Browse Forums Building A New House 1 May 28, 2008 10:31 am Hi! Can you recommend the most suitable building stage for an inspection? We're at frame stage now. I know all stages are important . Its just that there must be "the stage" that needs the most attention/s. I plan on getting two inspections done. Definitely one will be the pre-handover stage. A bit confuse as to the other stage
Plan on getting Kevin too Learning from here, I know I should not be too trusting with our builder cheers, Hannah Re: Recommended Stage/s for Independent Inspection 2May 28, 2008 10:36 am Hannah, if you are only getting 2 inspections, make them Pre-Plaster and Pre-Handover....
There have been plenty of threads raised on inspections....it might pay you to read up on them so that you know what to expect? Also read Kevin's website as it's quite informative. http://www.newhomeinspections.com.au Re: Recommended Stage/s for Independent Inspection 3May 28, 2008 11:24 am Thanks, Nicola. Done some reading on previous threads. I've not even finished yet , but I got so convinced to call up Kevin and have an inspection on my slab and frame
He'll do the inspection tomorrow... One thing I realised is not to cut short the trip It's not worth the stress. cheers, Hannah That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81884 It is true that a builder can ignore your independent inspection report as it is not part of the contractual arrangement but that is stupid because he cannot avoid fixing… 9 46854 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98680 |
