Request it from your SS at electrical rough in stage. They will probably do it as it’s not adding something new just slightly moving it
Browse Forums Building A New House Re: Building with Wisdom Homes 14170Feb 17, 2019 9:37 pm Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 14176Feb 18, 2019 6:03 am singalg Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks I have linear outlets in the drop ceiling with vent facing dining. In other cases, they should put a vent in dining near the window. Do you have a plan from Actron? Hi Singalg, Yeah. If something is prohibitive to install in Dining they should have installed a linear one in the dropped ceiling. Yeah. I checked the plans. It is supposed to be closer to the dining window. Ultra air says there is L shaped beam around the room. But I can see the beam runs through the living room. But I am not sure how did they manage to put there!! Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 14177Feb 18, 2019 6:06 am Hi Doosra, I have one too on top of the sink like you. But you should have one in Dininh.Isn’t it? Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 14178Feb 18, 2019 7:20 am Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks You have a beam running along your dining room. Ultra air know this but when you go for you AC appointment they still indicate an outlet where your window is then you get the big surprise when you see it and they all run away blaming each other (Ultra Air/Wisdom) because they only like to communicate to each other at the Christmas party over a free feed and a beer. Re: Building with Wisdom Homes 14179Feb 18, 2019 10:21 am Manhattan52 M4bath For those who are in the north ryde area, any recommendation for an arborist? Got 1 tree that needs a report whether we can remove it. Thanks! Bradshaw Trees. Highly recommended Got it. singalg - sure. will also take a look at true local. the last time we did a general search, only found someone who does the trimming and removal, not the report itself. Re: Building with Wisdom Homes 14180Feb 18, 2019 3:22 pm calais Priyasuresh11 Hi guys, May I know where the ac outlet was made for you in the dining? We build Majestic 35. They have made the outlet in the walkway and didn’t even let us know about it and we too didn’t notice too.But in the Aircon plan it is in the dining closer to the window. The ultra air technicians are saying different reasons. Someone please reply. We got keys on 12th Dec. Thanks You have a beam running along your dining room. Ultra air know this but when you go for you AC appointment they still indicate an outlet where your window is then you get the big surprise when you see it and they all run away blaming each other (Ultra Air/Wisdom) because they only like to communicate to each other at the Christmas party over a free feed and a beer. Exactly. Terrible. Atleast they could have installed a linear outlet in the dropped ceiling. They didn’t do that either.I wonder is this their first ever project with beams???? Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73525 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8242 |
