Browse Forums Building A New House 1 Jun 06, 2014 3:21 am For cdc approval, can I orient house diagonally and made the garage underneath. This way I can have required side setbacks of 2.5 m for lot width of 28m. For the garage, it has to be 1m behind the building line.
Here is the link to the image which will explain https://www.dropbox.com/s/85mw1f485ksc3 ... tation.JPG Re: house orientation on battlexe plot 2Jun 06, 2014 2:26 pm I don't know if the question can be answered, with the info you've given. "Probably"? CDC does require some enclosed private space, but it's only 24sqm or similar. I don't think there's anything in the regs that talk about any fixed requirement for orientation, so long as you're far enough back from all boundaries and the garage being underneath doesn't make the overall building too high above the natural ground level (I think it's an 8.5m limit?) then you're probably a good part of the way there. Maybe if you draw a diagram, more knowledgeable minds than I can answer? Re: house orientation on battlexe plot 3Jun 06, 2014 9:42 pm image added to give you an idea what I mean. Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3353 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15715 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7020 |
