Unfortunately, that installation is very much substandard, real amateur stuff. Do you intend paving around the slab?
Browse Forums Building A New House Re: Building with Wisdom Homes 13101Oct 20, 2018 1:08 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Wisdom Homes 13104Oct 20, 2018 2:27 pm Progress @week29 from slab: - All electrical and plumbing completed - good to see workers onsite today - they were completing all floors tiles (ground floor), so I am expecting grouting completed early next week, and probably some minor fixes and paint touchups. No date for PCI yet, I hope its not far.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 13105Oct 20, 2018 2:48 pm Jenifermarie twolittlepeas Jenifermarie Our water tank is a slimline tank from Kingspan Water Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Is a slim water tank an upgrade?? It’s the included water tank. Here are some pictures. The pipes have all been painted monument to match since these photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thanks jenifermarie ! I thought there might of been a slimmer one that we could get. What is the width on your one? I was told I couldnt fit mine on the side of our house, our side setbacks are 920mm. Re: Building with Wisdom Homes 13106Oct 20, 2018 3:04 pm singalg When enquired, I was told that that's what was in the plan that was approved by council, and changing it will mean additional cost and delay by around 6 weeks. I would have checked that with council. I would have thought that the retained volume was all that would concern council, not the shape of the tank unless offset to the boundary could also have been an issue. The substandard installation I have referred to has some very common isues that nearly all home owners are landed with unfortunately. The first flush diverter is fitted at the top of the wet system vertical riser. Wet systems retain water between rainfall, the first flush diverter will only fill with the settled water in the riser when it starts raining while the first flush will still be in the downpipe at the other end. There is no flap valve fitted to the wet system's discharge above the tank to prevent mosquito and other pest ingress but the pipe's current angle doesn't allow this anyway. The wet system will build up crud in the underground pipes if no leaf diverters are installed on the downpipe. Fitting leaf diverters also prevents mosquitoes accessing the standing water and breeding. From egg to adult mosquito takes about 12 days. Fitting an inspection cap at the bottom of the vertical riser allows some minor wet system flushing assistance, there isn't one fitted but maybe there is one fitted at the downpipe. Another area of concern is the tank's very low fitted outlet valve if it will supply an external pump. I suspect that a submersible pump will be installed but most submersible pumps that I see are installed incorrectly anyway. I hope that a Rainbank won't be used, there are better (and cheaper) choices. The installation is nevertheless compliant but compliance doesn't guarantee good design unfortunately. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Wisdom Homes 13107Oct 20, 2018 3:38 pm For those in construction, may I ask what your construction timeline has been like in weeks? I’m at week 9, and they have completed bricks and roof. Our timeline as follows: Week 1 - excavation, fencing, piering & formwork Week 2 - slab pour, pipes & plumbing Week 3 - frame delivery Week 5 - frames completed, brick delivery Week 8 - roof completed Week 9 - bricks completed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I’m really surprised at how quickly it’s building. My husband is so optimistic, he believes our home will be completed before the contract date. Lol Re: Building with Wisdom Homes 13108Oct 20, 2018 4:10 pm @twolittlepeas, we also had a very quick and good construction period. Happy how it went throughout. It's only when the last items 'driveway, fencing, landscaping' were supposed to be started, RAIN started and has been continuing for 3 weeks in Sydney! Our house is ready inside, but what can be done with weather. Wisdom, however, is trying hard to progress even with the wet soil. I appreciate. We are very happy with our SS who finished almost everything ahead of time which is helping to cope up with the weather delay. We are 30 weeks from Slab now (not including public holidays and rain). Slab went on 19 March 2018. Hoping to get PCI date soon. I am optimistic to end my journey with Wisdom Homes as a happy customer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 13109Oct 20, 2018 4:23 pm kvav27 Thanks for the model and price. I do agree with the less hassle but when everything adds up .. M52 - yea, KDR and from what I’ve seen from most new houses in my council area, does seem like we will require more than the standard 3000L, probably double at least..?? Trying to pre-empt where to place the bigger size tanks. Anyone know the brands being used for the rainwater tank?[/quote] Our water tank is a slimline tank from Kingspan Water Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/[/quote] Is a slim water tank an upgrade??[/quote] It’s the included water tank. Here are some pictures. The pipes have all been painted monument to match since these photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/[/quote] Hi Jeniffermarie, Did they install the water tank after QA inspection and your PCI? When did they do the driveway. We are also in the same phase.due to the wet weather our driveway work has bee Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13110Oct 20, 2018 4:33 pm singalg @Priyasuresh11, I have gone with Empire blinds, for shutters, blinds and security doors - happy with service so far. Wynstan's quote was also good/reasonable. Thank you Singalg. Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 13111Oct 20, 2018 6:37 pm singalg Progress @week29 from slab: - All electrical and plumbing completed - good to see workers onsite today - they were completing all floors tiles (ground floor), so I am expecting grouting completed early next week, and probably some minor fixes and paint touchups. No date for PCI yet, I hope its not far.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looking fantastic singalg Re: Building with Wisdom Homes 13112Oct 20, 2018 7:06 pm singalg Progress @week29 from slab: - All electrical and plumbing completed - good to see workers onsite today - they were completing all floors tiles (ground floor), so I am expecting grouting completed early next week, and probably some minor fixes and paint touchups. No date for PCI yet, I hope its not far.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Great Progress singalg everything is coming together well !! Re: Building with Wisdom Homes 13113Oct 20, 2018 7:16 pm Hi All, Our build is going ok with a few delays and hiccups . We were told in the nick of time that some of our tiles were discontinued and needed to be reselected. That cost us about 5-7 days as Di-Lorenzo never bothered to contact us before (which they could have easily done). All these minor delays are adding up . Currently we are in Week 27 and our tiles got finally delivered and the bathroom tiles should hopefully finish by next week. Our supervisor got one coat of paint done and door frames etc. Some photos (not the best ones) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 13114Oct 20, 2018 7:46 pm Priyasuresh11 @kvav27 Thanks for the model and price. I do agree with the less hassle but when everything adds up .. M52 - yea, KDR and from what I’ve seen from most new houses in my council area, does seem like we will require more than the standard 3000L, probably double at least..?? Trying to pre-empt where to place the bigger size tanks. Anyone know the brands being used for the rainwater tank? Our water tank is a slimline tank from Kingspan Water Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/[/quote] Is a slim water tank an upgrade??[/quote] It’s the included water tank. Here are some pictures. The pipes have all been painted monument to match since these photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/[/quote] Hi Jeniffermarie, Did they install the water tank after QA inspection and your PCI? When did they do the driveway. We are also in the same phase.due to the wet weather our driveway work has bee[/quote] Our water tank went in really early, I can’t remember exactly when but I want to say around the same time as the roof. Driveway was done about 3 weeks ago, just before all the rain started. It was our last big thing to be completed. It was a week before our QA inspection. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 13115Oct 20, 2018 7:49 pm twolittlepeas Jenifermarie twolittlepeas [quote="Jenifermarie"] Our water tank is a slimline tank from Kingspan Water Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Is a slim water tank an upgrade?? It’s the included water tank. Here are some pictures. The pipes have all been painted monument to match since these photos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thanks jenifermarie ! I thought there might of been a slimmer one that we could get. What is the width on your one? I was told I couldnt fit mine on the side of our house, our side setbacks are 920mm.[/quote] We have 1.45m setback where the water tank is. I’m not sure of the exact width. It’s about 70-80cm wide I think. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 13116Oct 20, 2018 8:15 pm spk_homebuild Hi All, Our build is going ok with a few delays and hiccups . We were told in the nick of time that some of our tiles were discontinued and needed to be reselected. That cost us about 5-7 days as Di-Lorenzo never bothered to contact us before (which they could have easily done). All these minor delays are adding up . Currently we are in Week 27 and our tiles got finally delivered and the bathroom tiles should hopefully finish by next week. Our supervisor got one coat of paint done and door frames etc. Some photos (not the best ones) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey spk_homebuild, it was only a few days back when our build was at the same stage as yours - so you are not too far behind Very soon you shall see tiles started, and keen to see some more pics as progress comes along... Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 13117Oct 20, 2018 8:57 pm singalg spk_homebuild Hi All, Our build is going ok with a few delays and hiccups . We were told in the nick of time that some of our tiles were discontinued and needed to be reselected. That cost us about 5-7 days as Di-Lorenzo never bothered to contact us before (which they could have easily done). All these minor delays are adding up . Currently we are in Week 27 and our tiles got finally delivered and the bathroom tiles should hopefully finish by next week. Our supervisor got one coat of paint done and door frames etc. Some photos (not the best ones) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey spk_homebuild, it was only a few days back when our build was at the same stage as yours - so you are not too far behind Very soon you shall see tiles started, and keen to see some more pics as progress comes along... Thanks singalg. It is a relief to know that. I have updated my blog with more details and photos of our progress. Re: Building with Wisdom Homes 13118Oct 20, 2018 9:29 pm On the topic of window coverings I’d recommend screen doors are done by W. We got ours post handover and unfortunately our stacker door frames were installed incorrectly during the build, so screen doors can’t be installed until the frames are fixed. It’s been ok but now the weather is warming up it’s becoming a pain not being able to leave the doors open. Plus we have $2500’s worth of screens sitting useless in our garage. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 13119Oct 21, 2018 5:35 am MandM+4 On the topic of window coverings I’d recommend screen doors are done by W. We got ours post handover and unfortunately our stacker door frames were installed incorrectly during the build, so screen doors can’t be installed until the frames are fixed. It’s been ok but now the weather is warming up it’s becoming a pain not being able to leave the doors open. Plus we have $2500’s worth of screens sitting useless in our garage. And which screen doors did you put for? I'm planning on having my retractable screens on the inside rather than the outside. I think they usually leave spacing for flat-screen tracks on the outside but I'm worried and keen to hear what went wrong? Re: Building with Wisdom Homes 13120Oct 21, 2018 8:02 am GLO MandM+4 On the topic of window coverings I’d recommend screen doors are done by W. We got ours post handover and unfortunately our stacker door frames were installed incorrectly during the build, so screen doors can’t be installed until the frames are fixed. It’s been ok but now the weather is warming up it’s becoming a pain not being able to leave the doors open. Plus we have $2500’s worth of screens sitting useless in our garage. And which screen doors did you put for? I'm planning on having my retractable screens on the inside rather than the outside. I think they usually leave spacing for flat-screen tracks on the outside but I'm worried and keen to hear what went wrong? GLO Are you using Centor retractables? They sit on the inside Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73510 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8241 |
