New tech leading suburb in Marsden Park
Browse Forums Building A New House Re: Stockland Elara at Marsden Park 2722Apr 19, 2018 8:26 am Sadly the estate will get substantial aircraft noise from the new airport Re: Stockland Elara at Marsden Park 2723Apr 19, 2018 9:04 am IamSAM Sadly the estate will get substantial aircraft noise from the new airport Please cite your source. Below is a sample: INDICATIVE ONLY - FINAL FLIGHT PATHS NOT YET DETERMINED Re: Stockland Elara at Marsden Park 2724May 08, 2018 12:08 pm Anyone here purchased in The Grange Parkside Terraces? Re: Stockland Elara at Marsden Park 2727May 09, 2018 10:18 pm Cheeku Be very careful as we have built with Stockland before in Pemulwuy. They will ask you to rip it out that’s why they have this carefully selected colors. Go to Pemulwuy and have a look. Re: Stockland Elara at Marsden Park 2729May 11, 2018 8:55 am Hi All, I have started building now and with stage 19. My next door (Left) has ZERO LOT BOUNDARY and I also have ZERO LOT BOUNDARY. As I understand for ZERO LOT BOUNDARY, normally we use garage wall as a fence and then we build fence on it. In my case my neighbour has build down pipes (two of them with distance) and gutter for water hanging on garage wall. Is this allowed when we have ZERO LOT BOUNDARY and we have build garage right to the boundary by leaving 150mm to 200mm and intend to use garage wall as a fence? My main concern is all the water and down pipes will be on my walk way. Please advise me on it! Thank you so much to all of you for your help. Re: Stockland Elara at Marsden Park 2731May 11, 2018 10:56 am Abaxi Hi All, I have started building now and with stage 19. My next door (Left) has ZERO LOT BOUNDARY and I also have ZERO LOT BOUNDARY. As I understand for ZERO LOT BOUNDARY, normally we use garage wall as a fence and then we build fence on it. In my case my neighbour has build down pipes (two of them with distance) and gutter for water hanging on garage wall. Is this allowed when we have ZERO LOT BOUNDARY and we have build garage right to the boundary by leaving 150mm to 200mm and intend to use garage wall as a fence? My main concern is all the water and down pipes will be on my walk way. Please advise me on it! Thank you so much to all of you for your help. The ZERO LOT garage build can never sit exactly on the boundary. The gutter is essential, however the down pipe should be positioned in a manner that water flows down/away from the garage towards street and NOT onto your property. Re: Stockland Elara at Marsden Park 2732May 11, 2018 2:37 pm IamSAM Abaxi Hi All, I have started building now and with stage 19. My next door (Left) has ZERO LOT BOUNDARY and I also have ZERO LOT BOUNDARY. As I understand for ZERO LOT BOUNDARY, normally we use garage wall as a fence and then we build fence on it. In my case my neighbour has build down pipes (two of them with distance) and gutter for water hanging on garage wall. Is this allowed when we have ZERO LOT BOUNDARY and we have build garage right to the boundary by leaving 150mm to 200mm and intend to use garage wall as a fence? My main concern is all the water and down pipes will be on my walk way. Please advise me on it! Thank you so much to all of you for your help. The ZERO LOT garage build can never sit exactly on the boundary. The gutter is essential, however the down pipe should be positioned in a manner that water flows down/away from the garage towards street and NOT onto your property. Thank you. Stockland Elara at Marsden Park 2733May 11, 2018 9:25 pm @Abaxi: It is unusual for the downpipes to be located on the side of the garage. Normally one downpipe would be in front of the garage on the bricks on the side of the zero lot while the other may be at the side of one of the front pillars of the patio. If I were you I would direct that query to the Council personally and trust me they would advise you if what your neighbour did is correct. If not then you can ask Council what your next course of action is. Marsden Central - Shaping the standards of modern-day living Marsden Park: The Sydney suburb you’ve never heard of that’s having a massive transformation An apartment boom is about to take off in Marsden Park. Western Sydney and The Central Coast Home To Fastest Property Sales Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Stockland Elara at Marsden Park 2735May 22, 2018 1:21 pm Abaxi IamSAM Abaxi Hi All, I have started building now and with stage 19. My next door (Left) has ZERO LOT BOUNDARY and I also have ZERO LOT BOUNDARY. As I understand for ZERO LOT BOUNDARY, normally we use garage wall as a fence and then we build fence on it. In my case my neighbour has build down pipes (two of them with distance) and gutter for water hanging on garage wall. Is this allowed when we have ZERO LOT BOUNDARY and we have build garage right to the boundary by leaving 150mm to 200mm and intend to use garage wall as a fence? My main concern is all the water and down pipes will be on my walk way. Please advise me on it! Thank you so much to all of you for your help. The ZERO LOT garage build can never sit exactly on the boundary. The gutter is essential, however the down pipe should be positioned in a manner that water flows down/away from the garage towards street and NOT onto your property. Thank you. Hi Arpan, I had the same thing as you have got, but what they do is build a drainage on the driveway so that water can go. And the downpipe will be located at very far end of the garage so the there won't be any issue. Thanks Re: Stockland Elara at Marsden Park 2736May 22, 2018 3:05 pm Guys, Has anyone try thought on Akuna Vista....Very close to the Schofields train station and prices are as compared to Elara. I do have a plot in Elara but my mind is biting seeing Akuna Vista's prices. Stockland Elara at Marsden Park 2737May 22, 2018 10:41 pm Classic33 Guys, Has anyone try thought on Akuna Vista....Very close to the Schofields train station and prices are as compared to Elara. I do have a plot in Elara but my mind is biting seeing Akuna Vista's prices. Please post the prices mate. Are the prices comparable to the below? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks in advance. Re: Stockland Elara at Marsden Park 2739May 24, 2018 4:40 pm The brand new display village in Stage 24 of Elara will be a Homeworld with 84 display homes!
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Builders that will feature display homes in Homeworld Marsden Park are shown below: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ More information is available on: https://www.blacktown.nsw.gov.au/Have-y ... A-18-00168 |
