Browse Forums Building A New House 1 May 29, 2014 5:59 pm Hi, hope I can get some suggestions from helpful people We are building a custom-designed house on the Central Coast and would like to use a local builder. Our house will have steel frames, Hebel powerfloors, Hebel walls. It seems that some builders don't want to use Hebel - so we'd like to find builders that have worked with Hebel in the past, or have no problem tackling a Hebel build. I guess we'd really be interested in recommendations for builders in general, but obviously if they have built houses with Hebel this would be even better. So a pm or answers to this question would be very welcome Many thanks! Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20432 Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4025 |
