to expand in future if you want to. Does wisdom allows to have our own cabling? by a licensed one? Any advise is greatly appreciated. Thanks My electrical was signed off in Aug '18. Single data point $140, double $260, inc GST. As to how many you need purely comes down to own preference. Do lots of research. Wireless these days is pretty common for most applications and heaps of info on this forum. I still put one in each bedroom for kids studying, multiple at each point where there are tv's and entertainment consoles and multiple in home study for PC's and printers etc. Probably overkill but easy to do now than regret later. Also depends how tech savvy you are. Haven't heard of anyone doing own cabling and don't think Wisdom would allow as they are carrying the builder warranty. Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73525 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8242 |
