Browse Forums Building A New House 1 Apr 21, 2014 10:49 pm Our Rheem 101 Electric HWS (approx 80l) has sprung a leak in the storage tank. Our tenants have about 10 weeks left on their tenancy before we are due to demolish the house. Does anyone have a short term remedy that might work? Re: Leaking hot water system 4Apr 21, 2014 11:23 pm As this is the first time i have used a forum, it appears i've made 2 mistakes 1. By putting post under "building a new house" rather than up a level. 2. I thought that quick reply needed me to confirm i understood and agreed with terms & conditions of forum - hence yes. But thats obviously doubtful! DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13967 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20228 |
