Browse Forums Building A New House Re: Stockland Elara at Marsden Park 1002Jul 02, 2015 4:27 pm Guys, Can anyone let me know how to find the Section No and DP/SP for my Lot. This is to apply for the 149 certificate from council. Thanks Re: Stockland Elara at Marsden Park 1003Jul 05, 2015 6:53 am $1 million+ house and land for sale; Lot 1261 Battle-Axe (Elara) Marsden Park NSW 2765 http://www.realestate.com.au/property-h ... -120163125 Re: Stockland Elara at Marsden Park 1008Jul 05, 2015 11:23 pm We are thinking of finalising the builder and the contract now as the registration is due in next 1-2 months (release 5) Is anyone building with Firstyle homes in Elara? Their designs are good and the pricing is reasonable, but their reviews aren't too good. As a matter of fact, most of the builders don't have great reviews. Also, I have a few questions, maybe somebody can help? 1. The Stockland guidelines regarding restriction about the continuous length of side walls, having a break on the side walls after 12 meters apply only to the corner lots OR for all the lots? 2. Can I have garage on any side of my block or is there any stipulation to have garage towards left side only? 3. Is there any requirement to have rain water tanks on the property in Elara? 4. Any guidance / particular points which we should take care before signing the building contract? 5. I understand that H class slab and most probably saline site upgrade for the site costs is required in Elara. Any info regarding this? Thanks Re: Stockland Elara at Marsden Park 1009Jul 06, 2015 11:28 am @greyhair I think you want to start to have a look here: http://www.stockland.com.au/residential ... _final.pdf Our soil classification came back requiring H class yes. As for garage, you'll probably best to check your lot as I think Stockland pre-planned where the driveway for your garage will meet the street. We wanted to change that and got told there was no way, even before the streets were completed. Re: Stockland Elara at Marsden Park 1012Jul 08, 2015 11:41 am Hello everyone ... We are from geranium st lot 913, 437 Sqmts with 15m frontage planning to build a single storey on a corner lot... Anyone with similar lot dimensions looking to build a single storey ?? If yes could u please share some information about the builder ... Regards Reddy Re: Stockland Elara at Marsden Park 1013Jul 10, 2015 6:48 pm Hi, We will be building @ Elara (Home/Land Package with Eden Brae, and are trying to select the bricks that will satisfy the Elara Design Requirements (smooth Bricks) - we still have a bit to go. Our bricks will have to be selected at PGH Bricks&Pavers, and I was wondering if any others on this forum have already gone through the selection process and had their bricks selection accepted. EdenBrae categorizes bricks from A-H, and the bricks considered as "smooth" by PGH are all in H so obviously the biggest upgrade cost. Would be great to hear whether others have a brick selected in a lower category that is deemed acceptable. Re: Stockland Elara at Marsden Park 1014Jul 10, 2015 10:03 pm Hi Belgian Builder, Smooth face requirement by Stockland doesn't mean that the brick has to be extra smooth. I have got "Blackheath" by Boral approved by Elara Stockland. Blackheath is not a smooth face brick -- they are allowing normal bricks. By smooth face they mean the brick should be even and should not have patterns on it. I don't believe you need to upgrade the bricks to smooth face. You can use standard brick at Elara. Cheers, Essen Re: Stockland Elara at Marsden Park 1015Jul 10, 2015 10:46 pm "Smooth" means they can't have discolourations or 'cuts' like Mocha. But there are a lot of others that you can use, eg Cement or Gravel. Re: Stockland Elara at Marsden Park 1016Jul 11, 2015 8:52 am For those who are now on approval stage of the design and construction, what slab did you use? Any other site provisions that we should know? Elara seems to be flat but was wondering if any of you required drop edge beams and other non standard site costs. Would really love to know and get some ideas. Thanks Re: Stockland Elara at Marsden Park 1017Jul 11, 2015 8:59 am Gibson from the Desert Collection is one of the most popular nowadays. It can be used as the main brick complemented by either the Cement or the Sinai as the feature brick if you are not opting for Moroka in your facade. For example, if the Gibson is the main brick then the off white mortar can be used with brick joint as ironed. The feature brick can then be flushed brick joint using a mortar with a colour close to the bricks. If there is cladding in the facade this can be painted as close as possible to the main brick. Alternatively it can be painted as close to the feature bricks. @addie 1231: Elara may require the H1 construction type slab and may be saline affected as well. To satisfy both requirements some builders may charge anywhere from $3K to $4K for each if you have not included these in your tender. Therefore save about $8K for this. Consider expenses for additional BASIX requirements too. Re: Stockland Elara at Marsden Park 1018Jul 11, 2015 8:45 pm kaycee Gibson from the Desert Collection is one of the most popular nowadays. It can be used as the main brick complemented by either the Cement or the Sinai as the feature brick if you are not opting for Moroka in your facade. For example, if the Gibson is the main brick then the off white mortar can be used with brick joint as ironed. The feature brick can then be flushed brick joint using a mortar with a colour close to the bricks. If there is cladding in the facade this can be painted as close as possible to the main brick. Alternatively it can be painted as close to the feature bricks. @addie 1231: Elara may require the H1 construction type slab and may be saline affected as well. To satisfy both requirements some builders may charge anywhere from $3K to $4K for each if you have not included these in your tender. Therefore save about $8K for this. Consider expenses for additional BASIX requirements too. Thanks Kaycee! What are the example of additional Basix requirements aside from rain tank? Stockland Elara at Marsden Park 1019Jul 12, 2015 8:48 am @addie 1231: The standard wall insulation offered by most builders is R1.5. If you have a double storey house you may be required to upgrade the wall insulation to R2.0. I vaguely recall that one mate in GL was charged about $4K for sarking but was'nt sure if that was for BASIX or for BAL. Anyway, to be on the safe side, negotiate for a R2.0 wall insulation as well as sarking, free of charge as a condition of accepting the tender. @BelgianBuilder: If Gibson is considered a mottled colour brick then Gravel is not a bad choice. I have also advised mates to tell the builders that registration will occur in 12 months time even if that is not the case. Most builders will offer 12 months tender validity for unregistered land but if you say it will register in the next 6 months they might offer you a tender validity for only 9 months. However, anything can happen and it is seldom the case that a developer is able to meet the anticipated registration date. Stockland has been doing well at Elara in terms of land registration. Other developers can delay this up to a year and some even revoke the contracts the moment it gets past the sunset date. On another note only DA:15-804 and DA:15-815 have been approved by Council. However, I am not certain that DA:15-815 is at Elara since it is located in the adjacent lot. Therefore it is not true that builders are unable to lodge when the land has not yet been settled. At GL Rawson Homes lodged the DA's at the Council about 6 weeks prior to the land being registered. They secured the developer approval a month before lodging the DA's to Council. This is the reason why GL is now full of houses being built by Rawson Homes since they were very pro-active even prior to construction. I am not saying that the other builders are slack but it is just a difference in processes being followed. Incidentally DA:15-804 is by Edgewater Homes Pty Ltd while DA:15-815 is by Allam Homes Pty Ltd. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Stockland Elara at Marsden Park 1020Jul 14, 2015 8:10 am kaycee @addie 1231: The standard wall insulation offered by most builders is R1.5. If you have a double storey house you may be required to upgrade the wall insulation to R2.0. I vaguely recall that one mate in GL was charged about $4K for sarking but was'nt sure if that was for BASIX or for BAL. Anyway, to be on the safe side, negotiate for a R2.0 wall insulation as well as sarking, free of charge as a condition of accepting the tender. @BelgianBuilder: If Gibson is considered a mottled colour brick then Gravel is not a bad choice. I have also advised mates to tell the builders that registration will occur in 12 months time even if that is not the case. Most builders will offer 12 months tender validity for unregistered land but if you say it will register in the next 6 months they might offer you a tender validity for only 9 months. However, anything can happen and it is seldom the case that a developer is able to meet the anticipated registration date. Stockland has been doing well at Elara in terms of land registration. Other developers can delay this up to a year and some even revoke the contracts the moment it gets past the sunset date. On another note only DA:15-804 and DA:15-815 have been approved by Council. However, I am not certain that DA:15-815 is at Elara since it is located in the adjacent lot. Therefore it is not true that builders are unable to lodge when the land has not yet been settled. At GL Rawson Homes lodged the DA's at the Council about 6 weeks prior to the land being registered. They secured the developer approval a month before lodging the DA's to Council. This is the reason why GL is now full of houses being built by Rawson Homes since they were very pro-active even prior to construction. I am not saying that the other builders are slack but it is just a difference in processes being followed. Incidentally DA:15-804 is by Edgewater Homes Pty Ltd while DA:15-815 is by Allam Homes Pty Ltd. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I agree with this Kaycee as Elara informed us that we can get their approval to lodge DA before registration. |
