Browse Forums Building A New House Re: Building with Wisdom Homes 1713Apr 13, 2016 12:23 pm Butts THX I know they use HFC but that is irrelevant to how your house is wired up. I don't understand what your issue is? and are we talking about internet or tv? as you mentioned foxtel. House is wired up with Cat6, but NO HFC connection to the house. We are talking about both Internet and TV combined. The HFC connection is usually arranged by Optus/Telstra. It's usually an overhead connection. If you require it to be underground you'll need to discuss it with Optus as to what requirements (if any) they need to be met prior to doing this. I'd say at least a conduit from house to your private pole. Which isn't all that difficult. Pick up a shovel and go for gold. Re: Building with Wisdom Homes 1714Apr 13, 2016 12:25 pm Butts THX I know they use HFC but that is irrelevant to how your house is wired up. I don't understand what your issue is? and are we talking about internet or tv? as you mentioned foxtel. House is wired up with Cat6, but NO HFC connection to the house. We are talking about both Internet and TV combined. Ok, optus connects their cable to your house when you signup, you don't. As extreme says if you want it underground, dig a hole, lay a conduit. If you wanted rooms prewired for Optus/Foxtel then yes you have not done that (let's ignore what you can transmit over cat6 for now) but you'll just pay them to add a connection/set top box to whatever rooms you want. Re: Building with Wisdom Homes 1715Apr 13, 2016 12:26 pm Extreme Butts THX I know they use HFC but that is irrelevant to how your house is wired up. I don't understand what your issue is? and are we talking about internet or tv? as you mentioned foxtel. House is wired up with Cat6, but NO HFC connection to the house. We are talking about both Internet and TV combined. The HFC connection is usually arranged by Optus/Telstra. It's usually an overhead connection. If you require it to be underground you'll need to discuss it with Optus as to what requirements (if any) they need to be met prior to doing this. I'd say at least a conduit from house to your private pole. Which isn't all that difficult. Pick up a shovel and go for gold. Extreme, I understand that and yes that is what they will do. However, it needs to be HFC all the way to the modem/router which will be inside the house. Then it can use my cat6 setup. I need to install the HFC part into the house. Does that make sense? Re: Building with Wisdom Homes 1716Apr 13, 2016 12:28 pm Caeserstone benches 1. Can anyone provide an approximate cost to upgrade from the standard included range to the Deluxe, Premium & Supernatural ranges (40mm benches included in the Prestige range now) 2. Are there additional charges by Wisdom to use different Caeserstones in the Kitchen, Laundry and Bathrooms? Our preference would be to have the Kitchen & Laundry the same (in the Supernatural range) and the Bathrooms to be the same (in the Deluxe Range) Thanks in advance for your time and comments. Regards, Oz.[/quote] Oz, just had a look at my costs associated with this. We had the Prestige package, so a few things included. All up, for 40mm cesarstone to Kitchen, Bathrooms and Laundry was approx $1000 over and above. Hope this helps. Our Kitchen costs alone were $9000 as we upgraded a few things.[/quote] Hi Butts, Thanks for this information, really helpful in knowing roughly what the builder is looking to add on in cost when you wish to vary the standard. I can foresee our Kitchen costs spiralling as well, and also have to include the Butler's Pantry in additional costs. Actually there's a question I don't think we've asked the tender presenter, is the stone bench cost included where there is a Butler's Pantry shown on the standard Masterplan or is this an additional cost? Thanks, Oz Re: Building with Wisdom Homes 1717Apr 13, 2016 12:36 pm ozmonkeyoy Hi Butts, Thanks for this information, really helpful in knowing roughly what the builder is looking to add on in cost when you wish to vary the standard. I can foresee our Kitchen costs spiralling as well, and also have to include the Butler's Pantry in additional costs. Actually there's a question I don't think we've asked the tender presenter, is the stone bench cost included where there is a Butler's Pantry shown on the standard Masterplan or is this an additional cost? Thanks, Oz I don't have a butlers pantry but it is my understanding the default layout is 4 shelves only like a oversized pantry. So everything added there would be an upgrade Re: Building with Wisdom Homes 1718Apr 13, 2016 12:38 pm Butts Extreme, I understand that and yes that is what they will do. However, it needs to be HFC all the way to the modem/router which will be inside the house. Then it can use my cat6 setup. I need to install the HFC part into the house. Does that make sense? You don't install the HFC part, they do. Re: Building with Wisdom Homes 1719Apr 13, 2016 12:47 pm Butts Extreme Butts [quote="THX"] I know they use HFC but that is irrelevant to how your house is wired up. I don't understand what your issue is? and are we talking about internet or tv? as you mentioned foxtel. House is wired up with Cat6, but NO HFC connection to the house. We are talking about both Internet and TV combined. The HFC connection is usually arranged by Optus/Telstra. It's usually an overhead connection. If you require it to be underground you'll need to discuss it with Optus as to what requirements (if any) they need to be met prior to doing this. I'd say at least a conduit from house to your private pole. Which isn't all that difficult. Pick up a shovel and go for gold. Extreme, I understand that and yes that is what they will do. However, it needs to be HFC all the way to the modem/router which will be inside the house. Then it can use my cat6 setup. I need to install the HFC part into the house. Does that make sense?[/quote] Optus will run the HFC/coax to the cable modem. (However most of their cablers are lazy and will want to install it on an external wall)From there you can run your cat6 to where ever you need it. Your router doesn't need to be in the same location as the cable modem. But I believe the new Optus cable modems are also a router, but you can disable this and use your own router elsewhere in the house. Re: Building with Wisdom Homes 1720Apr 13, 2016 12:52 pm THX Butts Extreme, I understand that and yes that is what they will do. However, it needs to be HFC all the way to the modem/router which will be inside the house. Then it can use my cat6 setup. I need to install the HFC part into the house. Does that make sense? You don't install the HFC part, they do. Now I'm starting to feel like a pux!! I think, based on what you and extreme are telling me, is I ONLY need the conduit to go from my power pole to the side of the garage so they can run their HFC connection. Would this be correct? From the side of the garage, I have cat6 straight into the house. They install the the box on the outside of my garage? Really appreciate the info you are giving me, helping IMMENSELY!! Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73519 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8241 |
