Browse Forums Building A New House Re: Henley Homes 2036Dec 01, 2015 11:47 am Does anyone know where I can get that list to check off at different stages? I've heard you can buy it off home forum one for a few dollars. Re: Henley Homes 2037Dec 04, 2015 7:20 pm hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. Marina Henley progress: viewtopic.php?style=26&f=31&t=81630 Re: Henley Homes 2038Dec 04, 2015 8:49 pm ![]() hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. I believe it used to be mandatory to have the step down and then they changed it. It's only now required if your driveway slopes towards the garage. Regardless its still a good safety measure to have the step. In the event your garage floods it should prevent water entering the house. Cost was $450 from memory ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Henley Homes 2040Dec 05, 2015 9:19 am ![]() ![]() hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. I believe it used to be mandatory to have the step down and then they changed it. It's only now required if your driveway slopes towards the garage. Regardless its still a good safety measure to have the step. In the event your garage floods it should prevent water entering the house. Cost was $450 from memory Thank you, MichaelQ. Yeah I messaged my administrator to add that in. I haven't been to a house that has the same level of garage and house. Marina Henley progress: viewtopic.php?style=26&f=31&t=81630 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 25452 Our house started in VIC south east in January 24... We just reached lock up stage and should be finished in the next couple of months. Seems the supply chain issues all… 1 30226 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 96136 |
