Browse Forums Building A New House 1 Jun 02, 2014 5:38 pm Hi everyone We have asked our builder to ensure that the tiled areas to wet areas are at the same level as carpeted rooms so there is no step up to the fininished tiled floors. Now that the variation has come through, they are charging $665 for each wet area for a 50mm set down. Has anyone requested this? If so, are the charges usually so high? Thanks BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Floor levels to tiled areas 3Jun 02, 2014 6:10 pm it depends on the slab design, a waffle slab may need to be re designed to accomodate the step down. or if its a highset theres quiet a bit of extra that needs to happen with floor joists to make this happen. Re: Floor levels to tiled areas 4Jun 02, 2014 6:41 pm I'm just not sure if we need the tiled areas set down at all. If you install a quality underlay and carpet, doesn't the height of the carpet bring it to the same level as the tiled floors? BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Re: Floor levels to tiled areas 6Jun 02, 2014 7:33 pm mgilla no, the best you will get from carpet and underlay is about 15mm. the angle trim on the wet area is 50mm. Thanks, so I do need the 50mm set down. BLOG: http://www.ourphoenix38.blogspot.com.au H1 THREAD: viewtopic.php?f=31&t=70454 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6335 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4922 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2503 |
