@MiloP: Reminiscent of the times when the Greenway Sales Team were sending out their email notifications at 8:00am on Saturdays but people have camped and formed a queue.
Browse Forums Building A New House Re: Stockland Elara at Marsden Park 1890Jan 16, 2017 1:27 pm ![]() ![]() Hi ,Secured cornered block with 1.5m easement few months back. Registration is in 2018 April. Wondering how much price do I need to expect for the 24-26sqr double storey construction on corner block. Any suggestion appreciated. Thanks Double storey 26 square would be around $330,000 (mid spec). It is possible to build it for around $300,000 but it would be low spec. Regards v_power Thanks for the reply... Re: Stockland Elara at Marsden Park 1892Jan 16, 2017 8:47 pm ![]() ![]() Hi All I am new to this forum ..I am planning to buy a lot in elara .Just curious to know is 28m depth block a good size for home designs? Thanks You MUST allow 4.5m at the front and 4m at the back. So, if your block is 28m deep, you can practically build on 19.5m. It should be sufficient if you are building a double storey house. However, the width is also something that limits your options. If it is 10m wide and has easements on both sides (typically 0.9m), you have 8.2m in width.. so that limits your options. But, the simple answer to your question is - Yes. It is a sufficient size to build a double storey home but you may be limited to 2 or 3 designs per builder. Thanks for the reply. Block width is 12.5m..I have one more option with 14.5m width ..but the depth is same 28m..I am definitely opting for double storey block..so which is the most ideal block between these two Thanks Re: Stockland Elara at Marsden Park 1893Jan 16, 2017 9:03 pm @Har86: You have more leeway/options with a 14.5m width lot. However, there should be more than enough designs for you to choose from with a 12.5m width lot. From the latest release it seems you are choosing between a 350sqm lot and a 406sqm lot. The price difference is $37K and if I were you I would rather use this saving on my house. Re: Stockland Elara at Marsden Park 1894Jan 16, 2017 9:20 pm ![]() @Har86: You have more leeway/options with a 14.5m width lot. However, there should be more than enough designs for you to choose from with a 12.5m width lot. From the latest release it seems you are choosing between a 350sqm lot and a 406sqm lot. The price difference is $37K and if I were you I would rather use this saving on my house. Thanks for the Reply Even I am thinking the same but with 406 you get some space in backyard..but if we are going for double storey it doesn't make a huge difference in backyard if it's 350 or 406? Re: Stockland Elara at Marsden Park 1895Jan 16, 2017 9:30 pm ![]() @Har86: You have more leeway/options with a 14.5m width lot. However, there should be more than enough designs for you to choose from with a 12.5m width lot. From the latest release it seems you are choosing between a 350sqm lot and a 406sqm lot. The price difference is $37K and if I were you I would rather use this saving on my house. Did you purchase land in elara? Re: Stockland Elara at Marsden Park 1896Jan 17, 2017 8:18 am ![]() @charan: The prices of the Frontier Stage 28 Release are still reasonable. Yes mate, I think they are reasonable. Just an update on my situation, I was able get hold of a corner block just before Christmas. Registration is said to be in April. Re: Stockland Elara at Marsden Park 1897Jan 17, 2017 10:42 am ![]() ![]() @Har86: You have more leeway/options with a 14.5m width lot. However, there should be more than enough designs for you to choose from with a 12.5m width lot. From the latest release it seems you are choosing between a 350sqm lot and a 406sqm lot. The price difference is $37K and if I were you I would rather use this saving on my house. Thanks for the Reply Even I am thinking the same but with 406 you get some space in backyard..but if we are going for double storey it doesn't make a huge difference in backyard if it's 350 or 406? What you have to do is go to the display centres and look at some house designs. Look at designs that fit a 12.5m wide block, if you like what you see, then go with that. If you don't, then go for 14.5m wide block. A wider block means a wider backyard and not a deeper backyard. Anyway, with a double storey, there are designs that will give you a 6 to 8m deep backyards... which are more than enough... Re: Stockland Elara at Marsden Park 1898Jan 17, 2017 10:53 am ![]() ![]() ![]() @Har86: You have more leeway/options with a 14.5m width lot. However, there should be more than enough designs for you to choose from with a 12.5m width lot. From the latest release it seems you are choosing between a 350sqm lot and a 406sqm lot. The price difference is $37K and if I were you I would rather use this saving on my house. Thanks for the Reply Even I am thinking the same but with 406 you get some space in backyard..but if we are going for double storey it doesn't make a huge difference in backyard if it's 350 or 406? What you have to do is go to the display centres and look at some house designs. Look at designs that fit a 12.5m wide block, if you like what you see, then go with that. If you don't, then go for 14.5m wide block. A wider block means a wider backyard and not a deeper backyard. Anyway, with a double storey, there are designs that will give you a 6 to 8m deep backyards... which are more than enough... Thanks for your reply We are going to see few display houses today so that we can some to a conclusion. Will let you know how we go. Thanks Re: Stockland Elara at Marsden Park 1899Jan 17, 2017 3:26 pm Hey, i recently purchased a house and land package in elara. Just had a quick question regarding the NBN in the estate. I asked an employee at the builder i chose but he didn't have a clue. All he said is the house will be NBN ready. What technology are they installing? Fibre to the home, fibre to the node or a variation of the HFC network? Thanks psb Re: Stockland Elara at Marsden Park 1900Jan 17, 2017 4:37 pm ![]() ![]() There is a release today and minimum is 280 size of 362k.. anyone going.. 280 has .9m easement on one side.. do u think its worth buying.. i hope we can cover full on the other side By the time you wrote this message, all of the sales appointments were already booked. The sales staff opened the office before the email went out and handed out all appointments to people who were "tipped off" to turn up early. Elara sales are very suspect these last few months. They send out an email at 8:30 to 9am in the morning, but before you even receive the email the appointments get booked. After I secured my lot before Xmas, my best mate got interested to buy in Elara. When he presented the idea of turning up early on a saturday without knowing there is a release, I called him crazy. Last saturday he was there @8am to be 20th in a queue. Quite interesting!! No wonder all sales appntmnts were booked out. Hello I have a question, when you upgrade an existing lights ( from metal halide to LED) on existing lighting poles in a recreational park. Do you have to design check… 0 13894 |
