Browse Forums Building A New House Re: 3D drawing from a 2D plan 2May 07, 2014 11:59 am As long as you have the measurements. You can do it yourself with My Virtual Home, we did this with our build Re: 3D drawing from a 2D plan 3May 07, 2014 4:36 pm Also importing a scanned image of your house plan into 'google sketch up' is simple then trace over the lines and pull the model up. Yes I know it sounds a little magical but give it a google it's very easy. Re: 3D drawing from a 2D plan 4May 07, 2014 6:32 pm I've downloaded Google Sketch but now how on earth do I do that??? I have imported the plan but can't see where I trace it and also its saved it on a weird angle...sounded simple till I gave it a go! Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: 3D drawing from a 2D plan 5May 07, 2014 7:37 pm There are some good online tutorials if you look at youtube. It takes a bit of fiddling but it's not too difficult. I do recommend the tutes. Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: 3D drawing from a 2D plan 7May 10, 2014 11:41 am You can also use sweethome 3d as that allows you to draw in 2d and then see the 3 d version. Re: 3D drawing from a 2D plan 8May 10, 2014 12:32 pm AussieMark You can also use sweethome 3d as that allows you to draw in 2d and then see the 3 d version. This looks like a great program... pity I didn't find it before I went to the trouble of learning Google Sketchup. Re: 3D drawing from a 2D plan 9May 10, 2014 5:17 pm Yep sweethome is very easy to use and allows to give shadow and 3d picks at different times of the day. There are a few things you have to consider when you have split levels but it really helped me visualise what my house will be like. Re: 3D drawing from a 2D plan 10May 10, 2014 10:04 pm How do you do a second storey on these? I've tried but can only seem to do single storey even tho I can add stairs? Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: 3D drawing from a 2D plan 11May 11, 2014 1:18 am Ok so when you open the single story go to one of the menus and it says add story. then to shift between there is a + and a -. For stairs i use the misc box and shape the size of the steps, which is usually 172mm high and prob 250 deep and how ever side your stairs are. then for the next step copy last on and raise the starting high by the height of the previous step and so on. To draw fast if you are using double brick make the outside walls 250 thick and you can save time by using the split wall function. If you highlight all walls you can right click and modify all at once. Its very cool. oh yes and when it comes to colours you can type in the various colour numbers off the chits and see what different renders look like. Have fun..... Re: 3D drawing from a 2D plan 13May 11, 2014 10:44 am Yep for me I needed something that would allow me to see/ design a floorplan and then see it in 3D. I am living overseas but building in Australia so the common ground to establish some sort of mechanism was needed to describe what I wanted. I also needed to visualise what the finished product would look like. The Home Designer Pro looks amazing and I wish I had time to learn something like that. I was able to improvise quite a bit to get stairs and split levels etc, but it does take a long time to get it right. Re: 3D drawing from a 2D plan 14May 11, 2014 6:56 pm I am oversea as well. So it's a good idea to learn a few more things to make things clear. I do wait till I am back to Aus before starting the build thou. But for the whole design process, it's email, email and email. i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17286 5 10493 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25171 |
